Zenoah G20EI Ignition no spark    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Zenoah G20EI Ignition no spark
Page: [1]
Login
Zenoah G20EI Ignition no spark - 11/8/2012 4:35 AM
Racinrc14
Score: 100
Last Login: 5/9/2013
Status: offline
Hello all,
I have a brand new Zenoah G20ei. I wired everything up as per the instructions. Thought I had done everything right. What I discovered was that I had used an old switch (probably Airtronics) for the ignition battery that had the positive wire on the outside of plug, and turned the ignition on before I realized it was backwards. Of course, now I have no spark. I have tried to get the ignition to fire on the bench by plugging in a fresh 4.8 battery (and using the correct polarity) and grounding the plug against the jug and switching the ignition on then off. This yields no spark. Have I fried the whole shebang by reversing the input voltage? I'm hoping to avoid having to buy a new ignition, and Adrian at CH can fix me up for about $100 bucks, but I was hoping maybe an expert here can maybe pick up something I'm missing and save my bacon. Thanks in advance,
-Tommy
_____________________________
Tommy Dale
Racinrc14@yahoo.com
Hide Signatures
       Post #: 1
RE: Zenoah G20EI Ignition no spark - 11/8/2012 5:58 AM  1 votes
bcchi
Score: 650
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Racinrc14
Hello all,
-Tommy
Probably blew you hall sensor. Try that first. Adrian has them.
BCCHI
Hide Signatures
(in reply to Racinrc14)
       Post #: 2
RE: Zenoah G20EI Ignition no spark - 11/8/2012 12:19 PM
jymz
Score: 100
Status: offline
Sounds like its toast. You can get a replacement for it here http://www.rcextremepower.net/ignitions.html thats better than the stock unit. Its not a power hog like the Zenoah and it does not weigh as much.
This was in the FS forum http://www.rcuniverse.com/market/item.cfm?itemId=880829
< Message edited by jymz -- 11/8/2012 12:41 PM >
Hide Signatures
(in reply to bcchi)
       Post #: 3
RE: Zenoah G20EI Ignition no spark - 11/8/2012 5:59 PM  1 votes
karolh
Score: 310
Status: offline
If the ignition is in fact toast as I suspect it might be, do yourself a big favour and get a replacement plug and play RC exl unit from Milton at RC Extreme power and go enjoy your G20.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 4
RE: Zenoah G20EI Ignition no spark - 11/8/2012 7:37 PM  1 votes
closetguy
Score: 166
Last Login: 5/23/2013
Status: online
i would follow BCCHI suggestion first,he made these ignitions for years.
Hide Signatures
(in reply to karolh)
       Post #: 5
RE: Zenoah G20EI Ignition no spark - 11/9/2012 4:14 AM
Racinrc14
Score: 100
Status: offline
[/quote]
BCCHI
[/quote]
I thought that's what I was checking when I switched the ignition on then off. If you get spark when doing this doesn't this indicate a faulty hall sensor? I have a replacement Zenoah sensor on the way, it was cheap enough. Is there a way to troubleshoot the hall sensor?
Tommy Dale
Racinrc14@yahoo.com
Hide Signatures
(in reply to bcchi)
       Post #: 6
RE: Zenoah G20EI Ignition no spark - 11/9/2012 4:43 AM
bcchi
Score: 650
Status: offline
quote:
ORIGINAL: Racinrc14
BCCHI
OK,I am brain dead sorry. I was thinking C&H or RCEXL.I do not no about testing the Zen ignition except it draws close to three amps.
BCCHI
Hide Signatures
       Post #: 7
RE: Zenoah G20EI Ignition no spark - 11/9/2012 11:23 PM
Racinrc14
Score: 100
Status: offline
3 amps?!? Holy crap! I might just order one of the others anyway...
Tommy Dale
Racinrc14@yahoo.com
Hide Signatures
(in reply to bcchi)
       Post #: 8
RE: Zenoah G20EI Ignition no spark - 11/10/2012 12:25 AM
Racinrc14
Score: 100
Status: offline
We have ignition! It was indeed the sensor as BCCHI suggested. So, for Zenoah ignitions, turning the ignition on then off with the plug grounded to the crankcase is not a definitive check of the hall sensor as it may be for other ignitions.
Thanks guys!
-Tommy
Tommy Dale
Racinrc14@yahoo.com
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Zenoah G20EI Ignition no spark
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
