lead weight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> lead weight
Page: [1] 2   next >   >>
Login
lead weight - 11/9/2012 1:43 AM
dash3riprock
Score: 100
Last Login: 5/18/2013
Status: offline
Anybody know a good source for some lead weights? Im tired of running to my LHS for those little stickys every time i need to add weight. theres got to be something ealse im not thinking of. somthing i can drill and use screws on. I have used rolls of pennies and epoxy with pretty good success but i need a little more this time. any ideas ? Thanks, Joe
Hide Signatures
       Post #: 1
RE: lead weight - 11/9/2012 1:53 AM
uncljoe
Score: 160
Last Login: 5/24/2013
Status: offline
BB's   (usually at ammo dept) are a great source get then at walmart  , 5 pound plastic container  about 8 bucks  pore the amount you need into a plastic bag . you can also add epoxy to secure them in the bag.
 Semper Fi
 Joe
_____________________________
Look towards the Horizon......your death awaits you there
Hide Signatures
(in reply to dash3riprock)
       Post #: 2
RE: lead weight - 11/9/2012 1:54 AM
samparfitt
Score: 125
Last Login: 5/23/2013
Status: offline
I get 25 lb bags of buck shot (was about $40) from local gun range:
http://www.targetworld.net/
I'm sure you have something, similar in your area.
G. Samuel Parfitt
Hide Signatures
       Post #: 3
RE: lead weight - 11/9/2012 2:03 AM
Live Wire
Score: 6329
Status: offline
Tire balance weights
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 4
RE: lead weight - 11/9/2012 3:21 AM
tunakuts3d
Score: 105
Status: offline
Gary  Prince ( ram3500 - rcu) sells steel powder that you mix with epoxy to form a thick paste that can be applied to the inside of cowls or other areas up in the nose. http://www.rcuniverse.com/forum/m_10576473/anchors_10903110/mpage_27/key_/anchor/tm.htm#10903110   pm him for more info or search for more of his threads.
obsessed Stuka D3 nut
Hide Signatures
(in reply to Live Wire)
       Post #: 5
RE: lead weight - 11/9/2012 3:34 AM
Peter_OZ
Score: 108
Last Login: 5/22/2013
Status: offline
fishing sinkers and lots of heat
fun police have struck again
Hide Signatures
(in reply to tunakuts3d)
       Post #: 6
RE: lead weight - 11/9/2012 3:38 AM
Edwin
Score: 156
Status: offline
I've used 1/4" thick steel plate cut out to fit the firewall. Then mount the engine. Usually on short nose round cowls like on Zero's and Stearman's. Of course it helps have a metal cutting band saw.
Edwin
Hide Signatures
(in reply to Peter_OZ)
       Post #: 7
RE: lead weight - 11/9/2012 3:47 AM
Check6
Score: 105
Status: offline
I use lead flashing for chimneys. Get it at hardware stores and Home Depot You can fold it quite easily and make blocks.
Fred
Hide Signatures
(in reply to Edwin)
       Post #: 8
RE: lead weight - 11/9/2012 11:45 AM
carlbecker
Score: 100
Last Login: 4/29/2013
Status: offline
Lead shot in the 25lb bag. Make holding weights or epoxy pie where ever needed.
Hide Signatures
(in reply to Check6)
       Post #: 9
RE: lead weight - 11/9/2012 1:07 PM
MajorTomski
Score: 113
Status: offline
And if you need nose weight, on my last two models I bought flat round or triangular fishing weights at Academy sports. Then drilled and tapped the sides of my engine mounts and screwed the weights to the engine mounts. Puts the weight as far forward as possible, minimizing the amount needed and lets you remove or lighten the amount if needed as you get comfortable with the plane.
Spitfire Brotherhood #6
Kadet LT 40 Brotherhood #98
Hide Signatures
(in reply to carlbecker)
       Post #: 10
RE: lead weight - 11/9/2012 1:36 PM
gibb
Score: 100
Status: offline
My buddy and I use a small cupcake metal cooking sheet. Fill the cupcake form with shot or whatever you like and hit it with the propane torch. Let it cool and turn the sheet over and you have a nice block that you can drill a hole through or glue on.....recommend the bolt on method. Again, use the mini cupcake sheet.
