BP oil question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mig 15 Global Jet Club with Jetcat p-80SE - RTF
Seller:  cessna172av
Details:   $5,000.00   |  5/4/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> BP oil question
Page: [1]
Login
BP oil question - 11/2/2012 10:23 PM
Dr Honda
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Guys,
I bought some Jet stuff from a guy, and he gave me a 5 gal jug of Kero. He said it had a quart of PB turbine oil in it. BUT... before I do anything with this fuel... I need to know... does the BP oil have a color?
I know the Shell 500 was amber.... but the DTE that I started using this year was clear.
_____________________________
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 1
RE: BP oil question - 11/2/2012 11:11 PM
Vincent
Score: 105
Status: offline
Yes it has an amber color to it. I have used BP, Mobil, Aeroshell, Exxon. The turbine oils all have some color to them.
Vin...
Hide Signatures
(in reply to Dr Honda)
       Post #: 2
RE: BP oil question - 11/2/2012 11:38 PM
Dr Honda
Score: 100
Status: offline
Thanks.
Tony
Hide Signatures
(in reply to Vincent)
       Post #: 3
RE: BP oil question - 11/3/2012 12:17 AM
gunradd
Score: 120
Status: offline
Exxon 2380 is pretty much clear(has a slight purple tint). I used to hate chasing oil leaks when the plane had that stuff. I know BP makes the same stuff but not sure if its the same color.
Loving my Kingtech Turbine!
Hide Signatures
       Post #: 4
RE: BP oil question - 11/3/2012 1:03 AM
invertmast
Score: 193
Status: offline
Bp is clear. You can barely see a purple tint through when poured straight out of the can.
If it was me and i wasnt 100% sure on the status of the fuel mix, i wouldnt chance it. Kero and oill is cheap compared to bearings
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to gunradd)
       Post #: 5
RE: BP oil question - 11/3/2012 1:20 AM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: invertmast
If it was me and i wasn't 100% sure on the status of the fuel mix, i wouldn't chance it. Kero and oil is cheap compared to bearings
Well................
That's what my thoughts were. BUT... I don't want to burn it in my shop heater if it has something that will be toxic either. I wish I still had my Diesel truck. I'd just pour it in the tank. (lol)
So the question is... what to do with it??
Tony
Hide Signatures
(in reply to invertmast)
       Post #: 6
RE: BP oil question - 11/3/2012 2:13 AM
FenderBean
Score: 119
Status: offline
BP is a clear with a slight blue shine, if that makes since
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 7
RE: BP oil question - 11/3/2012 3:08 AM
gunradd
Score: 120
Status: offline
Well....
I used some left over jet fuel for weed killer. It works great. The EPA probably wont like that much but heck I have seen some old hawkers leak more fuel just sitting over night on the ramp then I poured along a fence to kill weeds.
Hide Signatures
(in reply to FenderBean)
       Post #: 8
RE: BP oil question - 11/3/2012 3:25 AM
Kenrico
Score: 100
Status: offline
BP Oil turns amber when exposed to the sun.
Hide Signatures
       Post #: 9
RE: BP oil question - 11/3/2012 4:45 AM
JackD
Score: 100
Status: offline
It is very easy... pour a little on a clear glass container and see the sun through it. It should look "oily" (some colors). Compare to a straight kero sample and you will see the difference. and even if the oil is clear, if you leave it in the sun for a few hours it will turn brownish
if you are still uncomfortable, just add another can of oil. It won't hurt the engine
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
       Post #: 10
RE: BP oil question - 11/3/2012 5:34 AM
Eddie P
Score: 120
Status: offline
I know this has been beaten to death elsewhere as far as mixing your own (or so I recall) but can you make smoke oil out of "suspect" or old kerosene? Not so much of a "show smoke" but as practice smoke for any given Sunday... I think you could add some baby oil or vegetable oil to decrease the flammability and increase the flash point a bit and you'd have the value of your kero back in your pocket compared to what smoke oil costs. Just one possible other use for the stuff.
Hide Signatures
(in reply to JackD)
       Post #: 11
RE: BP oil question - 11/3/2012 1:32 PM
brenthampton79
Score: 105
Last Login: 5/17/2013
Status: offline
Bp 2380 is clear. I've probably poured 4-5 cases worth over the past 4-5 years and it's always been clear. We buy it by the case for our spray planes.
N802KC AT-802A Work
N66EC Pitts S1-S Fun!!
Hide Signatures
(in reply to Eddie P)
       Post #: 12
RE: BP oil question - 11/3/2012 2:04 PM
Vincent
Score: 105
Status: offline
quote:
ORIGINAL: brenthampton79
All of the turbine oils look clear when you are pouring them from the can. Assuming you are running the clear kero, take a sample of the " mixed" kero and put it in a glass jar then compare it with "non" mixed clear kero. There will be a distinct color difference between the two.
Vin...
Hide Signatures
(in reply to brenthampton79)
       Post #: 13
RE: BP oil question - 11/3/2012 7:48 PM
rgburrill
Score: 126
Status: offline
I am curious why you don't believe the guy.  Is there something you are not saying?
Hide Signatures
       Post #: 14
RE: BP oil question - 11/3/2012 9:11 PM
brenthampton79
Score: 105
Status: offline
Uhhh ok maybe it mixes to a different color I thought the question was if it's clear or not.
Plus if you don't know don't use it! Fuel and oil is cheap. I don't have an RC turbine so I'm not a expert or even a noob.
N802KC AT-802A Work
Hide Signatures
(in reply to rgburrill)
       Post #: 15
RE: BP oil question - 11/4/2012 1:01 AM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: rgburrill
Nope... not at all. He was a nice guy, and there isn't a reason to not believe him. But... I know I've questioned myself a bunch of times... and I just don't want to loose a turbine by trying to salvage $20 worth of fuel. And... as above, if there is oil in it... I don't want to poison myself by using it in a shop heater.
Now... if it's like AeroShell 500... it's very dark, and it's easy to tell if the oil is in it.
Tony
Hide Signatures
       Post #: 16
RE: BP oil question - 11/4/2012 1:04 AM
Greg Wright
Score: 102
Status: offline
Aero shell oil has no color to it. Mobil oil does though.
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
       Post #: 17
RE: BP oil question - 11/4/2012 1:18 AM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: Greg Wright
Really? I've only used a few cans before switching to DTE... but mine were all very dark. (like new car motor oil)
Tony
Hide Signatures
(in reply to Greg Wright)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
