Hot gluing a wing servo ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> Hot gluing a wing servo ?
Page: [1]
Login
Hot gluing a wing servo ? - 11/9/2012 1:14 AM
Popriv
Score: 216
Last Login: 6/18/2013
Status: offline
2lb. electric Yak, instructions call for 2 sided tape to hold the wing servos on.
Seems like the tape I have would allow for some play/movement .. I opted to use a dab of hot glue under the servo and then around the edges...
Is this an acceptable method.. seems tight... I've always relied on mechanical fasteners..
Steve
Click to see fullsize image.
Click for fullsize
_____________________________
Excuse me while I touch the sky...
Hide Signatures
       Post #: 1
RE: Hot gluing a wing servo ? - 11/9/2012 1:41 AM
JohnBuckner
Score: 352
Last Login: 6/19/2013
Status: offline
I see no issue with that PR. On some like that with an aileron plate I have used thin foam tape and just CA'ed both sides of the thin tape. That way it gives a very thin cushion of foam that allows you to cut out the servo with a blade if needed later. Also have simply Ca'ed with foam safe directly to the foam side.
John
"Keep your controllines tight"
Hide Signatures
(in reply to Popriv)
       Post #: 2
RE: Hot gluing a wing servo ? - 11/9/2012 2:20 AM
j.duncker
Score: 121
Status: offline
I have done this but wrapped the servo with a turn of masking tape before the glue.
Gut feeling said that this was more secure.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to JohnBuckner)
       Post #: 3
RE: Hot gluing a wing servo ? - 11/9/2012 4:16 AM
Hossfly
Score: 453
Status: offline
I would not trust that arrangement. One extra item that would make it - IMO - OK, is to use one or more of the small plastic ties ( readily available in $ stores in packages of a number of them in varied lengths ) wrapped around the servo through a small hole drilled through the wood/plastic base. Then if the tape gets loose, you have a good chance of discovering it before you pick up a broken flying machine.
I use a lot of those little ties and big ties to hold and/or secure various items in their place.
Horrace Cain AMA L-93
“Peace is the brief glorious moment in history when everyone stands around reloading." T. Jefferson
Hide Signatures
       Post #: 4
RE: Hot gluing a wing servo ? - 11/9/2012 9:57 AM
JeffinTD
Score: 110
Status: offline
Cheap ARF's often install servos with hot glue. A pain if you have to replace one, but otherwise seems to work fine.
With wood hatches like in your photo, though, I think I'd epoxy a couple of blocks of wood to the hatch and mount the servo with screws.
Hide Signatures
(in reply to Hossfly)
       Post #: 5
RE: Hot gluing a wing servo ? - 11/9/2012 10:03 AM
Popriv
Score: 216
Status: offline
quote:
ORIGINAL: Hossfly
I'm not using tape, I've hot glued it in. There may be better tape as mine is not super sticky?
On my 2nd wing servo I super glued to small mounting blocks on each side of the servo. I didn't screw it in but still used hot glue. Figuring it would hold better with the blocks being there. Could pop a couple of screws into the servo holes. But the first attempt was only with hot glue and as pointed out, it may be a bugger to remove?
I,ve just never NOT used a mechanical fastener.
A plastic tie would work but a little to ugly... Would be last resort..
Steve
Hide Signatures
       Post #: 6
RE: Hot gluing a wing servo ? - 11/9/2012 3:21 PM
JohnBuckner
Score: 352
Status: offline
The trouble with tie wraps is even if the the adhesive failed (whatever type you choose) is they are likely to cause wiggling anyway. I have used the ties in several attempts and even attempted to use no adhesive with just the ties. The result always seemed to be wiggling and a maladjusted control surface.
There are many times servos are just glued directly to a foam surface also and tie could not be used .
PR, you know what you have done is just fine.
John
Hide Signatures
       Post #: 7
RE: Hot gluing a wing servo ? - 11/9/2012 3:28 PM
KW_Counter
Score: 141
Last Login: 6/17/2013
Status: offline
You could also screw/glue a couple of pieces of hardwood
to the plate and screw the servo to them.
Very common practice with larger scale planes.
Basswood would probably work.
Good Luck,
KW_Counter
Hide Signatures
       Post #: 8
RE: Hot gluing a wing servo ? - 11/9/2012 3:51 PM
bikerbc
Score: 121
Status: offline
What you have done is almost a permanent solution...You will have fun reclaming your servo if you ever find the need or you might need to make a new hatch if the servo ever goes south on you and you want to replace the servo... but what you have done looks to me like it will work fine , probably one of the most secure methods I have seen...
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to KW_Counter)
       Post #: 9
RE: Hot gluing a wing servo ? - 11/9/2012 5:28 PM
opjose
Score: 284
Status: offline
quote:
ORIGINAL: KW_Counter
Yup. My first choice as well.
The servos are still removable.
You can take advantage of grommets to provide a cushion.
More reliable than hot glue.
Very simple too.
What is not to like?
< Message edited by opjose -- 11/9/2012 8:25 PM >
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 10
RE: Hot gluing a wing servo ? - 11/9/2012 5:32 PM
KitBuilder
Score: 131
Last Login: 6/16/2013
Status: offline
I hot glue when the servo is ecnased in foam only. 2lb model is a bit much for just hot glue. I do wrap in tape so i can then cut the tape and get the servo out.
Being an old(er) timer.. i find it crazy what size servos people are putting in larger models.. micros in 3 lb models... insane. Must realzie the smaller the servo.. the thinner the gear and the fewer teeth on the gear... easier to strip under load. But that's just me.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
(in reply to opjose)
       Post #: 11
RE: Hot gluing a wing servo ? - 11/9/2012 7:52 PM
Popriv
Score: 216
Status: offline
quote:
ORIGINAL: bikerbc
Yes, I thought of that.. lol
Worse is, its a new servo that I havent tested yet... hope it works...lol
The supplied instructions of a piece of 2 sided tape just didnt seem secure, at least not with the tape I have...
if the HS 55 servo is beefy enough is another question. I have the same servo on the elevator and a hs82 mg servo on the pull pull rudder. Just using what I have on hand...
what would be a better servo thats the same size as the HS55 as thats the size the servo mounts were made to?
steve
Hide Signatures
(in reply to bikerbc)
       Post #: 12
RE: Hot gluing a wing servo ? - 11/10/2012 12:57 AM
combatpigg
Score: 381
Status: offline
Shoe Goop would attack foam, but it will do a great job holding your servo to any semi pourous to non-pourous surface I can think of. If you are gluing to soft balsa, pin **** the area, then hit it with CA glue. It's always a good idea to clean the servo case with something like acetone before gluing. This etches the plastic.
The Shoe Goop also isolates the servo from vibration and some pylon racers swear by it.
It isn't too hard to undo it if you have to later on, but it will put up a pretty good fight.
I used to use HS55s in all my 1/2A planes, but have stepped up to HS65s after quite a few HS55 failures. The HS-65s will still find ways to fail in the tail of a small 3D plane if you accidentally bump them or if the servos are forced to move the control surfaces [easily] beyond there normal range of motion.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
