Pratt & Whitney 1/5 scale radial engine for warbirds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Pratt & Whitney 1/5 scale radial engine for warbirds
Page: [1] 2   next >   >>
Login
Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 12:12 AM
77chickenhawk
Score: 105
Last Login: 5/18/2013
Status: offline
Here is a nice new treat that is coming out. Authentic scale is just about finished with their nine cylinder radial gas engine
http://pegasusengine.com/cart.php?m=
Click to see fullsize image.
Click for fullsize
_____________________________
Just Make It Look Real !!!
Hide Signatures
       Post #: 1
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 3:46 AM
77chickenhawk
Score: 105
Status: offline
Hey you guys feel free to post any comments or thoughts this is definitely a worthy topic for conversation for sure
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 2
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 3:51 AM
BOLTMAN
Score: 101
Last Login: 5/17/2013
Status: online
If that is a R-2800 where is the second row of cylinders????
It does look really cool though & in a model I would not want the hassle of cooling a second row or the weight.
Aussie Bolts & Bits - Small fasteners for modelers
Hide Signatures
       Post #: 3
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 3:56 AM
Ram-bro
Score: 156
Last Login: 5/19/2013
Status: offline
I did nt see any specs on the motor. What size, what power, what is the diameter, whats it weigh and above all else whats it cost?
Hide Signatures
(in reply to BOLTMAN)
       Post #: 4
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 4:04 AM
samparfitt
Score: 125
Status: offline
clicking on the picture, pulls up the specs:
http://pegasusengine.com/Authentic-Scale-Engines/Radial-4-Stroke-Model-Engines/1-5-Scale-Radials/1-5-Scale-P-W-R-9-2800-200.html
Scale: 1/5
Fuel: Gasoline
Configuration: Radial
Cooling: Air
Cylinders: 9
Displacement: 200 cc (12.2 cu in)
Bore X Stroke: 29 X 32 mm
Compression Ratio: 9.5:1
Propeller Shaft: 10 mm, splined
Engine Outside Diameter: 278 mm (10.94")
Length (Prop. Back plate to firewall mount): 275 mm (10.82")
Weight (w/o blades or hubs): -
Carburetor: 1 Tillotson
Available: Late November
$3500
G. Samuel Parfitt
Hide Signatures
(in reply to Ram-bro)
       Post #: 5
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 4:11 AM
Ram-bro
Score: 156
Status: offline
thanks, I think my computer is acting up
Hide Signatures
(in reply to samparfitt)
       Post #: 6
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/10/2012 4:27 AM
77chickenhawk
Score: 105
Status: offline
Yeah! Try going into the parts section and scroll down about halfway on the left and you'll see the collector ring for it looks just like a AT6 exhaust nice-looking piece. It's going to have a multi spark electronic ignition and Antonio at authentic scale said the Ignition has 2 sparks per combustion. Two spark plugs Per cylinder also So that's really cool and then to top it off they have the 3,4 and five blade Variable pitch propeller (Ground adjustable) looking forward to hearing it run
Click for fullsize
Click for fullsize
< Message edited by 77chickenhawk -- 11/10/2012 3:42 PM >
Hide Signatures
       Post #: 7
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/13/2012 8:07 PM
SnakeBT6
Score: 100
Last Login: 12/26/2012
Status: offline
Watching their site with interest..would like the radial and exhaust for my Byron Corsair.
Hide Signatures
       Post #: 8
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/13/2012 10:04 PM
jzuniga
Score: 105
Status: offline
quote:
ORIGINAL: SnakeBT6
Ditto! Awesome ;-)
Z
Hide Signatures
(in reply to SnakeBT6)
       Post #: 9
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/13/2012 10:59 PM
77chickenhawk
Score: 105
Status: offline
Dotto 2. Comp. P-47 or Corsair
Hide Signatures
(in reply to jzuniga)
       Post #: 10
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/15/2012 5:43 AM
77chickenhawk
Score: 105
Status: offline
I just left the website And he has a video of the nine cylinder running. it looks like they are in the break-in process sounds really good and healthy
Hide Signatures
       Post #: 11
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/15/2012 12:06 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
awhile back I think it was moki had a 2 row in develepment I saw on youtube they never did put in on the market.this new engine looks great and being an 11" will fit in alot of 1/5 scale warbirds witch has 12" round cowls,got my vote +.
