Well this sucks    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Well this sucks
Page: [1]
Login
Well this sucks - 11/1/2012 11:31 PM
Zrock
Score: 101
Last Login: 5/24/2013
Status: offline
 Went out today to tweek my tuning had a little bit of a bog on a deat start. Got the thing perfectly tuned and after a few I noticed that it was not shifting into 3rd gear. Just figured the tank was getting low and might be leaning out a bit. About a mon later she ran out of fuel. Refuelled but could not get it to run properly. It kept staling if I gave it any throttle. Reset everything back to factory thinking something got out of adjustment when it rolled still would not run properly it would just stall or if I did get it rolling it would barly move sounded like it was getting way to much fuel. Gave up since its way to cold to be messing around with it. Figure something came loose gonna pull the engine and seal it all up hopefully its just a air leak.  This is on my savage xl
Hide Signatures
       Post #: 1
RE: Well this sucks - 11/2/2012 1:47 AM
Zrock
Score: 101
Status: offline
Exhast gasket is toast and broke the carb gasket trying to get it out to seal up.... Anyone have a pic of the inside of the pistion liner? I can see cross hatching on it but almost looks deeper than i think it should be
Hide Signatures
(in reply to Zrock)
       Post #: 2
RE: Well this sucks - 11/2/2012 4:39 AM
racingfan48
Score: 100
Last Login: 4/17/2013
Status: offline
ive had the same problem, mine was for different reasons though.  i noticed the mid range needle had backed out on mine so its turned in now.  Theres a tapper to the carb on the inside of the mid range that mine is set at now then reset all the needles from there.  seemed to work for the most part cause the truck would always stall after a wot pass and wouldnt shift into third either,  i did change the shift point though and that helped alot.  then i ran mine today and lost a bit of power and noticed the mid range had moved.  so reset that ran it and the clutch came loose and stripped the clutch gear apart, causing truck to flip and screw up the steering servo haha.  i feel your pain.  I am curious though, is your mid range needle set to the outside of the carb? cause i cant seem to figure out if you set it flush with the outside of the carb or flush with the tappered groove on the inside.  thanks!!
Hide Signatures
(in reply to Zrock)
       Post #: 3
RE: Well this sucks - 11/3/2012 3:28 PM
Zrock
Score: 101
Status: offline
 now this really sucks... parts may not be in for 2 weeks to a month... Decided to give my local hobby shop a chance at getting me parts...
Hide Signatures
(in reply to racingfan48)
       Post #: 4
RE: Well this sucks - 11/9/2012 3:11 AM
Zrock
Score: 101
Status: offline
i must be board waiting for parts... pulled the exhaust off and took my dremel and pollished it up... just like looking into a mirror now... also looking at a Tmax 2.5 that i found used local... his price is a bit high and for 100 more i could buy a new stampede.. need something for the GF to run... waiting to hear back how old and how much fuel... dont think the guy has a clue said it came complete with oil filter?
Hide Signatures
(in reply to Zrock)
       Post #: 5
RE: Well this sucks - 11/9/2012 5:00 AM
Zrock
Score: 101
Status: offline
Well now the owner of a tmax. Picked it up for a price I could not pass up. Owner said he had for 3 years but only run 1 tank of fuel. So I low balled him not thinking her would take it. So even if I have to toss a engine In it I'm still good
Hide Signatures
(in reply to Zrock)
       Post #: 6
RE: Well this sucks - 11/10/2012 4:15 AM
Zrock
Score: 101
Status: offline
lucked out... got the tmax and not even a scratch any ware on it mint condition... Engine was stuck at Top dead center so pulled the top off and gave it a little WD40 and stuck a hair dryer on it for about 15 min. Freed right up put some fuel in it primed and fired up first crank... let it idle for a bit but the temps got a little to high im hoping since it was just sitting in the shop idling on the bench.. ill take her out for a break in this weekend and see how it goes...
Hide Signatures
(in reply to Zrock)
       Post #: 7
RE: Well this sucks - 11/10/2012 5:17 AM
SyCo_VeNoM
Score: 626
Status: online
do not try to drive the t-maxx like a savage
they are fragile to high hell. Bulkheads are extremely notorious for breaking.
as for sealing the engine heres a good post on it from a guy who used to post here often, and was basically the savage guru (seriously I think he owned 17 of them) http://www.rcuniverse.com/forum/m_8761168/anchors_8763733/mpage_1/key_/anchor/tm.htm#8763733
_____________________________
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
(in reply to Zrock)
       Post #: 8
RE: Well this sucks - 11/10/2012 3:26 PM
Zrock
Score: 101
Status: offline
the Tmaxx is for the GF so hopefully she does not break it..hehe
thanks for the link
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 9
RE: Well this sucks - 11/23/2012 11:53 PM
Zrock
Score: 101
Status: offline
LHS pissed me off for the last time... 1 out of 4 parts came in.. the cycl and sleeve and then of charging me what they quoted me of $70 they charged me $90. when i tried to get a explanation i just got the run around so oi took the part and left. Got home and ordered the remainder of the parts i needed and they should be here next week. shot them a email telling them to cancel my orders as it is a little ridiculous to be waiting almost a month for parts and i still cannot get a eta of when they would be in and the pricing differences from what i was quoted. they even lost my fuel sales and i was going to buy a new rc from them but they lost all that as well...
on a good note i checked the piston and sleeve and the pinch is pretty much the same from the new and old so i really did not need that part.. in the pare box it goes
Hide Signatures
(in reply to Zrock)
       Post #: 10
RE: Well this sucks - 11/24/2012 5:03 PM
SyCo_VeNoM
Score: 626
Status: online
wow that is pretty bad for a hobby shop.
kinda why I buy my stuff online I KNOW when its coming not the check back in 3 days stuff just to pay a premium
Hide Signatures
(in reply to Zrock)
       Post #: 11
RE: Well this sucks - 12/6/2012 5:42 AM
Zrock
Score: 101
Status: offline
Finally got all the parts. What a pain replacing all the gaskets in the carb. Next time ill just order a new one. Figure I found 2 leaks in the midrange and high idle both gaskets just broke when I removed them they were so dry.  All put back togeather and seeled and I can get a run in tomorrow
Hide Signatures
       Post #: 12
RE: Well this sucks - 12/9/2012 8:40 AM
Borneoben
Score: 100
Last Login: 3/10/2013
Status: offline
Let us know if it solves your running problems
Cheers
Scratch Built Depron Biplane, Park Zone Extra 300, BlueSkyRC FPV Spider Quad with Naza+GPS
Savage XL
Hide Signatures
(in reply to Zrock)
       Post #: 13
RE: Well this sucks - 12/9/2012 5:33 PM
Zrock
Score: 101
Status: offline
Figures got a pile of snow over night... o well its going out anyway..hehe
And my collection keeps growing... got my 2 year old a Traxxas Rustler so she will leave mine alone... hehe
Hide Signatures
(in reply to Borneoben)
       Post #: 14
RE: Well this sucks - 12/9/2012 9:21 PM
Zrock
Score: 101
Status: offline
Runs way better than it ever did. Took about 5 cranks of the roto start and fired right up. Even when it would stall it would fire back up within a second. Was unable to tune as I could not get a good run in the snow and then the batterie in the truck started to go dead. Could not get steering or throttle unless I was within feet of it. Was nice to hear it run forgot how loud it was compared to the tmaxx
Hide Signatures
(in reply to Zrock)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.473RCU1
