SPADSTICK QUESTION    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> SPADSTICK QUESTION Page: [1]
Login
SPADSTICK QUESTION - 10/28/2012 4:03 AM
A6TEXAN
Score: 100
Last Login: 5/22/2013
Status: offline
hi all, i want to build a Spadstick. the description i find on the STTB site says the wingspan is 52 inches and fuse length is 46 inches. but the build plans show the fuse length to be 36 inches. (5"/11"/20") im confused. which is it? i want to used a .60 size 2 stroke. it seems 46 inches may be more proper (7"/11"/28"). thanks in advance.
Hide Signatures
       Post #: 1
RE: SPADSTICK QUESTION - 10/28/2012 7:40 PM
aspeed
Score: 105
Last Login: 5/23/2013
Status: offline
I think the rudder and motor/motor mount equal the extra 10".
Hide Signatures
(in reply to A6TEXAN)
       Post #: 2
RE: SPADSTICK QUESTION - 10/29/2012 4:15 AM
A6TEXAN
Score: 100
Status: offline
I kinda thought that as well. i eneded up making the fuse 40 inches and the wingspan 52 inches. gonna reshape the stabilizers to be more like the original ugly stick.
bolt on a s.t. 61, paint it rustoleum red, add the crosses, balance on the spar and go for it.
Hide Signatures
(in reply to aspeed)
       Post #: 3
RE: SPADSTICK QUESTION - 10/29/2012 2:36 PM
aspeed
Score: 105
Status: offline
Get the scallops in the ailerons too.  Thrill and amaze everyone with that.
Hide Signatures
       Post #: 4
RE: SPADSTICK QUESTION - 10/30/2012 2:39 AM
A6TEXAN
Score: 100
Status: offline
you mean like this ??
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5
RE: SPADSTICK QUESTION - 10/30/2012 4:01 PM
aspeed
Score: 105
Status: offline
I'm thrilled and amazed, maybe even motivated to do one.  I was going to do a Gnat.. Maybe I can Eindeckerize it.  The Spadstick looks like a better candidate.
Hide Signatures
       Post #: 6
RE: SPADSTICK QUESTION - 11/1/2012 2:56 AM
A6TEXAN
Score: 100
Status: offline
WING IS FINISHED. JUST NEED TO INSTALL SERVOS.
Click for fullsize
Hide Signatures
       Post #: 7
RE: SPADSTICK QUESTION - 11/8/2012 11:11 PM
jimgee1
Score: 100
Last Login: 5/19/2013
Status: offline
A6,
Nice job on the build.. You'll love the plane.. I think a .60 is too much for the size of the plane, but you don't have to fly it wide-open.. Enjoy! Post pics and/video of the maiden..
Jim Gallagher
Hide Signatures
       Post #: 8
RE: SPADSTICK QUESTION - 11/9/2012 3:38 PM
Villa
Score: 133
Status: offline
Hi A6TEXAN
Nice job. Are you going to mount the aileron servos on the wing surface, partly in the wing, or totally inside the wing?
Hide Signatures
(in reply to jimgee1)
       Post #: 9
RE: SPADSTICK QUESTION - 11/10/2012 2:02 AM
A6TEXAN
Score: 100
Status: offline
thx for the compliments fellas,
jimgee, i increased the w.s to 52" and the fuse length to 40". maybe this will help with the .60 size engine.
villa, im going to install a servo for each aileron, on the bottom of the wing. similar to most "arf" installations.
ill post more pics as i get farther in the build this weekend as the weather is supposed to good for building not flying.
Hide Signatures
(in reply to Villa)
       Post #: 10
RE: SPADSTICK QUESTION - 11/10/2012 3:43 AM
Villa
Score: 133
Status: offline
Hi A6TEXAN
I have mounted aileron servos inside the bottom of the wing, with only the servo arm protruding. I usually cut thru the bottom surface on three sides and hinge the forth side of a 2" by 2" square. What you will then have is a 2" X 2" hatch that is kept closed with a bamboo skewer into one of the flutes, from the trailing edge of the wing. Try this on a scrap piece of 4MM Coroplast. I have posted this procedure some years ago here, with photos, if you want tp search for it. Makes a nice clean instalattion. I sand the Coroplast servo mounting surface, and also sand the servo, and use thin CA glue. I usually cut off the two servo mounting ears. I believe I usually use a plastic tie wrap also, over the servo, but I always wonder if it is needed. Let me know what you think.
