CA Kicker Home Brew?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> CA Kicker Home Brew?
Page: [1]
Login
CA Kicker Home Brew? - 11/11/2012 3:53 AM
DenverJayhawk
Score: 193
Last Login: 5/23/2013
Status: offline
A little while ago someone posted a recipe for a home made solution for CA kicker. I think it was baking solution and water with another ingredient. If anyone has it, can they post it again please?
Thanks.
Hide Signatures
       Post #: 1
RE: CA Kicker Home Brew? - 11/11/2012 4:15 AM
foodstick
Score: 177
Last Login: 5/24/2013
Status: offline
I have sprinkled baking soda powder on the glue before.. instead of a liquid...
Hide Signatures
(in reply to DenverJayhawk)
       Post #: 2
RE: CA Kicker Home Brew? - 11/11/2012 4:57 AM
Live Wire
Score: 6329
Status: offline
Boil baking soda in water and use as spray!
_____________________________
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to foodstick)
       Post #: 3
RE: CA Kicker Home Brew? - 11/11/2012 6:01 AM
DenverJayhawk
Score: 193
Status: offline
that's all it is? Boiled solution of water and baking soda?
Hide Signatures
(in reply to Live Wire)
       Post #: 4
RE: CA Kicker Home Brew? - 11/11/2012 6:51 AM
foodstick
Score: 177
Status: offline
Probably is, all you need is baking soda ...
Hide Signatures
       Post #: 5
RE: CA Kicker Home Brew? - 11/11/2012 9:13 AM
Live Wire
Score: 6329
Status: offline
That is all the guy posted on the thread let it set for a while, then put it in your sprayer and spray it,
Larry K AMA 36417
Hide Signatures
       Post #: 6
RE: CA Kicker Home Brew? - 11/11/2012 5:10 PM
Hossfly
Score: 443
Status: offline
quote:
ORIGINAL: DenverJayhawk
Thanks.
For fun, if you need to fill a crack or such, rub some baking soda in it and hit with CA. Don't let the little bomb-smoke into the nose. Very irritating. Kind of cute though.
Horrace Cain AMA L-93
“Peace is the brief glorious moment in history when everyone stands around reloading." T. Jefferson
Hide Signatures
       Post #: 7
RE: CA Kicker Home Brew? - 11/11/2012 9:00 PM
DenverJayhawk
Score: 193
Status: offline
anyone know the ratio of water to baking soda?
Hide Signatures
(in reply to Hossfly)
       Post #: 8
RE: CA Kicker Home Brew? - 11/12/2012 12:37 AM
foodstick
Score: 177
Status: offline
Oh by the way, someone once posted they were using an eye dropper to accurately kick CA, instead of using the SHOTGUN effect out of the spray bottle !
you spray you pay !
Hide Signatures
       Post #: 9
RE: CA Kicker Home Brew? - 11/12/2012 12:45 AM
flyinwalenda
Score: 157
Status: online
One ounce of water to one teaspoon full of baking soda is a good ratio.
Brian Ray
Hide Signatures
       Post #: 10
RE: CA Kicker Home Brew? - 11/12/2012 5:38 AM
DenverJayhawk
Score: 193
Status: offline
quote:
ORIGINAL: flyinwalenda
Thank you!
Hide Signatures
(in reply to flyinwalenda)
       Post #: 11
RE: CA Kicker Home Brew? - 11/12/2012 6:36 PM
opjose
Score: 280
Status: offline
Interesting thread.
I know that CA does pretty well when moisture is present.
But that said most of the accelerators seem to use aromatic esters of some sort.
DenverJayhawk let us know how it works out.
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 12
RE: CA Kicker Home Brew? - 11/12/2012 8:47 PM
Live Wire
Score: 6329
Status: offline
I tried it today and it did not work The soda does not disolve in the water and seperates to the bottom. The water will not work alone and the paste in the bottom is like useng straigh soda. You need a dremel to get it smooth
NEXT
Larry K AMA 36417
Hide Signatures
       Post #: 13
RE: CA Kicker Home Brew? - 11/13/2012 12:11 AM
tacx
Score: 109
Status: offline
I don't understand this "kicker" thing. I have built many planes and have never found a need for it. Thin CA sets almost immediately and gap filling CA only takes a minute or two. Why would I want the glue to set up any faster?
Hide Signatures
       Post #: 14
RE: CA Kicker Home Brew? - 11/13/2012 12:18 AM
Live Wire
Score: 6329
Status: offline
Some CA's are not refined as much a others or are old, which will cause them to set slower. Some people use kicker to help bridge gapps.
Larry K
Larry K AMA 36417
Hide Signatures
(in reply to tacx)
       Post #: 15
RE: CA Kicker Home Brew? - 11/13/2012 5:03 AM
DenverJayhawk
Score: 193
Status: offline
quote:
ORIGINAL: tacx
I don't understand this ''kicker'' thing. I have built many planes and have never found a need for it. Thin CA sets almost immediately and gap filling CA only takes a minute or two. Why would I want the glue to set up any faster?
I use it in the field when repairing my depron foamies. If I snap a wing, I just hit it with some CA and give a spray of kicker and i'm back in the air in less than a minute. That way you don't have to wait for a couple minutes while holding the broken pieces together. It sets instantly. Be sure to use foam safe CA though.
Hide Signatures
(in reply to tacx)
       Post #: 16
RE: CA Kicker Home Brew? - 11/16/2012 12:52 AM
bikerbc
Score: 116
Status: offline
What I did was boiled a few tablespoons of baking soda in about a cup of water and then let it cool and settle ... Then I put the clear liquid thru a coffee filter and into my little glass storage bottle.. From there I fill my little spray bottle when it is empty...I dont use much and it tends to need shaking up from time to time but it works great....I could probably cut down on the amount of baking soda I use... I also find that you only need to get the water hot enough to disolve the baking soda , you dont really need to boil it..
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
       Post #: 17
RE: CA Kicker Home Brew? - 11/16/2012 4:39 PM
DenverJayhawk
Score: 193
Status: offline
thanks, Bikerbc. I'll try that.
Hide Signatures
(in reply to bikerbc)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
