another revo issue....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> another revo issue....
Page: [1]
Login
another revo issue.... - 11/1/2012 6:00 PM
mopartybob
Score: 106
Last Login: 5/23/2013
Status: offline
recieved a roller (somewhat) lol, from a stranger than strange person, he had the rear center driveline disconnected and was runnin the front only... after scrounging the parts barrel, i found one and hooked it up... weird thing now,when the front wheels turn forward,the rear wheels turn backwards, and vice-versa..... no grinding or clicking from the diffs, but i'm sure one has to be bad... anyone else encountered this???/ Robert
_____________________________
.....If I had a plan,I''''''''''''''''d be screwed....
Hide Signatures
       Post #: 1
RE: another revo issue.... - 11/1/2012 6:26 PM
steed2-inactive
Score: 166
Last Login: 12/18/2012
Status: offline
sounds like the rear diff is in backwards. on a tmaxx they can be installed upside down causing exaclty what your experiencing. i Did nt think revo diff housing could be installed upside down but where theres a will (prybars, hammers, vicegrips) theres a way.
oversteer scares passengers, understeer scares drivers!-savagex,-savagexl,-savageflux,-revo3.3,-tmaxx3.3,-losi aftershock lt
Hide Signatures
(in reply to mopartybob)
       Post #: 2
RE: another revo issue.... - 11/1/2012 6:32 PM
mopartybob
Score: 106
Status: offline
quote:
ORIGINAL: steed2
LOL Thanks, I didn't think it could be installed any other way either, i'm pulling it apart now....will post wassup.... Robert
Hide Signatures
(in reply to steed2-inactive)
       Post #: 3
RE: another revo issue.... - 11/1/2012 8:39 PM
mopartybob
Score: 106
Status: offline
Well, I took 'er apart, no way could the diff be installed but the right way, installed NEW diff.,(other was a wasted), but does the same thing??? W@TF ?? anybody........... Robert
Hide Signatures
       Post #: 4
RE: another revo issue.... - 11/2/2012 12:38 AM
TheKennyKiller
Score: 462
Last Login: 1/23/2013
Status: offline
Front diff must be backwards. Make sure the word "up" on the diff case is facing up.
Do you even RC?
Hide Signatures
       Post #: 5
RE: another revo issue.... - 11/2/2012 2:41 AM
mopartybob
Score: 106
Status: offline
quote:
ORIGINAL: TheKennyKiller
Front diff must be backwards. Make sure the word ''up'' on the diff case is facing up.
I'm checking now,if this is true........then this guy was runnin in reverse,to go forward... or...........he was runnin in forward to drive in reverse..... or.......
Hide Signatures
(in reply to TheKennyKiller)
       Post #: 6
RE: another revo issue.... - 11/2/2012 9:21 AM
mopartybob
Score: 106
Status: offline
same results,new diff. dont know wats going here.........
Hide Signatures
       Post #: 7
RE: another revo issue.... - 11/2/2012 10:19 AM
thef@st1
Score: 115
Last Login: 4/22/2013
Status: offline
have you tried runnig it? sounds to me like something inside the trans maybe. id rip it open and make sure its together right.
Hide Signatures
       Post #: 8
RE: another revo issue.... - 11/2/2012 3:05 PM
mopartybob
Score: 106
Status: offline
at first i thought it was the trans, so i yanked it out,installed the forward-only conversion, same results....thought i did sumthin wrong,so i swapped the trans out of my other revo, SAME RESULTS.......... W@TF... the cryin shame is it's probably sumthin simple...or ??? thanks anyway,please guys, keep'em comin... robert
Hide Signatures
(in reply to thef@st1)
       Post #: 9
RE: another revo issue.... - 11/2/2012 5:02 PM
crispyspa
Score: 137
Status: offline
I don't have a Revo, but looking at the diff case, it does look like you can install it upsidedown.
When you look at the diff case, there is a "large side" into which the ring gear is placed. That large side should be opposite each other (front and rear) in relation to the the other one. The front should have it on the "passenger" or right side of the car and the rear should have it on the "driver" side or left side of the car.
Taking the transmission apart and converting it to forward only wouldn't have done anything because the output shaft is solid.....unless there is a center diff and the diff cup is being kept from rotating somehow, in which case the wheels wouldn't turn at all. If it has a center diff, there may be a broken diff gear or the diff case is separated from the ring gear, but you said you swapped out the trans.
Classic example of Occam's razor in which the line of reasoning that says the simplest answer is often correct.
Other than that, I got nuthin'. Let us know what you find out. This one is perplexing.
After all is said and done, more is said than done.
Hide Signatures
       Post #: 10
RE: another revo issue.... - 11/2/2012 7:34 PM
mopartybob
Score: 106
Status: offline
quote:
ORIGINAL: crispyspa
When you look at the diff case, there is a ''large side'' into which the ring gear is placed. That large side should be opposite each other (front and rear) in relation to the the other one. The front should have it on the ''passenger'' or right side of the car and the rear should have it on the ''driver'' side or left side of the car.
your on the money there buddy, it seems you CAN install it upside down..... I was'nt wearing my glasses when i did the rear,and found it WAS upside down! when i tried to fit it right side up,it would not line up,further inspection of the case (with my glasses on) revealed a burr on that ring gear indentation,it seems the joker before me installed a screw that was too long and it went into and thru the diff case... problem SOLVED dahmit, THANKS guys Robert
Hide Signatures
(in reply to crispyspa)
       Post #: 11
RE: another revo issue.... - 11/3/2012 5:15 AM
crispyspa
Score: 137
Status: offline
Glad you got it figured out. Now go have some fun.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.607RCU1
