RE: Lanier Slasher and Ripper?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> RE: Lanier Slasher and Ripper?
Page: <<   < prev  1 [2]
Login
RE: Lanier Slasher and Ripper? - 5/30/2007 10:52:45 PM
Lou Melancon
Status: offline
Hi Ted,
Kirk's right about the OS LA .25. You will a lot happier with an OS .25 FX. The mousse cans are available through Flying Z Hobbies in Kentucky. I believe their web site is www.flyingzhobbies.com .
You do want a flat battery pack for the wing of your Slasher. See ya later.
< Message edited by Lou Melancon -- 5/30/2007 10:53:38 PM >
_____________________________
Waco Brotherhood Member #110
(in reply to Montague)
       Post #: 26
RE: Lanier Slasher and Ripper? - 6/26/2007 4:14:38 PM
DrScoles
Status: offline
I had a slasher, now have two avengers.... I liken the slasher to a semi-truck, and the avenger to a ferrari...;-) If it was a competition to see who could take the most mid-airs.. I think the slasher would rock! Just kind of a blunt instrument. The avenger is slick.
Mike
www.mikescolesheli.com
(in reply to Lou Melancon)
       Post #: 27
RE: Lanier Slasher and Ripper? - 6/26/2007 5:02:44 PM
ArCeeFlyer
Status: offline
We have been having a blast doing sport combat with the Slashers at our club. We're running GMS .32's with the short version mousse can mufflers and turning a 9x6 prop at 16,000 -17,000 rpms on 30% nitro and even with one less head shim in some cases. By keeping the weight down to 3.5 lbs or less and the c.g. as far back as possible, this combination really makes them haul fast and turn fast without losing hardly any speed. I have done terminal velocity dives pulling up hard at the bottom and the plane just does a fast tight loop, although it's not too hard to get the tail feathers to flutter that way, . Ya, the wing flexes big time, but I can't snap it. We have found that mounting everything on the fuse leaves only one connection (ailerons) to the wing for easy attachment and removal and reduces wire damage from midairs. We mount the Rx on top or on the side of the fuse just in front of the vert. stab and so far of the many midairs we have had, no Rx has been touched. It seems to be a well protected area from midairs. And the battery is mounted in the back under the horz stab. With the bigger engine, the weight needs to be more aft.
Talk about low cost and high fun, they're both.
Edit: The guys after some fierce battling. Notice a couple of the Slashers are a bit crooked. Also, I have been making a nice refined short mousse can muffler for the guys. Adds about 1500 rpm to the GMS .32.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by ArCeeFlyer -- 6/26/2007 5:25:59 PM >
Alan - YARCC (www.yorkrc.com) Admin/Editor (Say What?!)
AMA 338508
       Post #: 28
RE: Lanier Slasher and Ripper? - 6/26/2007 5:19:46 PM
Montague
Status: offline
hey, if you're in York, PA, that's less than 2 hrs from my field in Laurel, MD. If you guys ever want to try RCCA rules combat, or hold a contest, it's an easy trip. You're welcome to come to a contest here, or I'll drive up there if I can.
Kirk Montague Adams
RCCA 560
(in reply to ArCeeFlyer)
       Post #: 29
RE: Lanier Slasher and Ripper? - 6/26/2007 5:31:47 PM
ArCeeFlyer
Status: offline
I know that would be fun. Although, with the sport setups we have been using, they wouldn't qualify under the rules. The trick would be to get all the Slasher guys in our club to put together some by the rules and also for everyone to have them all done and ready at the same time. Seems like there is always a couple out of commision from attrition. I'll bring the idea up to the group and see if they are up to it.
AMA 338508
       Post #: 30
RE: Lanier Slasher and Ripper? - 5/3/2008 8:50:17 PM
secret_squirrel
Status: offline
Just dusted my ripper. Anyone know where I can buy a HDPE fuse only for the ripper since lanier has gone out of business? I love my Ripper and want it back!!!!
Thanks in advance,
Dan
P.S. .... The thread that won't die.
       Post #: 31
RE: Lanier Slasher and Ripper? - 5/5/2008 4:47:14 PM
Montague
Status: offline
I don't know about buying a new one, but you can get HDPE and do a lot of the cutting yourself with a jigsaw or scroll saw and drill.
You can get HDPE at a number of places, including McMaster-Carr at www.mcmaster.com
Kirk Montague Adams
RCCA 560
(in reply to secret_squirrel)
       Post #: 32
RE: Lanier Slasher and Ripper? - 5/7/2008 1:26:26 AM
secret_squirrel
Status: offline
Thanks Montague.
I figured with a jigsaw, drill and a router I could get pretty darn close. Someone at my local field tried to talk me out of it. Said it would look terrible. I don't really care that it is perfect but is this stuff really that hard to work with? It was suggested that I use cabinet quality plywood. I am leaning towards the HDPE.
Dan
       Post #: 33
RE: Lanier Slasher and Ripper? - 5/7/2008 1:41:31 AM
secret_squirrel
Status: offline
Does anyone know if a Bandit HDPE Fuse (http://webpages.charter.net/mnemesh/kitparts.htm) will work with a Lanier Ripper Wing?
Thanks in advance for all the help,
Dan
       Post #: 34
RE: Lanier Slasher and Ripper? - 5/7/2008 12:05:54 PM
Capn America
Status: offline
Last time I was at our LHS there was a complete kit on the shelf there. Dont remember if it was Slasher or ripper but it might be good to check on it.
Phil's Hobby 419-782-8020 in Defiance ohio, I'm certain they would ship it, they e-bay stuff all the time.
       Post #: 35
Jump to:
Google
