1/6th Scale DO-335    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> 1/6th Scale DO-335
Page: [1] 2   next >   >>
Login
1/6th Scale DO-335 - 11/8/2012 5:39 AM
ProfLooney
Score: 100
Last Login: 5/8/2013
Status: offline
Ok Guys besides the HE-111 I was also asked by the same customer to put together his new 1/6th Scale DO-335 in Solidworks so that can have some nice shots of it for construction book. I will also be prototype building this plane once I am finished.  The plans are really nice looking and colored to make things easier to read. there is even a complete electrical diagram sheet set up , plus it is electric so no worries about coolong and mopunting a rear engine plus at 1/6th scale it will be easy to transport.
Here are a few screenshots of the plans I will post more pics as I put the plane together in solidworks.
Since right now theres no construction manual I will be figuring it out as I go, however for now it seems to be built over a center crutch top and bottom halves.
_____________________________
Scale Model Design And Fabrication Services L.L.C.
Http://www.proflooney.net
Hide Signatures
       Post #: 1
RE: 1/6th Scale DO-335 - 11/8/2012 5:41 AM
ProfLooney
Score: 100
Status: offline
Hide Signatures
(in reply to ProfLooney)
       Post #: 2
RE: 1/6th Scale DO-335 - 11/8/2012 5:44 AM
ProfLooney
Score: 100
Status: offline
Hide Signatures
       Post #: 3
RE: 1/6th Scale DO-335 - 11/8/2012 5:51 AM
ProfLooney
Score: 100
Status: offline
Hide Signatures
       Post #: 4
RE: 1/6th Scale DO-335 - 11/8/2012 5:52 AM
ProfLooney
Score: 100
Status: offline
So there is the Plans for the most part Now I need to import some stuff into Solidworks and start extruding the parts. this will give me a rough Idea of the finished weight too
Hide Signatures
       Post #: 5
RE: 1/6th Scale DO-335 - 11/8/2012 7:58 AM
abufletcher
Score: 1576
Last Login: 5/20/2013
Status: offline
Looks like your "customer" also has some very impressive 2-D CAD skills! That certainly makes collaboration (commercial or otherwise) much easier and we'll be seeing more and more of that. We'll also be seeing many more Isometric construction drawings instead of photos in product manuals. Flair did away entirely with text descriptions of construction on their Puppeteer Mark II in favor of isometrics.
While I have a deep love of hand-drawn plans as objects of beauty (and find CAD drawings rather ugly), designing in CAD greatly enhances (if the user is strict with himself) the likelihood of a truly scale design. However, as I've said at other times in other places, I think there's a danger that using CAD can push designers to design in certain ways that may not be compatible with the "spirit" of the original, an example of this is the "3-D puzzle" approach.
Also I suspect that the days of having to work with two different CAD softwares are numbered. I don't know what 2-CAD was used here, but soon (or already in some cases) all you'll have to do is click "Render 3D."
Hide Signatures
       Post #: 6
RE: 1/6th Scale DO-335 - 11/8/2012 8:02 AM
ProfLooney
Score: 100
Status: offline
yea I try not to do very much 3D puzzle as a lot of times it adds a lot of extra weight. But I will use the puzzle approach in some areas just because it adds strength. Right now I am trying just to figure some of the stuff out on this plane and having to use the plans to extract parts yuck
Hide Signatures
(in reply to abufletcher)
       Post #: 7
RE: 1/6th Scale DO-335 - 11/8/2012 8:08 AM
abufletcher
Score: 1576
Status: offline
Once you get to stress-skin metal construction aircraft (think "WWII) the whole idea of "scale internal structure" on a model sort of goes out the window...or it's truly pointless. On the other hand, with WWI models, my attitude is "the inside IS the outside" so there's very little reason to "redesign" an already perfectly good design. It just needs to be "translated" into model materials and sizes.
At the same time, I have to admit that the complexity of building WWII models, and particularly something like the DO-335, scares the bejeezus out of me.
Hide Signatures
       Post #: 8
RE: 1/6th Scale DO-335 - 11/8/2012 8:16 AM
ProfLooney
Score: 100
Status: offline
yea all my WWI models I design as close as possible to the original cause it all can be seen through the fabric plus they light weight enough its fun to make them look original.
but areas on a WWII plane line motor mounts lg mounts and some flying surface mounts having puzzle cut makes them much stronger than just flush glueing the side of ply to the face of another ply piece. not to mention to properly glue ply or pourous wood like balsa you put a thin layer of glue on the area where glue will be applied let it dry then glue the pieces together. this was taught to me by a furnature maker as he explained wood naturally will pull the glue away from the joint so you need to seal the pores by double glueing
Hide Signatures
       Post #: 9
RE: 1/6th Scale DO-335 - 11/8/2012 4:50 PM
invertmast
Score: 193
Status: offline
Oh i love the DO335, what wingspan is this one? What drawings did he base the outline on?
