G-62 Flooding    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> G-62 Flooding
Page: [1]
Login
G-62 Flooding - 10/28/2012 9:07 PM
UDET
Score: 100
Last Login: 5/20/2013
Status: offline
Hello I have a G-62 that runs at mid to full throttle but never reaches more than maybe 3000 RPM it's running super rich. I have had the needle valves turned all the way in and still has to much fuel getting into the carb. I rebuilt the carb and still the same issue. And I changed all the parts out and replaced them with new parts from a ZenG-62 rebuild kit. Still no changes. I tried a different Tank no changes. I can start the engine let it run for a couple of minutes stop it take the carb apart and fuel pours out it's soaked. I've had plenty of G-62's never had this issue. Any ideas. Please do no tell me to buy a different engine thats not going to happen
1.I rebuilt the Carb.
2. I Changed to a different tank (outside the aircraft)
3. tried different gas (I have three G-62's a DA-100 A DLE-111 and a DA-150 and a Sacks 5.8 All run great on my gas oil mixture)
Please help.
Hide Signatures
       Post #: 1
RE: G-62 Flooding - 10/28/2012 10:07 PM
Scota4570
Score: 115
Last Login: 5/18/2013
Status: offline
The rubber tip in the pop off needle is damaged? Did you use carb cleaner? It will eat that tip. Pop off lever set too high? The pulse diaphragm installed backward? The gasket on the pulse diaphragm on the wring side? Little flapper valves in the carb damaged or the fapper valve sheet installed in the wrong orientation? Try a different carb.
Hide Signatures
(in reply to UDET)
       Post #: 2
RE: G-62 Flooding - 10/29/2012 2:06 PM
ROGER RUSSELL
Score: 115
Last Login: 5/22/2013
Status: offline
If you have other G62's, try takeing a carb off of one that you know works and is tuned good and see if that cures the problem on this G62.
When taking off the good carb take notice on how the gasket is situated, etc............
Report back your findings
_____________________________
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to Scota4570)
       Post #: 3
RE: G-62 Flooding - 10/29/2012 2:30 PM
flyinwalenda
Score: 157
Last Login: 5/25/2013
Status: online
Assume it has the correct carb on it ?
Did you check the float level setting ?
Brian Ray
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 4
RE: G-62 Flooding - 10/29/2012 4:26 PM
zx32tt
Score: 110
Last Login: 5/23/2013
Status: offline
I'd look at the fuel needle and replace it if you haven't already. It may be sticking open, or it may not be assembled correctly and causing problems. I hate changing them because of that tiny little spring, but when all else fails, give it a shot.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 5
RE: G-62 Flooding - 11/1/2012 6:32 PM
JeffH
Score: 114
Last Login: 5/24/2013
Status: offline
The rubber needle tip has to be damaged to be letting that amoutn of fuel in, or it is not situated on the arm correctly.
Hide Signatures
(in reply to zx32tt)
       Post #: 6
RE: G-62 Flooding - 11/2/2012 10:55 PM
rt3232
Score: 113
Status: offline
Or the seat could be damaged, had that one
Cheers Bob T
Hide Signatures
(in reply to JeffH)
       Post #: 7
RE: G-62 Flooding - 11/2/2012 11:14 PM
a70eliminator
Score: 100
Status: offline
Could the flywheel have slipped ever so slightly causing a late ignition not burning the charge efficiently.
Hide Signatures
(in reply to rt3232)
       Post #: 8
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> G-62 Flooding
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
