O.S. GF40 40cc Four Stroke Gasser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> O.S. GF40 40cc Four Stroke Gasser
Page: [1] 2   next >   >>
Login
O.S. GF40 40cc Four Stroke Gasser - 10/28/2012 9:26 PM
Pippin
Score: 103
Last Login: 5/21/2013
Status: offline
http://press.radiokaikan.jp/wp-content/uploads/2012/10/IMG_21141.jpg
Hide Signatures
       Post #: 1
RE: O.S. GF40 40cc Four Stroke Gasser - 10/29/2012 2:08 AM
Scota4570
Score: 115
Last Login: 5/18/2013
Status: offline
That links a Futaba radio.
Hide Signatures
(in reply to Pippin)
       Post #: 2
RE: O.S. GF40 40cc Four Stroke Gasser - 10/29/2012 2:22 AM
w8ye
Score: 318
Last Login: 5/22/2013
Status: offline
http://www.os-engines.co.jp/english/index.htm
< Message edited by w8ye -- 2/9/2013 4:02 AM >
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Scota4570)
       Post #: 3
RE: O.S. GF40 40cc Four Stroke Gasser - 10/29/2012 5:41 AM
TimBle
Score: 162
Status: offline
Nice! OS really attacking the petrol engine market
Really nice spec too. Excelletn weight and spinning props in the same range as the 33GT for similar weight. WINNER
Hide Signatures
(in reply to w8ye)
       Post #: 4
RE: O.S. GF40 40cc Four Stroke Gasser - 10/29/2012 10:27 AM
Pippin
Score: 103
Status: offline
http://press.radiokaikan.jp/wp-content/uploads/2012/10/IMG_21091.jpg
Hide Signatures
(in reply to TimBle)
       Post #: 5
RE: O.S. GF40 40cc Four Stroke Gasser - 10/29/2012 11:10 AM
SJN
Score: 105
Status: offline
Awesome
Sonnich Johannesen
Hide Signatures
       Post #: 6
RE: O.S. GF40 40cc Four Stroke Gasser - 1/22/2013 1:34 AM
kochj
Score: 143
Status: offline
Just did a exchange rate for a price in this....
(off a youtube vid, shows the engine with a Yen price amount)
71,400 YENS or 792.89 $ US dollars...
This might be retail but not sure...
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to SJN)
       Post #: 7
RE: O.S. GF40 40cc Four Stroke Gasser - 1/22/2013 5:00 AM
mikes68charger
Score: 106
Last Login: 5/20/2013
Status: offline
 Wow I would like one if its not really $700
Hide Signatures
(in reply to kochj)
       Post #: 8
RE: O.S. GF40 40cc Four Stroke Gasser - 1/23/2013 1:14 AM
airraptor
Score: 130
Status: offline
700 will be cheap as the Saito 220/35CC is 799 and the Roto motor is 770
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to mikes68charger)
       Post #: 9
RE: O.S. GF40 40cc Four Stroke Gasser - 1/23/2013 3:15 AM
kochj
Score: 143
Status: offline
I think it is in the ball park, as a 50 cc moki is 1,100$
This engine isn't a glow conversion either. It will have all the necessary internals that allow us the run what we
Mixed for our other gas engines.
I have a Saito FG 36 that I have yet to run. OS 40 four stroke is a significant price increase compared to what I paid for my Saito. The OS isn't even hear yet, and I would pay the dif to have one though,. I believe the OS will be better sorted, and will be easy to have the mixtures perfect out of the box.
Hide Signatures
(in reply to airraptor)
       Post #: 10
RE: O.S. GF40 40cc Four Stroke Gasser - 1/25/2013 12:39 PM
Cougar-RCU
Score: 100
Last Login: 4/6/2013
Status: offline
I think I am gunna cry , it is the most beautiful thing I have ever seen.
** CUB BROTHERHOOD ** #90
Hide Signatures
(in reply to kochj)
       Post #: 11
RE: O.S. GF40 40cc Four Stroke Gasser - 1/25/2013 4:04 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: TimBle
Where are the spec's?
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 12
RE: O.S. GF40 40cc Four Stroke Gasser - 1/25/2013 5:06 PM
MTK
Score: 203
Status: offline
I found a spec sheet of the 40cc 4 stroke. Hope it comes through. Was told the file is too large which is very strange since its a PDF file
Regards,
MattK
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 13
RE: O.S. GF40 40cc Four Stroke Gasser - 1/25/2013 5:14 PM
MTK
Score: 203
Status: offline
If you look at the link W8YE listed, look at the bottom of the page and see a PDF link. Click there and see the specs. Basically, engine weight is 1200g, muffler and CDI about 205 g.
Engines turns a 20x8W at 6750 rpm or so it sez. So just over about 3 lbs of nose weight will allow a reasonable prop at reasonable RPM.
