WSN T34    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> WSN T34
Page: [1]
Login
WSN T34 - 11/10/2012 4:49 AM
mcovalsk
Score: 105
Last Login: 5/22/2013
Status: offline
Hi friends
Could you help me to get a WSN T34 new to buy. Shops from Germany don't want to ship to SA and I didn't see them at ebay.
Thanks!
_____________________________
Mario Covalski
Editor Modelersite
Hide Signatures
       Post #: 1
RE: WSN T34 - 11/10/2012 6:04 AM
Airbrushler
Score: 112
Status: online
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CCIQFjAA&url=http%3A%2F%2Fwww.badcattoys.com%2Ft1mein86fcod.html&ei=I-6dUJeoJoT5ygHg3oG4DQ&usg=AFQjCNHO8l6vq26D85nX9AIEaoA4g8cGpA&sig2=tEjiEbRmW0XjECrKI1QW6A
don't know if this helps
http://s1009.photobucket.com/user/airbrushler/media/Soviet_Tank_Battle_zps9b2ee783.gif.html
Hide Signatures
(in reply to mcovalsk)
       Post #: 2
RE: WSN T34 - 11/10/2012 9:08 AM
Panther F
Score: 135
Last Login: 5/21/2013
Status: offline
I do not believe the Merit's are the WSN, but a TRUMPETER static version and has no outdrives at all.
I did save this link http://www.hydroponicsonline.com/store/WSN-116-RC-USSR-T34-85-Green-IR-BATTLE-TANK_370274354108.html and was going to get a 3rd T34 but funds are going to the new Tamiya. Oh, and I know NOTHING about this company or work for them at all.
~ Jeff
Hide Signatures
(in reply to Airbrushler)
       Post #: 3
RE: WSN T34 - 11/10/2012 12:19 PM
Martellus
Score: 100
Last Login: 5/19/2013
Status: offline
a hydroponics store selling a tanks? lol
Hide Signatures
(in reply to Panther F)
       Post #: 4
RE: WSN T34 - 11/10/2012 7:41 PM
mcovalsk
Score: 105
Status: offline
Thanks for the help!
Mario Covalski
Editor Modelersite
Hide Signatures
       Post #: 5
RE: WSN T34 - 11/14/2012 4:10 AM
model_mania
Score: 100
Status: offline
look this:
http://www.hobbyraw.com/item.jsp?id=19
Hide Signatures
       Post #: 6
RE: WSN T34 - 11/16/2012 4:11 PM
hemi
Score: 100
Status: offline
Hi Mario
Does this mean you might document a T34 build like your M51? If so that would be great. I've been work on a T34 project for some time. combining the WSN lower hull and outdrives with the Trumpeter T34-85 1944 static kit. I'm at the point where the tank is fully functional and runs well so I'm just beginning to start the detail work. I really want to start on the M51 so if your going to document a T34 build I'll stop work and start on my M51 until your finished with your T34. Here are a couple of pictures of my T34. The upper hull is attached with magnets and the turret comes apart the same way.
Best regards
John
Click to see fullsize image.
Click for fullsize
Click for fullsize
John
Hide Signatures
(in reply to model_mania)
       Post #: 7
RE: WSN T34 - 11/16/2012 5:56 PM
mcovalsk
Score: 105
Status: offline
Hi John
Well thanks for your confidence with my work but I think you are doing very well by yourself. By the way I have a question for you. Is it neccesary to use the Trumpeter static to detail the WSN. I mean, is the WSN less detailed in the outside than the Trumpeter?
I had in mind that they used the same moulds, now looks like should I buy both models, RC and static?
Thanks for the help.
Mario Covalski
Editor Modelersite
Hide Signatures
(in reply to hemi)
       Post #: 8
RE: WSN T34 - 11/16/2012 7:36 PM
hemi
Score: 100
Status: offline
Mario
Thanks for your compliments as well. The WSN tank needs to be upgraded to better electronics so I used Tamiya KV1 parts. It's a lot of work using the static kit upper hull and turret and the conversion has to be well thought out. The only thing I'm not happy with is the gun elevation I came up with, is not as smooth as it should be and the recoil mechanism is too far aft limiting up elevation. Some of the exterior detail is the same between the WSN and and the static kit but I think the texture of the upper hull and turret are better in the static kit. The engine deck is definately better. When you look through the open grills you can see the louvered doors used to control airflow into the engine compartment. I'm on a trip now and will be home Sunday. I'll take some pictures of both upper hulls so you can see what I mean. I used all of the upgrade parts Dayrl Turner makes such as aluminum road arms and outdrive bearing upgrades. Having the static kit made it easier to put bearings in the roadwheels and front idlers. If you decide to combine the static kit with the WSN, I'll take pictures of anything you need. I really enjoyed reading the M51 PDF and how you modified parts and discussed tips like making welds look more realistic. If you decide to document the T34, I want to be the first in line to buy the PDF.
Best regards
John
John
Hide Signatures
       Post #: 9
RE: WSN T34 - 11/16/2012 8:47 PM
Panther F
Score: 135
Status: offline
One thing to keep in mind is that the WSN plastic is much more robust and stiffer than the Trumpeter plastic from the kits.
~ Jeff
Hide Signatures
       Post #: 10
RE: WSN T34 - 11/18/2012 8:19 PM
karel47
Score: 149
Status: offline
 check this link
http://cgi.benl.ebay.be/ws/eBayISAPI.dll?ViewItem&item=380502429423&ssPageName=ADME:B:SS:BE:1123
PanzVI-J,ShermanM4A4,PershingM26,KTPorsche2x,KTHenshel Late3x-Early1x,TigerI 3x,JP,Panther,Jagdtiger;PantherIIta;PanthHL;Stu
Hide Signatures
       Post #: 11
RE: WSN T34 - 11/18/2012 10:27 PM
Panther F
Score: 135
Status: offline
quote:
ORIGINAL: karel47
 check this link
Ummm... this is about the T-34, right? C.A.
~ Jeff
Hide Signatures
(in reply to karel47)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
