RE: help on balancing low wing planes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> RE: help on balancing low wing planes
Page: <<   < prev  1 2 [3]
Login
RE: help on balancing low wing planes - 11/5/2012 10:50 PM
da Rock
Score: 265
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Bozarth
da Rock (I still don't know your real name),
I applaud your diligence. But it falls under the TLAR method if you apply science to part of the equation, and experience to the other. Specifically, how are you determining what the coefficient of lift is for your wing and tail? Or the wing's pitching moment coefficient? My guess is you are estimating. Which then leads to an estimated SM, which then leads to an estimated desired CG location. Which I would bet, falls somewhere between 25 to 35% of the MAC.
How do you learn of these coefficients for ARFs? I bet you estimate based on your experience. And I bet you know how it should feel when you fly it. And I bet you recognize there is a trade-off between maneuverability and stability, etc.
There is no ''correct'' cg provided it is within the static margin.
Measuring a cg location to the nearest 1/16'' means nothing. How do you like how the plane flies?
Measuring the cg to the nearest nth degree is like measuring how much hair the barber cut off.
Kurt
Sorry, Bozarth, but the important details pertaining to pitch stability imparted by the CG are really pretty simple. They're the wing chord, wing area, tail area and tail moment. None of the things you list affect static margin. It's pretty easy to see what does. Take a look at the list of inputs any of the online applications ask for so they can provide information as to where your model would need the CG to be for the SM you wish. A good one to look at would be http://www.geistware.com/rcmodeling/cg_super_calc.htm
_____________________________
Good flying wit ya today
Hide Signatures
(in reply to Bozarth)
       Post #: 51
RE: help on balancing low wing planes - 11/5/2012 11:08 PM
Bozarth
Score: 156
Status: offline
We can't see the equation being used in the model. Coefficient of lift is normally one of the considerations. I bet they are set at an estimated value.
Kurt
Hide Signatures
(in reply to da Rock)
       Post #: 52
RE: help on balancing low wing planes - 11/5/2012 11:16 PM
Rafael23cc
Score: 122
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: da Rock
The written word is about the worst communications us humans flog each other with.
What at least one of the most ''opinionated people'' has for motives is to provide enough detail that every beginner who comes through this swamp doesn't leave with just wet feet.
The point is for everyone to have a chance to understand most of this isn't an individual's opinion, and to understand how to find the mfg's suggested CG location with sufficient accuracy.
I _may_ understand your motives. The questions is, was it really necessary? The questions asked was simple and the answers would have been simple enough for anybody to understand. Now we are going into MAC and other parameters that would glaze over a newbie's eyes.
All the OP wanted to know is why the airplane needed to be balanced up-side-down, and if the nose needed to point up or down. The techniques and aeronautical terms could have been left out. Now it is really confusing for anybody trying to read thru this mess.
Rafael
Keep your eyes on the sky but your feet on the ground!
Team Heliproz.com / AMA # 8109
Hide Signatures
       Post #: 53
RE: help on balancing low wing planes - 11/5/2012 11:27 PM
Bozarth
Score: 156
Status: offline
quote:
ORIGINAL: Rafael23cc
quote:
ORIGINAL: da Rock
Rafael
Party pooper........oh, wait. Go Chiefs.
Hide Signatures
(in reply to Rafael23cc)
       Post #: 54
RE: help on balancing low wing planes - 11/6/2012 12:11 AM
retransit
Score: 125
Status: online
"All the OP wanted to know is why the airplane needed to be balanced up-side-down, and if the nose needed to point up or down. The techniques and aeronautical terms could have been left out. Now it is really confusing for anybody trying to read thru this mess.
Rafael"
If the OP's eyes glaze over at this point (25 years operating and building acccording to his profile) he needs cataract surgery. He isn't a newbie and newbies can benefit from the exchange of ideas.
Bob
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
       Post #: 55
RE: help on balancing low wing planes - 11/6/2012 12:23 AM
55alive1953
Score: 100
Last Login: 11/6/2012
Status: offline
If you want your planes to fly level then you must balance and c.g. them level.
      Ted
Hide Signatures
(in reply to retransit)
       Post #: 56
RE: help on balancing low wing planes - 11/6/2012 11:34 PM
Rafael23cc
Score: 122
Status: offline
quote:
ORIGINAL: retransit
''All the OP wanted to know is why the airplane needed to be balanced up-side-down, and if the nose needed to point up or down. The techniques and aeronautical terms could have been left out. Now it is really confusing for anybody trying to read thru this mess.
Rafael''
Bob
You'd be horribly surprised with some of people I have encountered in the 20+ years of me being in this hobby. They are quite content with what they know, and could care less about the rest.
quote:
ORIGINAL: Bozarth
I spend my time at the field or learning about my hobby, not watching grown men running around.
