school me on the tamiya hilux    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> school me on the tamiya hilux
Page: [1]
Login
school me on the tamiya hilux - 11/4/2012 2:19 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: offline
Ive seen them, seen vids, but never expected to own one. Just to expensive for me.
Well, I found this chassis on ebay and got it for $75.
I know it has a 3 speed trans, manual locking hubs and such.
Im not sure how to run the 3 speed off a radio. Am I right in thinking I need a 3ch radio with a 3 position switch?
Also, how do the tires mount to the axle? The seller said the tires are not in great shape, so I may need to fine aftermarket ones.
I dont think ill be restoring it to original. I know a hilux body is pricey. But I may install typical electronics and a lexan body and drive it some. Or I may just sell it, not sure.
I dont know if an original hilux chassis like mine is worth alot. But I figure its worth at least what I paid.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 1
RE: school me on the tamiya hilux - 11/4/2012 3:11 AM
TWERPA
Score: 105
Status: offline
I do think that you need a 4ch tx for the gears..
Goose
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 2
RE: school me on the tamiya hilux - 11/4/2012 1:57 PM
Score: 296
Status: offline
quote:
ORIGINAL: TWERPA
really?
I figured the motor controlled reverse. The only reason I can think you would need a 4th channel is if the reverse was a function of the trans...thus requring another servo.
Ive seen the radio in the vintage commocial.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to TWERPA)
       Post #: 3
RE: school me on the tamiya hilux - 11/4/2012 7:18 PM
zman5000
Score: 102
Last Login: 2/6/2013
Status: offline
even the new models of that chassis use a 4 channel radio  been that way from the start. get a owners manual from tamiya you'll understand
Hide Signatures
       Post #: 4
RE: school me on the tamiya hilux - 11/5/2012 12:24 AM
Score: 296
Status: offline
quote:
ORIGINAL: zman5000
cant seem to find the original manual online.
But according to the tower hobbies site info on the Highlift hilux, it does say 4ch radio but it only says 2 servos are needed. take 2 servos and 1 esc and you get 3ch. I think the 4th channel is only for acc.
I think I can just take a standard 4ch plane radio and make a plate for the left stick to match the one in the pic I posted eariler. The plate just keeps you in a gear (on the rudder stick) and lets you go forward/reverse in each gear. Then the right stick is jsut steering. Pretty sure thats how its setup.
Hide Signatures
(in reply to zman5000)
       Post #: 5
RE: school me on the tamiya hilux - 11/5/2012 7:12 AM
ReaperGN
Score: 108
Last Login: 5/23/2013
Status: offline
First off which Hilux? There is the original that was basically a Bruiser and the new one that is the same as a F-350 High Lift. There is a big difference in how they operate. The old one prefers a swash plate for the controls but the new one needs to be open to use the trans to its fullest.
Oderint Dum Metuant
Hide Signatures
       Post #: 6
RE: school me on the tamiya hilux - 11/5/2012 1:54 PM
The Mad Modder
Score: 341
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
quote:
ORIGINAL: zman5000
I'm pretty sure only modern Tamiya 3 speeds use a 4th channel. It's for controlling the multi function unit, which adds lights, sound and engine vibration.
The manual recommends a 4 channel, but I don't know what the 4th channel is used for.
God bless America
Hide Signatures
       Post #: 7
RE: school me on the tamiya hilux - 11/5/2012 4:24 PM
Score: 296
Status: offline
yeh, what I got is the original toyota hilux chassis.
And based on the manual mad modder helped me find, its only requires 3ch.
I think the reason 4ch is reccomended is that most "stick" radios are 4ch.
Hide Signatures
(in reply to The Mad Modder)
       Post #: 8
RE: school me on the tamiya hilux - 11/6/2012 12:04 AM
ReaperGN
Score: 108
Status: offline
Then its the same as the Bruiser. Reason for the dual stick remote has nothing to do with the channels. The Tamiya 3 speed has the ability to shift on the fly. Trying to do this with a 3 position switch on a pistol grip is a royal pain in the rear. So if your a man and not a boy you will use a dual stick radio. Also its not a SCX-10 or crawler. Its a proper scale truck so you shouldn't expect it to go everywhere.
https://www.tamiyausa.com/product/item.php?product-id=58519
Oderint Dum Metuant
Hide Signatures
       Post #: 9
RE: school me on the tamiya hilux - 11/6/2012 12:43 AM
Score: 296
Status: offline
quote:
ORIGINAL: ReaperGN
now, it says shift on the fly....but the panel on the left stick makes you return the throttle to nuetral in order to shift between gears...does it not?
I dont see why a 3p switch wouldnt do the same.
I know its a proper truck. The leaf spring suspension is the only thing that would keep it from doing what a SCX can tho. It just has more realistic suspension travel.
Hide Signatures
(in reply to ReaperGN)
       Post #: 10
RE: school me on the tamiya hilux - 11/6/2012 1:51 AM
ReaperGN
Score: 108
Status: offline
You dont need to use the swash plate. It limits what you can do a bit but stops your buddy from trying to destroy your rather complicated transmission. As to the 3 position switch it does work. But the end points need to be perfect. And if used on a pistol grip you have to let go of the steering wheel so you may as well stop first. I tried the swash plate and threw that in the trash. I thought about a pistol grip with a 3 position switch but then remembered I wanted independent 4WS so that idea joined the swash plate. Your best bet is a dual stick controller with no swash plate and self centering sticks. Takes a bit to get used to but no other setup is better for the Tamiya 3 Speed.
Oderint Dum Metuant
Hide Signatures
       Post #: 11
RE: school me on the tamiya hilux - 11/6/2012 1:59 AM
Score: 296
Status: offline
quote:
ORIGINAL: ReaperGN
ah, I see.
I was thinking of having the 3p switch on a TQ3 where the stock 2p switch used to be. With that setup, you wouldnt have to take your hand off the steering wheel or throttle to switch gears.
but I see what you mean by having the end points perfect. That could be a bit tricky....
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
