RE: Looking for a Rear Wheel Drive OnRoad Car    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: Looking for a Rear Wheel Drive OnRoad Car
Page: <<   < prev  1 2 3 [4] 5 6 7 8 9 10   next >   >>
Login
RE: Looking for a Rear Wheel Drive OnRoad Car - 11/24/2012 9:12 AM
Haddi Taha
Score: 183
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: phmaximus
Yeah? Some people have a lot of problems setting gear mesh on the e10 then they blame the car.
My spur is over 5 years old not a simple problem, that's on brushless power 3900kv on 24t pinion and 4300kv on 24t pinion
how often you drive that car?
I used to drive my tb03 two battery packs a day, took 2 months before 1st spur gear went out. I was using 8.5t 4000kv 3s too
_____________________________
Thunder Tiger MT4- Hobbywing 4274sd 2200kv motor- Savox 1256tg Servo
Hide Signatures
(in reply to phmaximus)
       Post #: 76
RE: Looking for a Rear Wheel Drive OnRoad Car - 11/24/2012 5:44 PM
The Mad Modder
Score: 341
Last Login: 5/22/2013
Status: online
quote:
ORIGINAL: phmaximus
Doesn't have anything to do with the plastic motor mount flexing?
quote:
ORIGINAL: phmaximus
1. Your e10 isn't exactly stock.
2. Don't you use it for a drift car? The lower traction of drift tires reduce stress on the drive train considerably.
God bless America
Hide Signatures
       Post #: 77
RE: Looking for a Rear Wheel Drive OnRoad Car - 11/24/2012 11:27 PM
phmaximus
Score: 627
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: The Mad Modder
quote:
ORIGINAL: phmaximus
No. From what ive seen its from the pinion gear moving away from the spur or the gap is incorrectly set. when the mount flexes it does NOT change the gear mesh.
quote:
ORIGINAL: phmaximus
Yep its not stock, im running a allow motor mount, but none of the other upgrades have anything to do with the gear mesh, or gears.
Yes mine is mainly a drift car, its been run heapse if times on hpi rubber tyres(they have slightly more traction then the drift tyre lol)
Allso one would think that if it was going to fail it would with a 3900kv motor with 34t pinion. I have never seen a E10 geared that high
< Message edited by phmaximus -- 11/24/2012 11:58 PM >
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to The Mad Modder)
       Post #: 78
RE: Looking for a Rear Wheel Drive OnRoad Car - 11/25/2012 1:38 AM
-JBLKING-
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: phmaximus
quote:
ORIGINAL: -JBLKING-
quote:
ORIGINAL: phmaximus
It's actually the other way around, I think that one is been built to resemble the real thing, but generally in RWD cars u want the weight at the back to assist with traction. that's why most RWD chassis have the motor behind the diff.
I understand the rear tracting thing but i figured more weight applied to the steering arms in the front make for a sharper turning radius with more force applied.
yep that kind to correct, but when u use weight to assist with traction. what ever it gains from one end it looses from the other.
But generally most rwd cars i know have to much traction on the front (sc10, Slash),
yes there is such think as to much traction on the front end. nothing wores than a setup that constantly oversteers and flips over
For example on my slash im now running stiffer front springs than before, and its reduced the steering & turn in. im loving it, so much eaiser to drive now
I know what you mean! I did the same to my slash.
-JBLKING-
Hide Signatures
       Post #: 79
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/13/2012 4:06 AM
iexion
Score: 149
Last Login: 5/4/2013
Status: offline
Call me what I am. I am Kolossus
Hide Signatures
(in reply to -JBLKING-)
       Post #: 80
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/13/2012 11:09 PM
-JBLKING-
Score: 100
Status: offline
Looks like a working design, but im not a fan of the front shocks. The electronics sound very delicate as well. I wonder if anyone has ever invented a 2wd with 4 wheel braking.
-JBLKING-
Hide Signatures
(in reply to iexion)
       Post #: 81
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/14/2012 12:47 AM
iexion
Score: 149
Status: offline
Im not a fan of the front suspension set up either but its a start. Wider rear tires would be the first thing I would upgrade. If you look up the TS2e and TS4e youll see they are reaslly close to the same chassis except for the front end (Think they are)
Hide Signatures
       Post #: 82
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/14/2012 12:49 AM
-JBLKING-
Score: 100
Status: offline
 The non-adjustability of the chassis will only let you go so far.
