RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of Pics!*    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of Pics!*
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/22/2012 8:03 PM
Canadian Man
Score: 100
Last Login: 6/19/2013
Status: offline
Not happy with the bulging saddle tank when filling. Because I have the saddle tank fill first, once it's full and the main tank starts filling the inside curve of the saddle tank will pop out.
So remove paint and aluminum tape. And Hysol carbon strips to stiffen tank.
I could have switched fuel tank order but I want the front tank to drain first.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Canadian Man)
       Post #: 126
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/23/2012 6:15 PM
Canadian Man
Score: 100
Status: offline
Here is another start and run video on diesel. I have included ecu settings as well.
Hide Signatures
       Post #: 127
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/24/2012 3:11 PM
Canadian Man
Score: 100
Status: offline
Well, plugging away at the cockpit. Made seat from balsa.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 128
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/24/2012 3:13 PM
Canadian Man
Score: 100
Status: offline
After a bit of shaping on the profile of the seat. Used exacto blades and mini planes.
Next will be with sand paper and dremel.
Click for fullsize
Hide Signatures
       Post #: 129
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/24/2012 4:04 PM
looping-74
Score: 100
Last Login: 5/9/2013
Status: offline
Hi,
What is your problem with the rear tank ? If this one tends to flatten it's on the external face not the internal one !
Take care of the rear tank is very close to the turbine and aluminium tape is not sufficient for a long time......on mine i used some ceramic BVM peint and now there is no problem (white paint).
Click for fullsize
Hide Signatures
       Post #: 130
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/24/2012 4:24 PM
Canadian Man
Score: 100
Status: offline
The problem with the rear tank is the inside curve, closest to turbine bulges out.
This doesn't happen when filling rear tank. Once rear tank is full and front tank starts to fill, then the rear tank starts to bulge.
These braces have helped but it still bulges. I will have to slow fill rate.
The rear of the tank has ceramic blanket under the tape. The rest of the tank is just aluminum tape. The previous 2 owners of this jet have run it like this without issue. I will keep an eye on it though.
On yours, do you fill rear tank first or front tank?
Hide Signatures
(in reply to looping-74)
       Post #: 131
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/24/2012 4:43 PM
looping-74
Score: 100
Status: offline
You need to fill the tanks from the front one so no problem but when draining too fast against the tanks the external part of the rear one deforms so I used a variable speed pump (i used a very high speed pump 3 liters/mn).
Hide Signatures
       Post #: 132
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/27/2012 10:28 PM
Canadian Man
Score: 100
Status: offline
Got a light kit for Christmas so time to take it all apart again
Started working on wing tip lights. Cut off the existing bump. Made the clear piece from 1/4" acrylic. Drilled hole to insert LED. It's a neat effect because the light makes the entire piece glow. I think I will back the piece of acrylic with aliminum.
Sorry pics not working right now
Hide Signatures
       Post #: 133
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/30/2012 5:57 PM
Canadian Man
Score: 100
Status: offline
Here is an overview video with my Airpower light kit installed.
Link to video
< Message edited by Canadian Man -- 1/14/2013 5:18 AM >
Hide Signatures
       Post #: 134
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 12/30/2012 6:26 PM
hooker53
Score: 100
Status: offline
Looking very good. Can't wait for the maiden video. Thanks.
_____________________________
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
       Post #: 135
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 2:53 AM
Canadian Man
Score: 100
Status: offline
Back from vacation and wrapped up light install. These three pics are of the plug for the light on the engine hatch. It's a deans mini plug.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to hooker53)
       Post #: 136
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 2:56 AM
Canadian Man
Score: 100
Status: offline
Shot of the light system switch on the main panel so I won't have to remove cockpit for start ups.
Pic of the light controller on the main board.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 137
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 2:59 AM
Canadian Man
Score: 100
Status: offline
Close ups of the acrylic led covers/reflectors on rudder and top of engine hatch. In the video the top of engine hatch was installed but rudder was not.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 138
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 4:14 AM
Pepperpete
Score: 100
Last Login: 6/18/2013
Status: offline
I don't know if it's my browser (Firefox) or what but I can't see the videos. There is just a big white space where the video should be...
Hide Signatures
       Post #: 139
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 5:19 AM
Canadian Man
Score: 100
Status: offline
quote:
ORIGINAL: Pepperpete
Hey pepperpete. I had that same issue a few weeks ago. I posted a link to video above for you.
Cheers
Hide Signatures
(in reply to Pepperpete)
       Post #: 140
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 4:09 PM
Pepperpete
Score: 100
Status: offline
Ah perfect thanks! Have you ever used the http://www.braincube-aero.com/ lighting systems? I just installed a set in my F-16 and I'm shocked at how bright they are. It's a bit mind blowing. The price is downright cheap for what you get but the components seem first rate. I took her out into direct sunlight and lights were 100 percent visible.
Please keep posting all of your info. This thread is a highlight!
Hide Signatures
       Post #: 141
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 1/14/2013 4:41 PM
Canadian Man
Score: 100
Status: offline
Hey Pepper.
Thanks for the positive comments!
This is the first lighting system I have used/installed. I will take a look at the one you posted for my next project though! Looks slick.
Hide Signatures
       Post #: 142
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 3/20/2013 3:04 AM
Canadian Man
Score: 100
Status: offline
Finished assembling my friends f18. Back to the euro. Patiently waiting to maiden.
I weighed it today. 34 lbs with fuel in UAT and no fuel.
I have a pilot in the mail from UK.
Will get back on working on cockpit.
Hide Signatures
       Post #: 143
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 12:15 PM
Canadian Man
Score: 100
Status: offline
Pic of the finished seat. I won't add any more detail as pilot will cover it if I can ever find a pilot that will fit
Click for fullsize
Hide Signatures
       Post #: 144
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 12:17 PM
Canadian Man
Score: 100
Status: offline
Out 2 weekend ago in the very cold weather. Three of us doing some taxi runs with all the new jets waiting for their maiden voyage
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 145
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 1:11 PM
Canadian Man
Score: 100
Status: offline
Cockpit installed
Click for fullsize
Hide Signatures
       Post #: 146
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 1:55 PM
looping-74
Score: 100
Status: offline
I used this one:
http://www.ebay.fr/itm/RAF-RC-FIGHTER-JET-PILOT-SCALE-1-8-1-7-FOR-GAS-TURBINE-EDF-GLOW-FUEL-ENGINES-/261197555823?pt=UK_ToysGames_RadioControlled_JN&hash=item3cd096686f
[image][/image]
Gilles
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 147
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 2:20 PM
Canadian Man
Score: 100
Status: offline
Hello Gilles. I purchased the blue angles version and its far too large.
Hide Signatures
       Post #: 148
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 2:43 PM
looping-74
Score: 100
Status: offline
The one on the Ebay link is perfect scale. You can see on the pictures.
Hide Signatures
       Post #: 149
RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of ... - 4/18/2013 3:44 PM
Canadian Man
Score: 100
Status: offline
Perfect. Thanks. I'll order it.
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
