Ultra Stick 25e Conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> Ultra Stick 25e Conversion
Page: [1] 2   next >   >>
Login
Ultra Stick 25e Conversion - 10/31/2012 10:53 PM
ckreef
Last Login: 6/3/2013
Status: offline
Well the Mini Ultra Stick conversion went so well Ithought I would try another one. This is the Ultra Stick 25e. It's designed for a .25 - .32 sized electric motor. I will convert it to glow using a TT Pro .36. This is giving the Mini Ultra Stick a big brother
I will try and post more detailed conversion pictures along the way. I should be able to order the rest of the needed parts this weekend.
This is a very well built ARF and should only need minimal modification for the conversion. The covering job was excellent and will not need any restretching. It also came with a second landing strut so you can put optional floats on it (floats sold seperatly). Here is the 1st few unboxing pictures.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Ultra Stick 25e Conversion - 10/31/2012 10:55 PM
ckreef
Status: offline
Top off the box.
Click for fullsize
< Message edited by ckreef -- 10/31/2012 10:56 PM >
Hide Signatures
(in reply to ckreef)
       Post #: 2
RE: Ultra Stick 25e Conversion - 10/31/2012 10:57 PM
ckreef
Status: offline
Wing tray removed.
Click for fullsize
Hide Signatures
       Post #: 3
RE: Ultra Stick 25e Conversion - 10/31/2012 10:59 PM
ckreef
Status: offline
Parts laid out as they came.
Click for fullsize
Hide Signatures
       Post #: 4
RE: Ultra Stick 25e Conversion - 11/1/2012 2:44 AM
Twin_Flyer
Last Login: 6/19/2013
Status: offline
I'll be watching the build!
Bill S.
_____________________________
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
       Post #: 5
RE: Ultra Stick 25e Conversion - 11/1/2012 2:59 AM
ckreef
Status: offline
After Dinner the first thing I needed to do was "strike through" the "E" for electric. I used what I had which was red lighting bolts.
Here is the how it came out of the box for the main "E"
Click for fullsize
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 6
RE: Ultra Stick 25e Conversion - 11/1/2012 3:01 AM
ckreef
Status: offline
Here is all the "E"'s after being struck through with lighting bolts.
I had to do a little something on it tonight while waiting till my paycheck to order the needed parts.
Click for fullsize
< Message edited by ckreef -- 11/1/2012 3:03 AM >
Hide Signatures
       Post #: 7
RE: Ultra Stick 25e Conversion - 11/7/2012 2:24 AM
ckreef
Status: offline
I ordered the engine and all the extra extra parts needed to complete this project except the servos. I think I finally decided on what servos to get and should order them within the next few days. In the meantime I got bored and took a picture of the 25e next to his little brother.
Click for fullsize
Hide Signatures
       Post #: 8
RE: Ultra Stick 25e Conversion - 11/7/2012 2:26 AM
ckreef
Status: offline
After reading the reviews on this plane there is a mod or two that needs to be done to strengthen up a few areas. I started working on that tonight. Even though this part is inset with tabs I added a little 30 min epoxy to the  wing bolt down area just to make sure.
Click for fullsize
< Message edited by ckreef -- 11/7/2012 2:27 AM >
Hide Signatures
       Post #: 9
RE: Ultra Stick 25e Conversion - 11/7/2012 2:30 AM
ckreef
Status: offline
The TE where the wing bolts go through needed to be strengthened. I used some light plywood covered in some white monocote. Here is the underside of the Plywood piece ready to be epoxied in place alond with the wing TE with the covering cutaway to accept the epoxy.
Click for fullsize
Hide Signatures
       Post #: 10
RE: Ultra Stick 25e Conversion - 11/7/2012 2:32 AM
ckreef
Status: offline
I used 30 min epoxy to attach the strengthing piece to the wing TE. Here is the fix done with the wing installed.
Click for fullsize
Hide Signatures
       Post #: 11
RE: Ultra Stick 25e Conversion - 11/10/2012 12:29 AM
ckreef
Status: offline
This is all the extra parts needed except the 4 main servos. I have them on order and they should arrive the 1st part of next week. I hope to maiden this a week from Sunday.
Let the fun begin
Click for fullsize
Hide Signatures
       Post #: 12
RE: Ultra Stick 25e Conversion - 11/10/2012 6:36 AM
ckreef
Status: offline
This is the back of the new fire wall.
Click for fullsize
< Message edited by ckreef -- 11/10/2012 6:40 AM >
Hide Signatures
       Post #: 13
RE: Ultra Stick 25e Conversion - 11/10/2012 6:37 AM
ckreef
Status: offline
Front of the new fire wall. Note 45 degree counter clockwise engine position.
Click for fullsize
< Message edited by ckreef -- 11/10/2012 6:41 AM >
Hide Signatures
       Post #: 14
RE: Ultra Stick 25e Conversion - 11/10/2012 6:40 AM
ckreef
Status: offline
Original fire wall prepped to accept new fire wall and epoxy.
Click for fullsize
< Message edited by ckreef -- 11/10/2012 6:42 AM >
Hide Signatures
       Post #: 15
RE: Ultra Stick 25e Conversion - 11/10/2012 6:43 AM
ckreef
Status: offline
Motor mount on new fire wall at a 45 degree angle.
Click for fullsize
Hide Signatures
       Post #: 16
RE: Ultra Stick 25e Conversion - 11/10/2012 6:45 AM
ckreef
Status: offline
Engine temp mounted to test fit.
Click for fullsize
Hide Signatures
       Post #: 17
RE: Ultra Stick 25e Conversion - 11/10/2012 7:37 AM
Kmot
Status: offline
Awesome!
~Tom~
Hide Signatures
       Post #: 18
RE: Ultra Stick 25e Conversion - 11/10/2012 10:52 PM
ckreef
Status: offline
Throttle servo and linkage installed and ready to go.
Click for fullsize
Hide Signatures
(in reply to Kmot)
       Post #: 19
RE: Ultra Stick 25e Conversion - 11/11/2012 6:38 AM
ckreef
Status: offline
I installed some very thin plywood strips (1 1/4" x 5 1/4" w/ corner knockout), into the side walls of the fuel tank area. I didn't do this for firewall bracing rather I accidently put an X-acto knife through the left side wall and so it needed some strengthening up - Shhhhhhh !!!!!!!!!! - don't tell anyone
Click for fullsize
Hide Signatures
       Post #: 20
RE: Ultra Stick 25e Conversion - 11/11/2012 6:41 AM
ckreef
Status: offline
Fuel tank installed and ready - It's a 200 cc tank just shy of 7 oz. if I did the math correctly. Should give me an easy 15 or 20 mins of flight time.
Click for fullsize
Hide Signatures
       Post #: 21
RE: Ultra Stick 25e Conversion - 11/11/2012 6:43 AM
ckreef
Status: offline
Charge jack/switch and Rx installed.
Click for fullsize
Hide Signatures
       Post #: 22
RE: Ultra Stick 25e Conversion - 11/11/2012 6:44 AM
ckreef
Status: offline
Engine bolted down and ready for the initial breakin.
Click for fullsize
Hide Signatures
       Post #: 23
RE: Ultra Stick 25e Conversion - 11/11/2012 6:45 AM
ckreef
Status: offline
Whats this - Powered by E-flite ???? - NOT
Click for fullsize
Hide Signatures
       Post #: 24
RE: Ultra Stick 25e Conversion - 11/11/2012 6:46 AM
ckreef
Status: offline
Powered by Thunder Tiger
Click for fullsize
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