-JBLKING-
Hide Signatures
       Post #: 83
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/14/2012 12:54 AM
iexion
Score: 149
Status: offline
You can always find turn buckles from some other brand. Hpi and Associated is where I would start to look
Hide Signatures
       Post #: 84
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 4:14 PM
prestonlal
Score: 109
Status: offline
Finally got some time to do some work on this .....!
Got the motor and tranny sorted....as well as the steering servo...the zip tie is just temporary till i figure out an aluminum mount.
Also got the bumpers and the rear spoiler done...just need to clear coat the body before attaching them! Started toworkon the interior as well...got the trans tunnel completed, the floor pan is work in progress...gonna try to start building the dash today , I hope!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 85
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 4:16 PM
prestonlal
Score: 109
Status: offline
Some more...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to prestonlal)
       Post #: 86
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 4:19 PM
prestonlal
Score: 109
Status: offline
And...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 87
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 9:48 PM
-JBLKING-
Score: 100
Status: offline
quote:
ORIGINAL: prestonlal
wow im impressed! What is your suspension setup for the rear. and will having the front suspension mounted to the front arms rather than the rear, cause it to roll a bit differently?
-JBLKING-
Hide Signatures
       Post #: 88
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 10:20 PM
prestonlal
Score: 109
Status: offline
Rear suspension is the main spring from the tamiya tractor trailer ... Home made U bolts to attach it to the tamiya CC01 axle.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 89
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 10:25 PM
prestonlal
Score: 109
Status: offline
I don't anticipate any issues with the front suspension as its a HPI Super Nitro Rally front suspension and they are designed to be bolted to the front of the front arms.
These a couple of pics of my super rally's , as you can see the shocks are all mounted to the front of the arms!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 90
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 10:31 PM
prestonlal
Score: 109
Status: offline
I also have some dampers to install for the rear but still considering whether to use them or not, as the main spring is already pretty firm. Also because the diff housing is off center it doesn't leave much room to have the dampers mounted like in the 1:1 car.
This is how it looks now... I will try to find a pic of the 1:1 setup...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 91
-JBLKING-
Score: 100
Status: offline
ahh ok i was just wondering.
-JBLKING-
Hide Signatures
       Post #: 92
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 10:33 PM
-JBLKING-
Score: 100
Status: offline
What diff was that from?
-JBLKING-
Hide Signatures
       Post #: 93
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/16/2012 10:37 PM
prestonlal
Score: 109
Status: offline
The stock suspension from the 1:1 car looks like this pic
That diff and the axle is from the Tamiya CC01 Mitsubishi Pajero truck.
Click for fullsize
Hide Signatures
       Post #: 94
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/17/2012 6:13 AM
iexion
Score: 149
Status: offline
This is such a simple layout, why in the hell do they not have this on the market already!!!
Hide Signatures
       Post #: 95
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/17/2012 7:44 AM
prestonlal
Score: 109
Status: offline
My thoughts exactly! That's why I had to build one!
Hide Signatures
       Post #: 96
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/17/2012 7:13 PM
-JBLKING-
Score: 100
Status: offline
I would rather have shocks. How does the adjustability on your suspension compare?
-JBLKING-
Hide Signatures
       Post #: 97
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/17/2012 8:41 PM
prestonlal
Score: 109
Status: offline
Well although I don't think it will need it, but I can always add on the helper leafs to the main spring. Initially the leaf spring assembly came complete with 3 leaf springs per side, but it was too stiff, so I used only the main spring.
That being said, when I put the battery in the back/trunk area, the back drops around 3-5 mms. I tested it in the hallway (low carpet) and it seemed ok. I will know more when I finish building the trunk area and have the battery properly secured, only then I can give it a run outside in the backyard!
Hide Signatures
       Post #: 98
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/19/2012 4:45 AM
prestonlal
Score: 109
Status: offline
Made a lil progress with the dashboard...still needs more detailing and cleaning up!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 99
RE: Looking for a Rear Wheel Drive OnRoad Car - 12/19/2012 4:58 AM
-JBLKING-
Score: 100
Status: offline
How long do you estimate this project to take start to finish and how long have you spent on it already?
-JBLKING-
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
