ASP 15 diesel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> ASP 15 diesel Page: [1] 2   next >   >>
Login
ASP 15 diesel - 11/10/2012 6:45 AM
qazimoto
Score: 100
Last Login: 5/18/2013
Status: offline
My clubmate Bob Fisher turned up with this conversion today. We didn't get around to running it, maybe on Wednesday.
It's one of those Chinese $60 post free ASP 15's TBR glow off ebay. Bob's simply fitted it with a spare 15 Euro push/pull Parra 15D head.
It just required a little machining to the ASP head and a slight liner top skimming to get the clearances right.
Ray
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: ASP 15 diesel - 11/10/2012 8:12 AM
fiery
Score: 100
Status: offline
If it runs as well as it looks it's cert Ray.
Very, very nice. I hear the .15 ASP's are one of the best sports .15's out there.
Running report in due course please.
Hide Signatures
(in reply to qazimoto)
       Post #: 2
RE: ASP 15 diesel - 11/10/2012 9:21 AM
greggles47
Score: 100
Status: online
That young Mr Fisher is a bit of a whiz ,eh mate?
How are his knees now?
Like the look of the ASP, could work really well in a DGY.
G
Hide Signatures
(in reply to fiery)
       Post #: 3
RE: ASP 15 diesel - 11/10/2012 1:33 PM
earlwb
Score: 584
Status: offline
That is a pretty cool looking conversion. Do let us know how it works out too.
It does look nice, clean and sanitary too.
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to greggles47)
       Post #: 4
RE: ASP 15 diesel - 11/10/2012 2:47 PM
AMB
Score: 110
Status: offline
I have 2 a 12 and 15 that I got from Just engines in 2005 with conversion heads run well great carbs (rc)
note the 12 and 15 head are the same diameter same thus slight over hang on diameter of the 12 but inside skinned to fit martin
had I realized at the time engine case almost same size would have gotten 2 15s rather than one of each
Click for fullsize
< Message edited by AMB -- 11/10/2012 4:22 PM >
Hide Signatures
       Post #: 5
RE: ASP 15 diesel - 11/10/2012 4:53 PM
Mr Cox
Score: 102
Status: online
How do the ASP engines run?
The 15A is a more timid engine than the XLS, so it might do better on larger props.
Hide Signatures
(in reply to AMB)
       Post #: 6
RE: ASP 15 diesel - 11/10/2012 10:44 PM
AMB
Score: 110
Status: offline
Did a run on my 15, just wanted to see what would happen with a huge prop put on a wood XOAR 12x5 we did get 6800, sure we could have coaxed to 7K but no point
It was quiet on the stock muffler (no surprise on the low rpms) light exhaust smoke oil was grey/brown good response from idle will re-run tomorrow with a proper prop 9x6 or 9x7
martin
Hide Signatures
(in reply to Mr Cox)
       Post #: 7
RE: ASP 15 diesel - 11/10/2012 11:02 PM
fiery
Score: 100
Status: offline
Give it an 8 x 4 Martin, and let it show you what it can do
Hide Signatures
(in reply to AMB)
       Post #: 8
RE: ASP 15 diesel - 11/10/2012 11:30 PM
AMB
Score: 110
Status: offline
Found one new 8x4 also lets see what the Aussie wood strato 9 x6 does you sent me
Looking at the data sheet on the AA taipan 66 replica did 14600 on the 8x4
Hide Signatures
(in reply to fiery)
       Post #: 9
RE: ASP 15 diesel - 11/10/2012 11:48 PM
fiery
Score: 100
Status: offline
That is true for the "AA S.66 Taipan Repro." Martin, but do note the prop figures were achieved after Maris Dislers "breathed" on his example.
I was very happy with mine. I am reluctant to put it into service. It is such a pretty engine, but I know David Burke prefers his engines to be used, not to become cabinet Queens.
Those Strato propellers are nice, and are a real find, they would date from the late 50's to mid 60's. I know of a stock of them, new old stock, I get them for $2 each. Still perfectly useable today, they featured an airfoil that even "Joe Supercool" complimented, high praise indeed.
Hide Signatures
(in reply to AMB)
       Post #: 10
RE: ASP 15 diesel - 11/11/2012 12:34 AM
AMB
Score: 110
Status: offline
I know Rays ASP 15 is the new SLS model besides the crankcase,wonder if any change in bore, stroke, liner porting??? from the early ones?? martin
Hide Signatures
(in reply to fiery)
       Post #: 11
RE: ASP 15 diesel - 11/11/2012 6:36 AM
Mr Cox
Score: 102
Status: online
I don't have any of the early ones myself so I cannot make a direct comparison, but I believe that "everything" is changed, from a different carb and crankcase, to the bore and stroke.