Rafael
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 57
RE: help on balancing low wing planes - 11/6/2012 11:54 PM
Bozarth
Score: 156
Status: offline
We all bow down!
Kurt
Hide Signatures
       Post #: 58
RE: help on balancing low wing planes - 11/7/2012 3:36 PM
retransit
Score: 125
Status: online
quote:
ORIGINAL: retransit
Rafael''
Bob
quote:
ORIGINAL: Bozarth
Rafael
I can't be surprised anymore. I'll give you some examples.
After informing a fellow flier about the care and feeding of Rx batteries on several occasions, he subsequently goes and flies and has a fly away. Dollars to doughnuts, the battery gave up the farm. I can't prove it because the plane is lost somewhere. On another occasion another flier was heard to say on a video that his batteries were at minimal voltage and that was good enough. After having his throttle stuck full open, he proceeds to fly around using up his batteries by performing maneuvers until he runs out of fuel. The batteries won that race. The result was a full bore lawn dart into the the earth. Another flier crashes when his plane is obviously tail heavy, fails to recognize the symptoms and continues to keep the aircraft aloft until he can no longer sustain any kind of control.
Fifty-five years in the hobby and no, I can't be surprised anymore. Talking to these people is fruitless.
Bob
Club Saito #800
Hide Signatures
       Post #: 59
RE: help on balancing low wing planes - 11/7/2012 5:48 PM
OldRookie
Score: 115
Status: offline
retransit,
You are starting to sound like Tired Old Man.
You know everything, and can't tolerate the ignorance of your peer group.
Greg
< Message edited by OldRookie -- 11/7/2012 6:52 PM >
You really only own what you can carry at a full out run.
Hide Signatures
       Post #: 60
RE: help on balancing low wing planes - 11/7/2012 10:25 PM
Rafael23cc
Score: 122
Status: offline
quote:
ORIGINAL: OldRookie
retransit,
Greg
Don't confuse ignorance with stupidity. Ignorance stops when advise is given. Stupidity follows.
Rafael
Hide Signatures
(in reply to OldRookie)
       Post #: 61
RE: help on balancing low wing planes - 11/7/2012 10:50 PM
OldRookie
Score: 115
Status: offline
I never mentioned stupidity. Don't add things I didn't mention.
My original observation of your comments on this post still reflect your personality.
Still standing by my original comment.
Just saying...Ha.
Greg
Hide Signatures
       Post #: 62
RE: help on balancing low wing planes - 11/8/2012 2:11 AM
retransit
Score: 125
Status: online
quote:
ORIGINAL: OldRookie
retransit,
Greg
To the contrary, I do not know everything and will be the first to admit it.
I can stand the ignorance. We learn from other's experience and knowlege, and that includes me as the student. What I cannot tolerate is a mind set where a bit of attention to detail will defuse a bad situation concerning a fundamental safety issue. If you want to crash your plane due to unsafe practices, go ahead, but don't do it with others around and in a setting that can have a detrimental effect on those people.
Bob
Club Saito #800
Hide Signatures
       Post #: 63
RE: help on balancing low wing planes - 11/8/2012 2:42 PM
Rafael23cc
Score: 122
Status: offline
quote:
ORIGINAL: OldRookie
I never mentioned stupidity. Don't add things I didn't mention.....
Greg
Missed the point completely....
Have a good day.
Rafael
Hide Signatures
       Post #: 64
RE: help on balancing low wing planes - 11/8/2012 3:04 PM
retransit
Score: 125
Status: online
Agreed.
Bob
Club Saito #800
Hide Signatures
       Post #: 65
RE: help on balancing low wing planes - 11/9/2012 4:51 PM
jaka
Score: 158
Last Login: 5/21/2013
Status: online
Hi!
Long fingers???
What do mean? Just hold the fingers under the wing at the supposed C of G What could be more difficult?
If the plane sits okay go out and fly it! If it doesn't behave good...change the C of G (Move servos and batteries )and go out and fly again. Repeat this process untill you are satiesfied with the flight caracteristics.
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 66
RE: help on balancing low wing planes - 11/9/2012 9:28 PM
retransit
Score: 125
Status: online
My answer to that is, get it right the first time and you won't have to move components. Even if you do, it can be limited to a battery pack, which is easy to do. Servos require changing mounting location and pushrods if you want to fly to confirm your CG choice.
I've said it before, but it bears repeating. It is difficult to hold a 23lb. plane with two fingers, especially if it is covered with fabric. I wouldn't want to place that concentrated force on the fabric. That is why I use the hook, cord and plumb bob. By using a balancing device, no matter what it is, you can move components while on the balancer.
Bob
Club Saito #800
Hide Signatures
(in reply to jaka)
       Post #: 67
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
