Meltdown on maiden voyage!~    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Meltdown on maiden voyage!~
Page: [1]
Login
Meltdown on maiden voyage!~ - 10/29/2012 7:19 PM
wvcruffler
Score: 100
Last Login: 11/9/2012
Status: offline
 Howdy all,
Well, the electrix RC boost I bought this weekend to it's maiden and perhaps final drive.  After 5 min of driving it up and down the road, it stopped.  I walked up to it and could smell melting plastic, which is generally not a good thing.  I could then see smoke wafting up from the speed control.  Turned it off and removed the battery, which as it turns out may have been the source of the smoke.  I actually threw the battery since the plastic was melting off and it was smoking.  It is probably still out there in the gravel smoking.  The black wire to the battery has melted off the speed control.  Well, that's not good....  Anyhoo, its only 2 days old and I have sent a message off to electrix to notify them of the issue.
Phil
Hide Signatures
       Post #: 1
RE: Meltdown on maiden voyage!~ - 10/30/2012 6:50 PM
EXT2Rob
Score: 177
Last Login: 5/17/2013
Status: offline
Yeow!  Let us know what you hear (if anything) from them.
Hide Signatures
(in reply to wvcruffler)
       Post #: 2
RE: Meltdown on maiden voyage!~ - 10/31/2012 5:26 PM
The Mad Modder
Score: 341
Last Login: 5/20/2013
Status: offline
That's too bad. Was the chassis damaged by the heat?
Myself, I've had poor luck with horizon brand electronics(losi and electrix are owned by horizon). Every piece of electronic in my losi mini baja quit working in a little over a year and I found out the hard way that Losi's blue mini peak charger doesn't stop charging when the battery is full. Accidentally left it charging my VMG overnight and found an burned nimh and a badly warped battery box the next morning.
_____________________________
God bless America
Hide Signatures
(in reply to EXT2Rob)
       Post #: 3
RE: Meltdown on maiden voyage!~ - 10/31/2012 5:49 PM
nitrosportsandrunner
Score: 296
Status: offline
I had a ecx on my torment burn up. ECX (or horizon I should say) replaced it for free.
You should be able to have them replace the battery and ESC for you.
It kinda sounds like the battery connector shorted out. That would cause both the battery and the ESC to fry.
If they send you replacements, Id recommend upgrading the battery and speed control plugs to deans or traxxas plugs. The white tamiya plugs on those are really pretty sucky.
even low cost Redcat models no longer have tamiya plugs. The twisters have deans copies and the other have 4.0mm banana plugs.
But if you find the warrenty form for the ECX and fill it out you should be taken care of.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to The Mad Modder)
       Post #: 4
RE: Meltdown on maiden voyage!~ - 11/2/2012 7:58 PM
wvcruffler
Score: 100
Status: offline
Good news. All they required were some pics of the carnage and a new battery and ESC are on the way.  The grass was a little wet that day so I wonder if the moisture got to the battery.  It was no impressive amount of moisture, so not clue whether it was the cause or not.  Thanks to all for the help and I will look into upgrading the plugs to Traxxas or Dean.  Where is a reasonable place to buy those pieces?
Phil
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 5
RE: Meltdown on maiden voyage!~ - 11/6/2012 4:02 PM
EXT2Rob
Score: 177
Status: offline
Local hobby store.  Don't forget, you'll need one for your charger too.  Hope you have a good, hot, soldering iron. Be VERY careful on exposed wire length, it needs to be short and accurate so as not to extend beyond the line marked on the contacts. You may also want to "dry run" your soldering setup.  Those contacts hold heat a long time, so it takes a while for the solder to solidify, and you do not want to move the wire while it is cooling.  I usually do this on a piece of wood, and I have some weights to hold the contact and wire in place so it doesn't move while soldering/cooling, and you cannot hold either one by hand, those things get HOT.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.346RCU1