The older ones had a reputation for being low on power, but perhaps like the OS LA it would make a good diesel.
Hide Signatures
(in reply to AMB)
       Post #: 12
RE: ASP 15 diesel - 11/11/2012 6:56 PM
AMB
Score: 110
Status: offline
OK GROUP got a little time to [put the old ASP A series 15 on the bench for a run Davis ABC mix
all props were wood
XOAR 10x5 9500
zinger 9x6 9700
strato 9x6 9200
zinger 9x4 11000
zinger 8x4 13000
idle 3400 3800 good response to WOT
grey smoke light color oil ( not black)
runs well but a mild engine, starter used first time, then hand flips 5-6 after prime
very quiet with stock muffler martin
Hide Signatures
       Post #: 13
RE: ASP 15 diesel - 11/11/2012 7:32 PM
AMB
Score: 110
Status: offline
Pulled head after the runs pretty clean no soot buildup martin
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 14
RE: ASP 15 diesel - 11/11/2012 8:03 PM
Mr Cox
Score: 102
Status: online
That's pretty low numbers though. Should get something around 15000rpm on an 8x4 prop form a 2.5cc engine...
Even the PAW 09 will make 10500rpm on a 9x4 prop, as a comparison.
Hide Signatures
(in reply to AMB)
       Post #: 15
RE: ASP 15 diesel - 11/11/2012 8:27 PM
AMB
Score: 110
Status: offline
Mr Cox will have to get some APC grey composition props< I thought a little low also , then may be very mild timing and porting,thats why they have the new series, will wait and see what the chap comes up with on the new series with the para head, mine would certainly fly a plane however on these numbers. still a lot of wind martin
It may improve with a little more time running only about a half hour on it, also it was never run on glow
< Message edited by AMB -- 11/11/2012 11:33 PM >
Hide Signatures
       Post #: 16
RE: ASP 15 diesel - 11/11/2012 8:36 PM
Mr Cox
Score: 102
Status: online
I've never liked the zinger props, seems to give a high load and low trust. Both MAS and APC are better then I think. The Bully props that looks like APC are quite nice too and comes in sizes in between most other props.
Hide Signatures
(in reply to AMB)
       Post #: 17
RE: ASP 15 diesel - 11/11/2012 9:15 PM
AMB
Score: 110
Status: offline
Mr Cox found a black MAS 8x5 just re- ran 14500 also used fresh fuel when I did the run last 2 oz in can so quite sure ether loss too martin
think thats more like it
Hide Signatures
       Post #: 18
RE: ASP 15 diesel - 11/11/2012 9:20 PM
Recycled Flyer
Score: 101
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: qazimoto
Hi Ray,
         looks like the one he showed me 12 months ago at Mannering Park, did it take that long to get sorted?
And they do like very 'finished' don't they?
Thanks.
Hide Signatures
       Post #: 19
RE: ASP 15 diesel - 11/11/2012 9:22 PM
Mr Cox
Score: 102
Status: online
Well that sounds more normal.
Another thought, what fuel did you use in the Irvine engine that didn't perform so good either?
Hide Signatures
(in reply to AMB)
       Post #: 20
RE: ASP 15 diesel - 11/11/2012 9:27 PM
AMB
Score: 110
Status: offline
Mr Cox do not recall are you refering to the Irvine 20?? I got used so so on compression?? martin
Hide Signatures
       Post #: 21
RE: ASP 15 diesel - 11/11/2012 9:32 PM
AMB
Score: 110
Status: offline
HEY RAY any runs yet on that beauty??? my guess will surpass my oldie martin
Hide Signatures
(in reply to AMB)
       Post #: 22
RE: ASP 15 diesel - 11/11/2012 10:16 PM
qazimoto
Score: 100
Status: offline
quote:
Hi Ray,
Thanks.
Chris,
I don't think he had it that long ago. You may be thinking of the MVVS 15 glow converted to diesel with the Parra head.
The engine may get a test run this week.
Ray
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 23
RE: ASP 15 diesel - 11/11/2012 10:24 PM
fiery
Score: 100
Status: offline
Running report awaited with interest Ray.
Hide Signatures
       Post #: 24
RE: ASP 15 diesel - 11/11/2012 11:26 PM
AMB
Score: 110
Status: offline
re looking at the low numbers think the low RPMs gotten 2 factors, the wood zingers and ether loss using the last bit in the can, on the fuel alone may have cost 500 rpm loss it came back like a champ on fresh fuel and APC prop, martin
Mr Cox pointed out the woos prop issue
Hide Signatures
(in reply to fiery)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> ASP 15 diesel
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