Hide Signatures
(in reply to MajorTomski)
       Post #: 11
RE: lead weight - 11/9/2012 1:48 PM
scale only 4 me
Score: 319
Status: offline
nice tip
I did want to try that "SteelPowder" someday too
Hide Signatures
(in reply to gibb)
       Post #: 12
RE: lead weight - 11/9/2012 1:51 PM
a65l
Score: 105
Last Login: 5/7/2013
Status: offline
I'd say Wal-mart for lead sinkers, but those things are rather expensive..... but they can be pounded into whatever shape you need and then held in with silicone adhesive...
In God I trust.
All others pay cash.
Hide Signatures
(in reply to scale only 4 me)
       Post #: 13
RE: lead weight - 11/9/2012 3:06 PM
tfarmer96
Score: 125
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: dash3riprock
This is where i get my lead
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1311&_nkw=lead+ingots&_sacat=0&_from=R40
Spitfire Brotherhood #2
www.wyliewarbirds.com
Hide Signatures
       Post #: 14
RE: lead weight - 11/9/2012 3:30 PM
ForcesR
Score: 105
Last Login: 2/22/2013
Status: offline
dash3riprock; go to your local "Scuba Dive Shop" in your area, they should have a good selection of various lead weights, size, shapes, weights etc., that can be drilled and attached to your aircraft to suit your needs.
Roger
Hide Signatures
       Post #: 15
RE: lead weight - 11/9/2012 4:06 PM
STUKA BARRY
Score: 130
Status: offline
Why not usable weight? If you need to add weight, purchase a larger battery. It does'nt make sense to add dead weight. A larger battery will solve your balance problem as well as adding more flight time.
KEEP UM FLYIN
Hide Signatures
(in reply to ForcesR)
       Post #: 16
RE: lead weight - 11/9/2012 4:25 PM
Edwin
Score: 156
Status: offline
I didnt have room for 5lbs of battery.
Edwin
Hide Signatures
(in reply to STUKA BARRY)
       Post #: 17
RE: lead weight - 11/9/2012 4:26 PM
check6ii
Score: 112
Last Login: 12/31/2012
Status: offline
I get mine at the local dive shop. You can get some that goes on a weight belt, and shot thats in a strong woven bag. On the bag I emty out whatever amount needed.
"I dont have an attitude, rather, you have a perception problem"
Hide Signatures
       Post #: 18
RE: lead weight - 11/9/2012 5:47 PM
GerKonig
Score: 191
Status: offline
quote:
ORIGINAL: gibb
Great idea...
Gerry
Hide Signatures
(in reply to gibb)
       Post #: 19
RE: lead weight - 11/9/2012 6:00 PM
aa1a
Score: 100
Status: offline
I go to my local tire store and ask for some used tire weights. They are usually reluctant but when I tell them what I want them for they will give me me a couple handfulls. Bring your own bag. They are using steel instead of lead now so there is less and less lead in the mix. They are dirty but the price is right.
Jim
Hide Signatures
(in reply to GerKonig)
       Post #: 20
RE: lead weight - 11/9/2012 7:12 PM
radfordc
Score: 100
Status: offline
Decoy strap weights work great. They are soft and flat and can be easily cut, drilled, or bent to shape.
Walmart has them http://tinyurl.com/bchqoe5
Hide Signatures
(in reply to aa1a)
       Post #: 21
RE: lead weight - 11/9/2012 8:04 PM
Moggy
Score: 100
Last Login: 3/22/2013
Status: offline
Zinc plates used on boats. You can usually get used ones at a marina in the spring for free.
Piece of Cake
Spitfire Brotherhood #121
Hide Signatures
(in reply to radfordc)
       Post #: 22
RE: lead weight - 11/9/2012 8:50 PM
wayne d
Score: 105
Last Login: 5/21/2013
Status: offline
I would recommend Ram3500 (gary Prince) and his steel powder. Very easy to use and besides lead is toxic when melted. I took some old paper tubes from wing tubes, sealed the end with packing tape, mixed up 30min epoxy and poured it in. When its cured it can be cut on a band saw without clogging up the blade. Best thing is you can cut it to any size you need. And its heavy stuff when its mixed.
Best Regards,
Wayne Fussell Pres. Solo Propellers & RC Products
Hide Signatures
(in reply to Moggy)
       Post #: 23
RE: lead weight - 11/9/2012 10:21 PM
lkruse
Score: 100
Last Login: 5/10/2013
Status: offline
Wheel weights at Harbor Freight. They are available and cheap.
Hide Signatures
       Post #: 24
RE: lead weight - 11/10/2012 2:02 AM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
Edwins steele firewall is a clean idea,you dont need to epoxy a bunch of crap to the cowl just BUILD it into the plane.good idea ED.
Hide Signatures
(in reply to lkruse)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
