Does any company make a replacement electric retract for ESM    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Does any company make a replacement electric retract for ESM
Page: [1]
Login
Does any company make a replacement electric retract fo... - 11/1/2012 2:53 AM
splais
Score: 131
Last Login: 5/25/2013
Status: online
Does anyone know of a company that makes electric retracts that will replace the ESM 30cc size electric retracts? Please help. I just received my V3 retracts and two of the three gear are malfunctioning already. One has quit all together.. Ive a really nice plane that has been sitting for 6 months now and things are no better than the day it was finished back in May. Because of interior space I really am kind of restricted to electrics. Can anyone help?
Hide Signatures
       Post #: 1
RE: Does any company make a replacement electric retrac... - 11/1/2012 9:12 AM
damagedgoodes
Score: 100
Last Login: 5/24/2013
Status: offline
Splais,
I like you have been waiting a long time for the V3 retracts (I have V1 that work but I'm not trusting my airframe to retracts that take nearly a minute to operate) and still don't have them. I have a set of Electron retracts that will dop in place of the ESM ones but the mounting bolt pattern is a tad different (same width but 1mm shorter between the holes on the rails). That's a relatively easy fix. Trouble is they are expensive, but I guess expensive is a relative term when you weigh up the cost of the airframe and your time building it. I haven't fitted mine yet as I was waiting on seeing the V3's which should be in the country any day now and the Electron retracts can be used in another project but based on what's happened with yours I might as well fit them next week when I get the chance.
The Electron retracts are a work of art, very solidly built, and bench testing have been perfect every time. They are over engineered for the 30cc class of ESM planes but I look beyond what they are going into at the present. Choices are limited (90 or 100 degree rotation at the moment) but you can get them in 11mm trunion block so the ESM struts can be used. They run off a 1000mAh 2 cell Lipo. The model mine will go in is the P47. The dimension drawings are on Electron website so you can check depth in the wing first. www.electron-retracts.com and mine are the Er-40 which I ordered as the slower Powerful set for larger models down the track.
Hope this helps,
Dave
Hide Signatures
(in reply to splais)
       Post #: 2
RE: Does any company make a replacement electric retrac... - 11/1/2012 11:39 AM
JPate147
Score: 116
Last Login: 5/23/2013
Status: offline
You may want to speak with Down and locked, or Dreamworks. D&L will rebuild your existing retracts and Dreamworks has complete sets in three size.
Hide Signatures
(in reply to damagedgoodes)
       Post #: 3
RE: Does any company make a replacement electric retrac... - 11/1/2012 12:04 PM
VIRGINIA MODEL BUILDERS
Score: 105
Last Login: 4/7/2013
Status: offline
Can you please let me know exactly wich retract set you are refering to and the specifics of what has happened.
Click to see the file in new window.Attachment.pdf
_____________________________
VAMODELBUILDERS
http://vamodelbuilders.com/
Hide Signatures
       Post #: 4
RE: Does any company make a replacement electric retrac... - 11/1/2012 2:40 PM
splais
Score: 131
Status: online
VMB,
I just received three of the new V3 motors from TBM to replace the old V2's that had all three gear malfunction on two different sets. I ground tested them several times. From the get go for some reason the nose gear, every once in awhile would do nothing. I tried reseting the screw tension per Ashers memo and "right now" it seems to be working. One of the main gear motors is a mess and completly screwed up, started making all kinds of god aweful noise and now won't work (see link below of video I sent Asher last nght). Steve
http://flic.kr/p/dpHjG7
Hide Signatures
(in reply to VIRGINIA MODEL BUILDERS)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
