stuck valve..saito 60 twin    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> stuck valve..saito 60 twin
Page: [1]
Login
stuck valve..saito 60 twin - 11/2/2012 5:47 PM
skypup50
Score: 100
Last Login: 12/13/2012
Status: offline
I tried running a saito 60 twin and discovered it has a stuck valve. Any ideas on how to free it up? Not sure about dissassembly. The rockers are held on with e clips. Can I just unbolt the affected cylinder without screwing things up? Thanks.
Hide Signatures
       Post #: 1
RE: stuck valve..saito 60 twin - 11/2/2012 8:54 PM
bigphil
Score: 100
Last Login: 5/9/2013
Status: offline
Yes you can pull just one cylinder but before you do, make sure the rocker is not stuck rather than the valve. You may not need to pull the cylinder. If it is indeed the valve you might get it freed up by giving it a shot of penetrating oil and excercising it a few times, that might also save a tear down. Make sure the pushrods are seated properly under the rockers too and not holding a valve open.
_____________________________
Big Phil
AMA 6762
Hide Signatures
(in reply to skypup50)
       Post #: 2
RE: stuck valve..saito 60 twin - 11/2/2012 9:18 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: bigphil
Thanks. Trying that with penetrating oil now.
Hide Signatures
(in reply to bigphil)
       Post #: 3
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> stuck valve..saito 60 twin
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.141RCU1
