What type of glue can I use to hold magnets in place?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Extra 330S
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> ARF or RTF >> What type of glue can I use to hold magnets in place?
    Page: [1]
    Login
    What type of glue can I use to hold magnets in place? - 11/7/2012 8:09 PM
    jstanton
    Score: 100
    Last Login: 5/20/2013
    Status: offline
    I want to use magnets to hold my canopy on. What type of glue will hold the magnets in place and not come loss when I remove to canopy. I have a would fuselage and canopy. The Magnets are 1/2" in diameter and 1/4" thick. I will use 2 dowels on the front of the canopy and 4 magents on the rear. 2 in the fuselage and 2 in the canopy itself
    _____________________________
    Jim Stanton
    Millington, TN 38053
    Hide Signatures
           Post #: 1
    RE: What type of glue can I use to hold magnets in place? - 11/7/2012 9:36 PM
    600Bob
    Score: 100
    Last Login: 5/18/2013
    Status: offline
    I would use 30 min. epoxy myself.
    Hide Signatures
    (in reply to jstanton)
           Post #: 2
    RE: What type of glue can I use to hold magnets in place? - 11/7/2012 10:53 PM
    Granpooba
    Score: 110
    Last Login: 5/6/2013
    Status: offline
    Magnetic glue of course !!
    Just kidding. I to would opt for a good epoxy.
    Hide Signatures
    (in reply to 600Bob)
           Post #: 3
    RE: What type of glue can I use to hold magnets in place? - 11/7/2012 11:08 PM
    flyinwalenda
    Score: 156
    Status: offline
    Take a demel or some heavy sandpaper, or file and scuff up the side of the magnet that will accept the epoxy and it will give the glue something to "bite" into. Scuff up the wood as well.
    Brian Ray
    Hide Signatures
    (in reply to Granpooba)
           Post #: 4
    RE: What type of glue can I use to hold magnets in place? - 11/8/2012 1:49 AM
    Russmall
    Score: 100
    Last Login: 5/19/2013
    Status: offline
    I use a brass tube chucked into a drill to cut the hole for the magnet. This gives the magnet a tight fit into the wood. Then, just a couple of drops of thin CA from the back side is all it takes. Make sure and glue the magnets in so they do not oppose each other. Been doing it this way for years and have never had one come loose. The ones in this plane are 3/8" diameter.
    RS
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 5
    RE: What type of glue can I use to hold magnets in place? - 11/8/2012 2:26 AM
    guver
    Score: 174
    Status: offline
    How do you get the "hole" removed? Ya know the inside of it. Don't you wind up with just a ring or groove around the outside?
    and airplanes were in
    Hide Signatures
    (in reply to Russmall)
           Post #: 6
    RE: What type of glue can I use to hold magnets in place? - 11/8/2012 3:01 AM
    ckreef
    Score: 105
    Last Login: 5/17/2013
    Status: offline
    quote:
    ORIGINAL: jstanton
    I also would use epoxy or a medium CA, in both cases with the magnets inset into a hole.
    How big is this plane ?? 4 x 1/2" magnets are huge. I would think this is for a giant scale plane otherwise buy smaller rare earth magnets and save some weight.
    Hide Signatures
           Post #: 7
    RE: What type of glue can I use to hold magnets in place? - 11/8/2012 10:24 AM
    skystreaker1a
    Score: 100
    Last Login: 3/6/2013
    Status: offline
    JB Weld.
    Hide Signatures
    (in reply to ckreef)
           Post #: 8
    RE: What type of glue can I use to hold magnets in place? - 11/8/2012 10:43 AM
    jstanton
    Score: 100
    Status: offline
    I went ahead and drilled two 1/2" holes into the canopy and used some 1/2" flat washers on the fuselage. I epoxied both the batteries and washers in place. This has made for a very tight fit and looks like it is going to work just fine. O by the way the plane is a 1/5 scale Fokker D-VII with a DEL-30 gas engine. That is why I choose to use 1/2" flat magnets. Here are a few pic's The canopy has the pilot in it.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Jim Stanton
    Hide Signatures
    (in reply to skystreaker1a)
           Post #: 9
    Page:   [1]
    Page: [1]
    Extra 330S
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.906RCU1