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 10
RE: 1/6th Scale DO-335 - 11/8/2012 5:16 PM
ProfLooney
Score: 100
Status: offline
it's like a 90" wingspan and calls for 2 Scorpion S-5535-190KV Motors
As for the drawings he used I have no idea but I will check on it. when I prototype it I might convert it to the type 10 2 seat nightfighter I like the lines on that better and all it basically is is adding a little to the top
Hide Signatures
(in reply to invertmast)
       Post #: 11
RE: 1/6th Scale DO-335 - 11/8/2012 9:34 PM
ProfLooney
Score: 100
Status: offline
BTW the Designer use the A.L. Bentley drawings
Hide Signatures
       Post #: 12
RE: 1/6th Scale DO-335 - 11/8/2012 11:04 PM
GM1
Score: 100
Last Login: 3/5/2013
Status: offline
I have plans for a gas 104" version but find the prospect of an electric intriuging.
In a dog sled team, if you're not the lead dog, the view never changes.
Hide Signatures
       Post #: 13
RE: 1/6th Scale DO-335 - 11/8/2012 11:54 PM
ProfLooney
Score: 100
Status: offline
Ive built 2 of Don Smiths and they were a total pain and I found a lot of engineering needed just to cool the rear engine so I thought Electric could be fun for this and this will be my first serious electric
Hide Signatures
(in reply to GM1)
       Post #: 14
RE: 1/6th Scale DO-335 - 11/9/2012 1:45 AM
ProfLooney
Score: 100
Status: offline
I Got the front end going. the hatch and still have to add the bottom formers
Hide Signatures
       Post #: 15
RE: 1/6th Scale DO-335 - 11/9/2012 3:24 AM
invertmast
Score: 193
Status: offline
90" and based off the Bentley drawings.. COUNT ME IN! where can I get plans?
Thomas W.
Hide Signatures
       Post #: 16
RE: 1/6th Scale DO-335 - 11/9/2012 3:26 AM
ProfLooney
Score: 100
Status: offline
well I have to build it first and make sure all the parts fit but I think he drew them for Arizona Models
Hide Signatures
       Post #: 17
RE: 1/6th Scale DO-335 - 11/9/2012 4:03 AM
Ram-bro
Score: 156
Status: offline
definietly electric and maybe consider putting one of the motors in the scale location and use the scale cooling outlets rear of the radiator and in front of the rear spinner. Hey if your gonna do it in cad might as well see if it can be done
Hide Signatures
       Post #: 18
RE: 1/6th Scale DO-335 - 11/9/2012 4:07 AM
invertmast
Score: 193
Status: offline
Fiberglass cooling ducts would be fairly simple to fabricate for this thing..
Thomas W.
Hide Signatures
(in reply to Ram-bro)
       Post #: 19
RE: 1/6th Scale DO-335 - 11/9/2012 4:12 AM
ProfLooney
Score: 100
Status: offline
well guys it is already done I am only putting it together in Solidworks to make sure everything fits and to have some good detail shots for the instruction manual for individual areas etc. then I need to build it so can see whats going to go on. Since it isnt my design or anything I am doing just the usual minor changes for unfitting parts and the instruction manual. from there if he needs molds for different things he will let me know.
Hide Signatures
       Post #: 20
RE: 1/6th Scale DO-335 - 11/9/2012 4:14 AM
ProfLooney
Score: 100
Status: offline
Here is where I am at the moment. it takes a bit to do each former as I need to convert them for solidworks but its speeding up
Hide Signatures
       Post #: 21
RE: 1/6th Scale DO-335 - 11/9/2012 7:02 AM
ProfLooney
Score: 100
Status: offline
Ok I have all but 2 angled formers to go then to do a few things. I need to adjust the holes for the air tanks or adjust the tanks themselves. and then add all the other little items
Hide Signatures
       Post #: 22
RE: 1/6th Scale DO-335 - 11/9/2012 3:14 PM
spinnetti
Score: 100
Last Login: 5/19/2013
Status: offline
Looks great!
Hide Signatures
       Post #: 23
RE: 1/6th Scale DO-335 - 11/9/2012 3:29 PM
Lifer
Score: 148
Status: online
Really, really cool! Thanks for sharing!
Hide Signatures
(in reply to spinnetti)
       Post #: 24
RE: 1/6th Scale DO-335 - 11/9/2012 3:43 PM
ProfLooney
Score: 100
Status: offline
Some More Drawings
Hide Signatures
(in reply to Lifer)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