Click to see the file in new window.Attachment.pdf
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 14
RE: O.S. GF40 40cc Four Stroke Gasser - 1/26/2013 4:04 AM
WindGap
Score: 105
Status: offline
quote:
ORIGINAL: Cougar-RCU
Hehehe...
Hide Signatures
(in reply to Cougar-RCU)
       Post #: 15
RE: O.S. GF40 40cc Four Stroke Gasser - 1/26/2013 4:50 AM
earlwb
Score: 584
Status: offline
It looks like the OS 40cc gas engine is a little bit more powerful than the other four stroke engines in this size range.  A 20x8 at 6750 RPMs would come out at around 2.6 hp for the engine.  A 20x10 turning 6,000 RPms would be about 2.3hp.  The Roto Motor 35cc engine turns the 20x10 prop.  The NGH 38cc gas engine turns a prop in this same power range too.  The 20x8 prop at 6750 rpms would yield about 17 pounds of static thrust. maybe 20 pounds free air thrust, and around 51mph air speed depending on the plane of course.
I was using Pe Reivers prop power calculator spreadsheet with the generic propeller power factor number.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to WindGap)
       Post #: 16
RE: O.S. GF40 40cc Four Stroke Gasser - 1/26/2013 3:50 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: MTK
Well, that's about 3HP so it looks like this 40cc offering has significant power advantage over the Chinese & Eastern Euro offerings.
About the same power as was promised by Saito for the FG36.
Hopefully this engine is a true "gas" engine W/neddle bearings on the crank throw.
Hide Signatures
(in reply to MTK)
       Post #: 17
RE: O.S. GF40 40cc Four Stroke Gasser - 1/26/2013 3:54 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: earlwb
Earl, did you use the "W" factor? It's 1.09 over a standard prop.
My CALCULATOR came out to just under 3HP @ 68°F.
Hide Signatures
(in reply to earlwb)
       Post #: 18
RE: O.S. GF40 40cc Four Stroke Gasser - 1/27/2013 12:40 AM
MTK
Score: 203
Status: offline
If you're into Cubs, power won't be a problem for third scale or a little bigger.
I couldn't open the video link. Anyone have a Utube link that works? I wanna hear this one
Regards,
MattK
Hide Signatures
       Post #: 19
RE: O.S. GF40 40cc Four Stroke Gasser - 1/27/2013 1:35 AM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: earlwb
I used Pe Reivers calculator spreadsheet, a generic prop power factor in his program is 1.2. Thus a engine using a generic prop 20x8 at 6750 rpms puts out 2.59 HP using it.
He put a lot of effort in getting his program to work, so I can expect it to be pretty close in accuracy. it is somewhere on his website MVVS.nl
AMA # 928076
Hide Signatures
       Post #: 20
RE: O.S. GF40 40cc Four Stroke Gasser - 1/27/2013 2:11 AM
capnduane
Score: 105
Status: offline
For $792 I'd like to see a little beefer mounting lugs.......
Hide Signatures
       Post #: 21
RE: O.S. GF40 40cc Four Stroke Gasser - 1/27/2013 2:43 AM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: capnduane
I was noticing that too. it might be a money maker item for the importers to charge more for it.
I would suggest using a metal aluminum backplate for the standoffs to help ensure the the firewall stays level so the lugs aren't strained. A flat plate of at least .090 inch thick should do the trick. Just bolting up the standoffs to a wood firewall won't have the lugs staying even, wood will compress differently at each point.
AMA # 928076
Hide Signatures
(in reply to capnduane)
       Post #: 22
RE: O.S. GF40 40cc Four Stroke Gasser - 2/9/2013 3:55 AM
kochj
Score: 143
Status: offline
quote:
ORIGINAL: MTK
Here is one Matt!!
http://www.youtube.com/watch?v=rDyJy_N1xi0&list=PL-OEvM6c1aYQ4gdMA2YhGMOTDKTe3E7z0
Hide Signatures
(in reply to MTK)
       Post #: 23
RE: O.S. GF40 40cc Four Stroke Gasser - 2/9/2013 5:32 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: kochj
quote:
ORIGINAL: MTK
Here is one Matt!!
Thank you....Definitely has the distinctive OS sound. Noisier than I would have expected It needs a Hatori muffler and a soft mount.
Regards,
MattK
Hide Signatures
(in reply to kochj)
       Post #: 24
RE: O.S. GF40 40cc Four Stroke Gasser - 3/19/2013 10:12 AM
DaveR
Score: 100
Last Login: 5/17/2013
Status: offline
Any more sightings or news on this motor?
Hide Signatures
(in reply to MTK)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> O.S. GF40 40cc Four Stroke Gasser
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.376RCU1
