Groove worn in tires?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> Groove worn in tires? Page: [1]
Login
Groove worn in tires? - 11/3/2012 1:58 AM
t-max97
Score: 168
Last Login: 5/19/2013
Status: online
On my rs4 all 4 tires but mostly the back have a groove worn on the inside edge, I thought maybe the body rubbed them some but it overlaps the tires so i dont know what it is, has this happened to anyone else? one of them actually wore thew the tire and they're pretty new.
_____________________________
If you dont know what your doing, its best to do it quickly.
Hide Signatures
       Post #: 1
RE: Groove worn in tires? - 11/3/2012 2:05 AM
FahrtAutoRC
Score: 409
Last Login: 5/17/2013
Status: offline
Do you have a pic of the damage, by chance? I would check first and make sure that there is nothing else rubbing besides just the body. Might even be a case of something not assembled correctly and rubbing only when you trun, so compress the suspension in various way while you inspect it to see if anything hits near the bottom of the stroke. If it is actually a flat spot instead of a groove, then I would say you are running too much camber, but it is hard to tell with no pics.
The Midnight Chef
Hide Signatures
(in reply to t-max97)
       Post #: 2
RE: Groove worn in tires? - 11/3/2012 2:24 AM
t-max97
Score: 168
Status: online
Here's a picture. I cant figure it out.....
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to FahrtAutoRC)
       Post #: 3
RE: Groove worn in tires? - 11/3/2012 2:49 AM
phmaximus
Score: 627
Status: offline
Could that be too much camber, there does not look like much wear in the middle of the tyre.
With out seeing more pics...
It looks like u are running very very excessive camber and have worn out the tyre to the point that it's collapsed onto the sidewall. And is sagging because the rubber is so thin compared to the sidewall.
Also what tyre foam are u running?
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
       Post #: 4
RE: Groove worn in tires? - 11/3/2012 2:53 AM
t-max97
Score: 168
Status: online
quote:
ORIGINAL: phmaximus
Its all stock including the camber setting.
Hide Signatures
(in reply to phmaximus)
       Post #: 5
RE: Groove worn in tires? - 11/3/2012 2:58 AM
phmaximus
Score: 627
Status: offline
I've seen this happen before... Not saying u are doing this ok, this is just for other guys to think about
sometimes u can get this from having a high grip racing setup, then bashing it on concrete.
Because the setup has lots of camber to hold traction around fast bends, when it's going straight and the back is down from hard acceleration, if there is wheel spin, it wears out tyres just like in that pic.
I would recomend re checking ur camber and really look at the car during the bends, how much is it leaning over?
And would definatly play around with the top suspension arm mount points. What holes are u running ATM
Hide Signatures
       Post #: 6
RE: Groove worn in tires? - 11/3/2012 2:59 AM
phmaximus
Score: 627
Status: offline
quote:
ORIGINAL: t-max97
quote:
ORIGINAL: phmaximus
Hmmm, I don't think they set the camber from factory correctly, but that's ok, u can work from that
Hide Signatures
       Post #: 7
RE: Groove worn in tires? - 11/3/2012 3:06 AM
t-max97
Score: 168
Status: online
As soon as I fix my clutch i will, There are two holes to use and its on the top one on the front and rear towards the chassis. and the bottom one on the right at the tires in the rear and and the ones closest to the tires in the front. If you understood that haha. I was doing alot of high speed turns and sliding around lol.
Hide Signatures
       Post #: 8
RE: Groove worn in tires? - 11/3/2012 10:17 AM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: phmaximus
I had a tyre wear like that also. Negative camber was not excessive.
I think the tyre wears so thin that when driving it balloons even more in the thin area than the rest of the tread ....causing even more wear...in the end my tyre ripped leaving 2 seperate parts.
I guess the rubber is thicker in the middle than it is at the sidewall junction.
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
       Post #: 9
RE: Groove worn in tires? - 11/3/2012 11:24 AM
phmaximus
Score: 627
Status: offline
One would think if it was due to tyre ballooning wouldent the wear mark be more towards the centre near where the tyre would ballon the most?
Yes I agree that it's going to lead to sepperation of the tyre, but I don't agree that it's from the tyre ballooning
IMO looks like there is to much camber for his driving style
If the driver was easy on the corners but was getting wheel spin out f he corners and down the straights he might be better running about. 0.5deg camber on the rear, but by the looks of hat pic thats has go to be near 3 deg?
Hide Signatures
(in reply to Anthoop)
       Post #: 10
RE: Groove worn in tires? - 11/3/2012 2:42 PM
t-max97
Score: 168
Status: online
quote:
ORIGINAL: phmaximus
How do you tell how degrees its at?
Hide Signatures
       Post #: 11
RE: Groove worn in tires? - 11/3/2012 4:22 PM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: phmaximus
I am only guessing at what happened with my tyre, I had around -1 deg of camber. I still have the tyre from the other side that has worn in a similar fashion and I can feel the rubber is thinner at the edge than in the middle (picture below)
quote:
ORIGINAL: t-max97
There are many different tools to measure camber, you could get a rough idea with just a protractor, I have one of the set up stations (picture below).
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Groove worn in tires? - 11/3/2012 9:41 PM
9five9
Score: 137
Last Login: 5/10/2013
Status: offline
I've had one vehicle come from the factory with the nastiest camber - to the point where I thought it was broken. You can't always trust factory settings.
Thinking outside the box of traditional RC
Hide Signatures
       Post #: 13
RE: Groove worn in tires? - 11/4/2012 1:12 AM
t-max97
Score: 168
Status: online
I adjusted the camber so theres not as much now, I need one of those set-up stations lol. Ive only ever had off-road trucks and stuff like this wasnt as critical so i didnt know where to set it.
Hide Signatures
(in reply to 9five9)
       Post #: 14
RE: Groove worn in tires? - 11/4/2012 1:14 AM
phmaximus
Score: 627
Status: offline
dont worry about a setup station they are sooo expensive... get one of these
RPM camber gauge, they do a tow gauge to... oh they are about $9-
Hide Signatures
       Post #: 15
RE: Groove worn in tires? - 11/4/2012 1:16 AM
t-max97
Score: 168
Status: online
quote:
ORIGINAL: phmaximus
Awesome ill get one sometime.
Hide Signatures
       Post #: 16
RE: Groove worn in tires? - 11/4/2012 1:19 AM
phmaximus
Score: 627
Status: offline
Before I had one I use to use my drivers licence and mesure the top gap, that way i could get both sides the same.
what I did was watched the car for how much it leaned over on the track, then i would simulate that on a bench by hand & set the camber so the wheel was upright and level, and doubble check it by checking the tyre ware
Hide Signatures
       Post #: 17
RE: Groove worn in tires? - 11/6/2012 1:09 PM
Gilchrist111
Score: 100
Last Login: 11/14/2012
Status: offline
Large steel checkpoint and the rubberized rim is not only dressed in out very quick on the tangible but it is dressed in a pattern in the concrete..i think its Tyre lineament problem in the Tyre...whats your opinion?
< Message edited by i8tweety -- 1/14/2013 4:26 PM >
Hide Signatures
       Post #: 18
RE: Groove worn in tires? - 11/6/2012 8:17 PM
FahrtAutoRC
Score: 409
Status: offline
English would make this easier to understand, in my opinion.
quote:
ORIGINAL: Gilchrist111
The Midnight Chef
Hide Signatures
(in reply to Gilchrist111)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
