Do hobbico LiFe packs load test just like normal batteries?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Do hobbico LiFe packs load test just like normal batteries?
Page: [1]
Login
Do hobbico LiFe packs load test just like normal batter... - 11/10/2012 2:44 AM
FenderBean
Score: 124
Last Login: 6/10/2013
Status: offline
If so whats the stop fly voltage under a 1 amp load on a 6.6v pack? Im not talking about A123s by the way thanks
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 1
RE: Do hobbico LiFe packs load test just like normal ba... - 11/10/2012 10:47 PM
K-Bob
Score: 169
Last Login: 6/18/2013
Status: offline
No matter that they aren't true A123s. You cannot load test them ,especially with 1a. 1a. isn't even enough to tickle them. Charge them, make one flight, then charge them again noting how many Ma. you put back in. Once you know this you can calculate how many flights you can safely make before a recharge. As a rule, I do not run mine below 50% of capacity which leaves a large margin of error. They only take 15 or so minutes to recharge anyway.
K-Bob. The K is silent. "The only time you can have too much fuel is if you are on fire"
Hide Signatures
(in reply to FenderBean)
       Post #: 2
RE: Do hobbico LiFe packs load test just like normal ba... - 11/11/2012 9:25 AM
4*60
Score: 116
Last Login: 6/20/2013
Status: offline
I agree with above.  I use less than 100mah in 3 flights on 5 standard servos in a 4*60 on HobbyKing 1100 LIFE rx packs at $4 each so I would use the Hobbico's for a few years and then buy the HK's and use them for a few years.  If they ever weren't up around 6.6 after charging I would replace them.   At $4 before shipping and with them considered non-toxic don't keep them too long.
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
(in reply to K-Bob)
       Post #: 3
RE: Do hobbico LiFe packs load test just like normal ba... - 11/11/2012 2:37 PM
KW_Counter
Score: 141
Last Login: 6/17/2013
Status: offline
Since LiFes voltage drop very quickly when they get below their
nominal voltage (3.3 v/c), I stop flying them when they get to 3.2 v/c.
I am using LiFes in my transmitter, I stop/recharge at 9.8 volts.
They will stay at 9.9 for quite some time.
This is also true of LiPos.
Good Luck,
KW_Counter
Hide Signatures
       Post #: 4
RE: Do hobbico LiFe packs load test just like normal ba... - 11/11/2012 4:16 PM
countilaw
Score: 229
Status: offline
I  would recommend Hobbico's  batteries and I think you will find them of excellent quality.    Hobbico like Tower demands a higher quality control standards and have a  fantastic customer service reputation.     If you ever get a bad  battery or one that doesn't stand up your quality,  help is just a phone call away.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to KW_Counter)
       Post #: 5
RE: Do hobbico LiFe packs load test just like normal ba... - 11/12/2012 1:22 PM
K-Bob
Score: 169
Status: offline
True, authentic A123 packs will outlast and outperform generic LiFes all day long. They are available from several trusted vendors at very reasonable prices. TaildraggerRC, WrongwayRC and NOBS are just a few I have used with great results. I'm not going to risk my planes to save a few bucks on HobbyKing anything.
Hide Signatures
(in reply to countilaw)
       Post #: 6
RE: Do hobbico LiFe packs load test just like normal ba... - 11/13/2012 2:47 PM
raptureboy
Score: 183
Last Login: 6/19/2013
Status: offline
+1  taken from Hangtimes site-
Q: What's the difference between A123 LiFe packs and LiFe PO4 packs like Hobbico's LiFeSource™ packs?
Two big differences. First, A123's patented 'Nano' plating technology.. at a molecular level the negative plate material stands like a shag carpet rather than laying 'end-to-end'. This produces an incredible amount of surface area gain for A123's negative plate and it's why A123 can tolerate immense current loading without voltage sag. Another benefit to the nano plating technology is a huge increase in cell life. All stored energy systems consume negative plate over time.. with 100+ times the negative plate surface area generated by any competitors plating process the lifespan of the A123 cell is extended immensely. Next, A123's are aluminum cased cylindrical cells with welded alloy end plates and towers like a Nicad cell. This enables a rugged welded strap pack assembly system (like Nicads) that is exceptionally robust and very resistant to vibration and hard knocks. The LiFeSource™ packs are built with wafer stacked 'bag' prismatic cells.. like LiPoly. And, like LiPoly, they are fragile, the cell link tabs are very thin alloy strips and the entire assembly is as a result susceptible to rough handling and vibration. Further, the prismatic cells and their tabbing system are unable to handle anywhere near the current loading the A123 system can tolerate with ease.
But from an AMERICAN COMPANY! These guys aare based in LI, N.Y right at ground zero of Sandy. If your plane means something then your battery should also. http://hangtimes.com/index.html They could use our help right now.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to K-Bob)
       Post #: 7
RE: Do hobbico LiFe packs load test just like normal ba... - 11/13/2012 3:43 PM
pilotpete2
Score: 120
Status: offline
+++++1
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to K-Bob)
       Post #: 8
RE: Do hobbico LiFe packs load test just like normal ba... - 11/13/2012 4:49 PM
trax de max
Score: 114
Status: offline
Hasn't A123 went into liquidation now.
Sorry officer i thought the speed limit only applied to people with driving licenses.
Hide Signatures
(in reply to pilotpete2)
       Post #: 9
RE: Do hobbico LiFe packs load test just like normal ba... - 11/13/2012 10:41 PM
Goldenduff
Score: 114
Status: offline
Bought by Johnstone controls I think?.....
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to trax de max)
       Post #: 10
RE: Do hobbico LiFe packs load test just like normal ba... - 11/14/2012 2:14 PM
BarracudaHockey
Score: 280
Status: offline
That was the car battery division.
Hobby, tools, military, has been unaffected.
My sources are now selling the new 2500 mah A123 packs and cells are available aplenty
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Goldenduff)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
