Engine "play" from the prop hub.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Engine "play" from the prop hub.
Page: [1]
Login
Engine "play" from the prop hub. - 11/11/2012 9:56 PM
lechuza
Score: 100
Last Login: 5/15/2013
Status: offline
Hello, I have a RCG 26cc gas engine and since received it I noted a small "play" when pulling a bit the prop hub or even by the propeller, but flown many hours without any issue.A few days ago I broke the prop shaft by tighting the propeller lock nut too much, so I got a new prop shaft and after mounting it on the engine, I have noted that the play I had before still persist but now a bit more that the first time.I can pull the prop hub about 1mm.I flew the engine today and all looks fine but I need to know if that play is normal, or could be an indication of a possible engine problem or about to develop by some internal part like the bearings, etc.
It is recomended to open the engine looking for some loose part?, or even is better to replace the bearings?
Thanks, Schaye
Hide Signatures
       Post #: 1
RE: Engine - 11/11/2012 10:43 PM
Old Fart
Score: 158
Last Login: 5/24/2013
Status: online
It is normal to have a little back and forth movement in the crankshaft.
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to lechuza)
       Post #: 2
RE: Engine - 11/12/2012 4:39 PM
Cyberwolf
Score: 655
Status: offline
What kind of engine are we talking about here?
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to Old Fart)
       Post #: 3
RE: Engine - 11/12/2012 5:28 PM
w8ye
Score: 318
Status: offline
The original post was about a RCG 26
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Cyberwolf)
       Post #: 4
RE: Engine - 11/12/2012 6:07 PM  1 votes
Cyberwolf
Score: 655
Status: offline
Sorry I missed that, anyway to much end play is in direct relation to the bearings, and the machine work. If things are off a little new bearing's won't help things out much if any, but on the other hand if it's just bearing wear a new set would fix the issue. Bearing's for these smaller engines are cheap and not hard to replace.
RC Bearings.com or Boca Bearings should have what you need.
Hide Signatures
(in reply to w8ye)
       Post #: 5
RE: Engine - 11/13/2012 4:25 AM
lechuza
Score: 100
Status: offline
Thanks for your help and suggestions.I will continue using the engine to see if something develops and I will keep it posted.
Hide Signatures
       Post #: 6
RE: Engine - 11/13/2012 5:03 AM
w8ye
Score: 318
Status: offline
What you would be more interested in is if the "slack" increases over what you now know it to be.
Original AMA #31261
Hide Signatures
       Post #: 7
RE: Engine - 11/13/2012 1:12 PM
Old Fart
Score: 158
Status: online
The op says he has overdone things a bit re tightening the prop nut.It may have seated one of the crankshaft bearings closer to the engine case so you would expect the crankshaft to have more to and fro movement if you get fussy.If the op can grab the prop tips and wiggle the crankshaft via the prop and hear a faint Kashhing! kashing(cash)big bearing clearance sound throw the bearings mate
Hide Signatures
(in reply to w8ye)
       Post #: 8
RE: Engine - 11/13/2012 1:35 PM
R/C Addiction
Score: 100
Last Login: 5/22/2013
Status: offline
Sorry...post deleted...thought it was RCGF...
Hide Signatures
       Post #: 9
RE: Engine - 11/13/2012 2:05 PM
ahicks
Score: 669
Status: offline
It is. They're the same...
Hide Signatures
(in reply to R/C Addiction)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Engine "play" from the prop hub.
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
