48in mono hull scratch build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> 48in mono hull scratch build
Page: [1]
Login
48in mono hull scratch build - 11/9/2012 6:30 PM
maxxnitro88
Score: 100
Last Login: 5/3/2013
Status: offline
 this is my first boat that i have built, found some plans online and had a homelite 25cc engine laying around.  this is what i came up with.  i had a lot of help fromthis forum building my boat so i figured i would post up these pics so new guys/girls can get  agood idea of what all is involved!
Hide Signatures
       Post #: 1
RE: 48in mono hull scratch build - 11/9/2012 6:39 PM
maxxnitro88
Score: 100
Status: offline
here is a link to the first run of the boat, the engine was still not quite tuned right!
Hide Signatures
(in reply to maxxnitro88)
       Post #: 2
RE: 48in mono hull scratch build - 11/9/2012 8:06 PM
cconeill
Score: 100
Last Login: 5/18/2013
Status: offline
You have to luv a woodie!! very nice job.
Hide Signatures
       Post #: 3
RE: 48in mono hull scratch build - 11/9/2012 10:31 PM
The Ghost
Score: 110
Status: offline
Very nice boat, very clean lines, good luck with it, congrats
cheers
_____________________________
Remember, Always look after the ORGANIC part of the model
Hide Signatures
(in reply to cconeill)
       Post #: 4
RE: 48in mono hull scratch build - 11/10/2012 4:23 AM
dwr9
Score: 105
Last Login: 5/17/2013
Status: offline
Looks real nice. Doug
Hide Signatures
(in reply to The Ghost)
       Post #: 5
RE: 48in mono hull scratch build - 11/10/2012 7:00 PM
expresscraft
Score: 105
Last Login: 4/13/2013
Status: offline
very nice job,you will have a lot of fun with that boat.
Owner - Express Craft Model Boats
Hide Signatures
(in reply to dwr9)
       Post #: 6
RE: 48in mono hull scratch build - 11/12/2012 4:51 PM
maxxnitro88
Score: 100
Status: offline
thanks, its a pretty fun cruiser.  im hoping a 3 blade prop will give it some more pep this spring, but i haven't done any research so any input on a  potentially better prop would be helpful!
Hide Signatures
(in reply to expresscraft)
       Post #: 7
RE: 48in mono hull scratch build - 11/12/2012 6:37 PM
martno1fan
Score: 221
Status: offline
Making it a surface drive will improve performance quite a bit,exit the transon 1/8 -1/4 " to right of keel and 1/2" up from the keel to centre of driveline and im sure you will see more performance.
Mart
waveridermouldings
Hide Signatures
       Post #: 8
RE: 48in mono hull scratch build - 11/13/2012 2:04 AM
MrMikeG
Score: 115
Status: offline
Try a X470/3, or Prather 275 or 280.
You might need another shroud, you cut that one a bit low. Once you start working the engine harder you need the cooling coming off the fan going across the head, forward motion is no where near enough air flow.
Hide Signatures
(in reply to martno1fan)
       Post #: 9
RE: 48in mono hull scratch build - 11/13/2012 3:35 AM
dwr9
Score: 105
Status: offline
The props Mike mentioned should work on a surface drive. You could also try an X482. The X470/3 would be my first choice of the props mentioned. however they are all too large for you current subsurface drive. The boat was meant to use a surface drive. Doug
Hide Signatures
(in reply to MrMikeG)
       Post #: 10
RE: 48in mono hull scratch build - 11/13/2012 4:21 AM
MrMikeG
Score: 115
Status: offline
I ran a drive like that for a while, most of the top blade will still be out of the water.
Trying to find 12 year old pics on hard drives is the problem now.
Hide Signatures
(in reply to dwr9)
       Post #: 11
RE: 48in mono hull scratch build - 11/19/2012 2:04 PM
maxxnitro88
Score: 100
Status: offline
just out of curiosity how does the octoura x470/3 compare to the prop shop B6717/3?
i see that the B6717/3 has a steeper pitch (4.48) but with a smaller diameter (67mm), but not really sure how the specs stack up with the octura's specs.
Hide Signatures
       Post #: 12
RE: 48in mono hull scratch build - 11/19/2012 2:22 PM
martno1fan
Score: 221
Status: offline
Personally i think youd be best with a bigger prop,a good prop for a lower reving motor is the prather 280.
waveridermouldings
Hide Signatures
       Post #: 13
RE: 48in mono hull scratch build - 11/22/2012 3:42 PM
chipbreakr
Score: 100
Last Login: 3/22/2013
Status: offline
            Great job,  If you would like to build a tuned pipe for it and have plans that I can email
Jim
Hide Signatures
       Post #: 14
RE: 48in mono hull scratch build - 11/22/2012 5:34 PM
maxxnitro88
Score: 100
Status: offline
quote:
ORIGINAL: chipbreakr
Jim
yea sure that would be great, my email is mann.232@osu.edu
it's been hard to find one that will fit with the way I have the exhaust routed...
Hide Signatures
(in reply to chipbreakr)
       Post #: 15
RE: 48in mono hull scratch build - 11/23/2012 2:43 PM
chipbreakr
Score: 100
Status: offline
I'm out of town , I'll be home tonight and will send you the pipe plans.
Jim
Hide Signatures
       Post #: 16
RE: 48in mono hull scratch build - 11/29/2012 3:01 AM
chipbreakr
Score: 100
Status: offline
I just sent you the pipe plans , I apologize for taking so long , I forgot about sending them .
Jim
Hide Signatures
       Post #: 17
RE: 48in mono hull scratch build - 11/30/2012 1:40 PM
maxxnitro88
Score: 100
Status: offline
got them thanks!
Hide Signatures
       Post #: 18
RE: 48in mono hull scratch build - 12/14/2012 9:45 PM
wan6176
Score: 105
Last Login: 3/17/2013
Status: offline
was it 48" or 54" which one is it your length.here stated 48" ur youtube stated 54". which is which? what ur width?
Everyday is learning day,no one can say he has learn enough.
Hide Signatures
       Post #: 19
RE: 48in mono hull scratch build - 1/9/2013 4:24 PM
maxxnitro88
Score: 100
Status: offline
48 without the running gear and 54 with it.
Hide Signatures
(in reply to wan6176)
       Post #: 20
RE: 48in mono hull scratch build - 3/22/2013 9:27 AM
michaelgrout146
Score: 100
Last Login: 5/12/2013
Status: offline
I'd like to build one of these too! Where did you find the plans?
Hide Signatures
       Post #: 21
RE: 48in mono hull scratch build - 3/23/2013 2:34 AM
dwr9
Score: 105
Status: offline
michaelgrout146, I can email them to you if you let me have your email address or you can download them at: http://www.modelgasboats.com/
Doug
Hide Signatures
(in reply to michaelgrout146)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.607RCU1
