Hobbyking RX3S Flight Stabilizer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Hobbyking RX3S Flight Stabilizer
Page: [1]
Login
Hobbyking RX3S Flight Stabilizer - 10/31/2012 12:41 PM
mjunior
Score: 103
Last Login: 5/22/2013
Status: offline
Have you guys tried it in glow powered models?
http://www.hobbyking.com/hobbyking/store/__25448__RX3S_OrangeRX_3_Axis_Flight_Stabilizer.html
Any thread about it?
Regards
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Hobbyking RX3S Flight Stabilizer - 10/31/2012 2:30 PM
dirtybird
Score: 173
Last Login: 5/21/2013
Status: offline
I have a couple of them. I expect to try them soon.
There is a lot of info on Hobbykings comments with the article
Hide Signatures
(in reply to mjunior)
       Post #: 2
RE: Hobbyking RX3S Flight Stabilizer - 10/31/2012 2:54 PM
mjunior
Score: 103
Status: offline
Yes but I couldn't see precise information about the results in glow powered models. I'm affraid the natural vibration of those models will affect the stabilizer performance.
Hide Signatures
(in reply to dirtybird)
       Post #: 3
RE: Hobbyking RX3S Flight Stabilizer - 11/1/2012 6:22 PM
dirtybird
Score: 173
Status: offline
I wouldn't expect vibration to cause any problems if it is mounted securely to prevent movement independent of the aircraft. They are all solid state components. Its not like a spinning flywheel gyro.
Hide Signatures
       Post #: 4
RE: Hobbyking RX3S Flight Stabilizer - 11/19/2012 12:56 AM
bicyclemonkey
Score: 100
Last Login: 5/18/2013
Status: offline
We tried this on a friends Pitts with a DLE-30 this weekend and it worked amazing!  The plane was very sensitive, squirrely, and, twitchy in the air before...it was quite a handful.  After the gyro, it settled down nicely, he loves this plane now.
Hide Signatures
       Post #: 5
RE: Hobbyking RX3S Flight Stabilizer - 11/19/2012 6:41 PM
dirtybird
Score: 173
Status: offline
I have one on an old Lazy Ace. I have the gain on the aileron turned all of the way down and it still hunts little bit when I give it full throttle. I am going to cut down the aileron servo movement mechanically and try again tomorrow.
Update
I was turning down the yaw pot and not the aileron. Its hard to read in the bright sun. I now have the aileron pot set at about 50% and there were no hunting.
< Message edited by dirtybird -- 11/20/2012 10:32 PM >
Hide Signatures
(in reply to bicyclemonkey)
       Post #: 6
RE: Hobbyking RX3S Flight Stabilizer - 11/19/2012 7:19 PM
mjunior
Score: 103
Status: offline
quote:
ORIGINAL: bicyclemonkey
Good news. Do you know how much gain is set for each control?
Hide Signatures
       Post #: 7
RE: Hobbyking RX3S Flight Stabilizer - 11/19/2012 7:32 PM
bicyclemonkey
Score: 100
Status: offline
quote:
ORIGINAL: mjunior
I don't remember which was which but two were at 25% and one was 50%. (I think)
Hide Signatures
       Post #: 8
RE: Hobbyking RX3S Flight Stabilizer - 11/19/2012 10:09 PM
rmh
Score: 252
Last Login: 5/19/2013
Status: offline
I am going to get a couple -
After buying some of the little Bind n Fly AS3X arobatic types -it is obvious how well a properly setup gyro can make an otherwise "bright' model and make it feel much larger and solid.
My radios have very good expo/dual rate etc., adj and I really don't have any issues to fix - just want to see how well it works - I will start with my camera carrying model to see if it smooths up my movies .
_____________________________
Libby is still watching you
Hide Signatures
       Post #: 9
RE: Hobbyking RX3S Flight Stabilizer - 11/24/2012 3:14 AM
Flypaper 2
Score: 100
Last Login: 5/16/2013
Status: offline
I have it on an old Zoombi bipe. Made a completely different plane out of it. This was a very violently aerobatic plane with very high throws with lots of expo. With the gyro I had to take out all of the expo as the gyro took over in the stability department. Flies more like pattern plane now and hovering performance is a none issue. Was able to move the CG much further back now because the gyro keeps it much more stable in pitch. Great new tool.
Gord
Dreamed I was a muffler. Woke up exhausted.
Hide Signatures
(in reply to rmh)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