Hide Signatures
       Post #: 12
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/15/2012 6:16 PM
acdii
Score: 155
Status: offline
1/5th B-17 or B-25, or even a B-24, B-29 would just be the nutz! Four of those running in unison flying low overhead, I think I just had an O.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to dadragon)
       Post #: 13
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/15/2012 6:28 PM
77chickenhawk
Score: 105
Status: offline
Yes I totally agree
Did you go into the parts section yet of the nine cylinder? It shows the Finished three and four blade prop hubs they look exactly scale
Hide Signatures
(in reply to acdii)
       Post #: 14
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/19/2012 1:45 PM
dadragon
Score: 112
Status: offline
they will be comming out with the 1/4 scale twin row,900 I hope will fit in my new 1/4 scale AD-1 skyraider witch is almost done.
Hide Signatures
       Post #: 15
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 11/19/2012 5:33 PM
77chickenhawk
Score: 105
Status: offline
A quarter scale engines are at least a year out. 1/6th scale engines will be first.
Hide Signatures
       Post #: 16
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 2/8/2013 5:45 AM
77chickenhawk
Score: 105
Status: offline
Well it appears that we have a updated website here. He has posted pictures of the engine finally put together with the prop. What an absolutely sexy piece of machinery. I have got to get one of these in my plane
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acdii)
       Post #: 17
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 8:24 AM
jymster
Score: 100
Status: offline
i saw them a couple of months ago too, but now looks like they have increased the price substantially! I am sure it was sub $4000 before, now it is $5000!
WACO Brotherhood #228
Ryan STA/STM Brotherhood #26
Hide Signatures
       Post #: 18
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 12:28 PM
tp777fo
Score: 103
Status: offline
Anyone seen one of these run? Could not find video on their web site.
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to jymster)
       Post #: 19
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 1:56 PM
77chickenhawk
Score: 105
Status: offline
The video is on their homepage. It's about a 20 second clip
Hide Signatures
(in reply to tp777fo)
       Post #: 20
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 2:00 PM
77chickenhawk
Score: 105
Status: offline
Boy oh boy I don't know what happened. But it used to be $3500. I'm going to have to give Antonio a call and find out what happened. Because now it's priced that nobody can afford it
Hide Signatures
       Post #: 21
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 3:20 PM
invertmast
Score: 193
Status: online
quote:
ORIGINAL: 77chickenhawk
Its priced so now its competing with the Larger Moki radials, and given the reputation those have and history those have, youd probly be better off with a moki.
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 22
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 3:31 PM
John Redman
Score: 117
Status: offline
Beautiful engine but at the size or 11 inches in diamater it is going to be hard to find a model it fits into. You will need at least a 12 - 12.5" cowl to make it work. Remember right thrust guys? This pushes the entire engine off to the left side of the fuselage to ensure the prop shaft exits in the center of the cowling.
The real aircraft positioned the verticals with 3 - 5 degrees of right thrust and not the engines. I am currently building a Comp ARF P-47 for a friend and tried to fit the Evo 7 cylinder 260 inside teh cowling and it won't fit if you want any type of right thrust. When you increase the number of cylinders around the cracnkcase the diameter goes up. This is one of the main reasons Moki went with a 5 cylinder radial when they developed the engine. It is smaller in diameter.
I will say the engine is a true work of art, even at the current price!
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
(in reply to invertmast)
       Post #: 23
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 6:07 PM
JeffH
Score: 114
Status: offline
I guess we will just have to start building in the proper offset into the stab!
The later Bf109s used a semi symmetrical airfoil to accomplish the same thing.
Hide Signatures
(in reply to John Redman)
       Post #: 24
RE: Pratt & Whitney 1/5 scale radial engine for warbirds - 4/29/2013 6:26 PM
BobH
Score: 116
Status: offline
A Splined crank shaft will be a problem. Not to the engine but to "sudden stopage". Can you imagine what's going to happen when THAT happens? Not sure its a good idea to have it for our models.
BobH.
Hide Signatures
(in reply to JeffH)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