< Message edited by Villa -- 11/10/2012 1:19 PM >
Hide Signatures
       Post #: 11
RE: SPADSTICK QUESTION - 11/11/2012 1:40 AM
Jackjet
Score: 105
Status: offline
jackjet
_____________________________
Jack Jet Williams
Apple Valley,Ca
Hide Signatures
       Post #: 12
RE: SPADSTICK QUESTION - 11/17/2012 4:40 AM
A6TEXAN
Score: 100
Status: offline
i have a little more accomplished. been a long week at work. i did install 2 servos in wing so it is finished. also alot has been finished on fuse. need to install push rods, servo tray, and switch. then install front and rear turtledecks and paint with red rustoleum. will post more pics soon.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Jackjet)
       Post #: 13
RE: SPADSTICK QUESTION - 11/18/2012 6:00 PM
PatrickCurry
Score: 110
Status: offline
Looking good A6!
Hide Signatures
       Post #: 14
RE: SPADSTICK QUESTION - 11/28/2012 1:48 AM
ratshooter
Score: 105
Last Login: 3/18/2013
Status: offline
quote:
ORIGINAL: A6TEXAN
A6 have you painted coro before with rustoleum and is it fuel proof? I hadn't thought of painting it before. Have you tried lusterkote on coro? A camo SPAD would be kool!
Hide Signatures
       Post #: 15
RE: SPADSTICK QUESTION - 11/28/2012 2:54 AM
A6TEXAN
Score: 100
Status: offline
hey Shooter,
i got a tip from a friend to use the rustoleum that is "made for plastic". he told me it was fuel proof. i cant confirm it yet. i did get an extra long slim line muffler to use just in case its not. i think the longer it gets to cure before flying will definitely give it a better chance. ill be flying soon and let you know how it works out.
Hide Signatures
(in reply to ratshooter)
       Post #: 16
RE: SPADSTICK QUESTION - 11/28/2012 3:41 PM
PatrickCurry
Score: 110
Status: offline
The regular old gloss Rustoleum is what holds up to glow fuel.  Scuff up the plastic, paint it and then let it cure for a couple weeks before you fly it.  I had a DPS that I painted camo and it held up pretty well.  When you clean your planes, if you scrub the plane clean with paper towel and windex, you can take the paint off, but if you clean it gently, it'll hold up ok.
Hide Signatures
       Post #: 17
RE: SPADSTICK QUESTION - 2/27/2013 2:57 AM
A6TEXAN
Score: 100
Status: offline
shes getting close to flying !!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to PatrickCurry)
       Post #: 18
RE: SPADSTICK QUESTION - 2/27/2013 1:10 PM
aspeed
Score: 105
Status: offline
It almost looks too good for a SPAD.  Only 5 months.  I have taken a couple of years to build a spad.  I think about it too much, and change my mind.  A lot of people make them on a Friday night. (or Saturday if it is special)
Hide Signatures
       Post #: 19
RE: SPADSTICK QUESTION - 2/27/2013 7:40 PM
jimgee1
Score: 100
Status: offline
Tex,
Very nice! Keep up th good work.. Post video if the maiden.. oh, and you can build one for me!
Jim Gallagher..
Hide Signatures
       Post #: 20
RE: SPADSTICK QUESTION - 3/19/2013 1:02 AM
OzMo
Score: 113
Last Login: 5/18/2013
Status: offline
Hi,
Having built several of these over the years I think your 60 will be great. We usually had to add quite a bit of nose weight anyhow.
I extended the nose 2" for my 2 cycle 40s
Personally I still have not found a good "coro paint". I just swip a sign of the right color [>:]
Yes dear, I did glue my hand to the airplane to keep from dropping it.
Hide Signatures
       Post #: 21
RE: SPADSTICK QUESTION - 5/18/2013 5:05 AM
A6TEXAN
Score: 100
Status: offline
finally flew the aircraft today. excellent flights. only 2 clicks of down elevator trim and 1 click right aileron and she flew hands off. had a funny tail waggle that i didnt like though. could have just been the windy day. i find out on a calm day.
Hide Signatures
(in reply to OzMo)
       Post #: 22
RE: SPADSTICK QUESTION - 5/18/2013 1:16 PM
mustangman177
Score: 105
Status: offline
quote:
ORIGINAL: A6TEXAN
Congrats. on the maiden flight !!! The tail waggle wasn't flutter was it ? With the bigger engine and prop wash produced, I've found out that flutter can be a problem. Try stiffening up the stablizer and vertical fin with bamboo skewers for extra support.
Hide Signatures
       Post #: 23
RE: SPADSTICK QUESTION - 5/18/2013 9:06 PM
jimgee1
Score: 100
Status: offline
A6Texan,
Congratz on the maiden, but without pictures or video it never happened..
Jim Gallagher
Hide Signatures
(in reply to mustangman177)
       Post #: 24
RE: SPADSTICK QUESTION - 5/19/2013 5:21 AM
A6TEXAN
Score: 100
Status: offline
LOL im with ya Jim.
i have 4 skewers in each stabilizer. it definitely wasnt flutter. im thinking i should have made the fuselage a little longer, maybe at least 4 inches. it reminded me of my hangar9 corsair. you know how short coupled they are. other than the waggle its a keeper !
Hide Signatures
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
