Hobbistar 60 - Tail dragger conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> Hobbistar 60 - Tail dragger conversion
Page: [1]
Login
Hobbistar 60 - Tail dragger conversion - 11/12/2012 2:52 AM
grosbeak
Score: 140
Last Login: 5/22/2013
Status: offline
Now that the wing repair is complete, I'm turning my attention to the next project for this plane - converting it from conventional tricycle gear into a tail dragger.
The first step was to remove all of the stock landing gear.
_____________________________
MAAC 83386
Stetson Flyers, Ottawa
Hide Signatures
       Post #: 1
RE: Hobbistar 60 - Tail dragger conversion - 11/12/2012 3:01 AM
grosbeak
Score: 140
Status: offline
Next step: Filling in the main gear channel with some scrap.
I went with a Sullivan tail wheel. The original idea was to have it castering, but a closer look at the tail presented a different solution - taking a notch out of the elevator.
The notch was centred, but the stripes weren't.
Re-covered...
MAAC 83386
Hide Signatures
(in reply to grosbeak)
       Post #: 2
RE: Hobbistar 60 - Tail dragger conversion - 11/12/2012 3:08 AM
grosbeak
Score: 140
Status: offline
After the notch was cut and covered, I ground off the heads of the plastic tail bolts, possible because the horizontal and vertical stabilizers are epoxied in place. Once that was done, I re-covered the tail.
The tail wheel bracket was mounted with four servo screws...
... and the steering arm was connected to the rudder.
MAAC 83386
Hide Signatures
       Post #: 3
RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 1:11 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Cool, I did the same with my Tower Trainer 40 but left the tailwheel to caster , it worked OK for my flying field but your solution is quite elegant.
The plane flew a lot better as a taildragger but it still sucked and I am glad it finally crashed and burned.
I now have a Nexstar and its much better, maybe I can make it a taildragger too?
Click to see fullsize image.
Click for fullsize
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
       Post #: 4
RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 3:16 AM
grosbeak
Score: 140
Status: offline
Jeffie, there's a guy named chuebner on RC Canada who has converted his NexStar - check out this post for pictures.
MAAC 83386
Hide Signatures
(in reply to jeffie8696)
       Post #: 5
RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 11:23 AM
grosbeak
Score: 140
Status: offline
On to the main gear. The first step was to decide on the orientation. I chose to have it sweep back.
There are calculations you can do to determine where the gear should go. After a lot of thought, research and advice I decided that placing the axles directly beneath the leading edge (in a level attitude) was the solution for me. To that end, I followed these steps.
  • Eyeball the placement of the gear on the fuse
  • Mark the leading edge of the gear on one side of the bottom, 5mm from the edge
  • Insert a t-pin at the mark
  • Roughly across the bottom from the t-pin, make a short line parallel to the edge and 5mm from it
  • Pick a forward point on the fuse. Measure halfway across the bottom and insert the t-pin there
  • Measure the distance between the two t-pins
  • Mark the same distance from the forward -pin to where it intersects the 5mm line drawn in step 4.
  • Insert a third t-pin at the mark
  • The line between the two rearmost t-pins forms an accurate leading edge location for the gear
    MAAC 83386
    Hide Signatures
  •        Post #: 6
    RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 11:28 AM
    grosbeak
    Score: 140
    Status: offline
    With the leading and trailing edges of the gear marked, the covering came off the bottom.
    There was a small gap at one point where a razor blade could be worked in...
    ... but first the bottom had to be cut across. A fine-toothed back saw worked well.
    MAAC 83386
    Hide Signatures
           Post #: 7
    RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 11:34 AM
    grosbeak
    Score: 140
    Status: offline
    With the crosscuts done, a razor blade fit nicely into the gap.
    A small scraper soon followed.
    With some gentle encouragement, the bottom plate came off the fuse with little damage.
    Turns out I had a hardwood block that was the perfect depth and width - it just had to be cut to length.
    MAAC 83386
    Hide Signatures
           Post #: 8
    RE: Hobbistar 60 - Tail dragger conversion - 11/13/2012 11:45 AM
    grosbeak
    Score: 140
    Status: offline
    I used 30 minute epoxy to secure the block.
    While it was curing, I turned my attention to the gear itself. Drilled out the axle holes...
    ... test fit the axles...
    ... and marked the centre line.
    MAAC 83386
    Hide Signatures
           Post #: 9
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 2:28 AM
    grosbeak
    Score: 140
    Status: offline
    I put the tail wheel on before work this morning - couldn't wait to see how it looked.
    I made a drilling template for the main gear based on the location of the hardwood block.
    Got the holes marked and ready for drilling.
    MAAC 83386
    Hide Signatures
           Post #: 10
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 2:43 AM
    grosbeak
    Score: 140
    Status: offline
    With the holes marked it was time to lug my trusty drill press to the bench.
    A little protection...
    Started with the pilot holes.
    Then to an 11/64" bit for the #8 wood screws.
    MAAC 83386
    Hide Signatures
           Post #: 11
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 2:48 AM
    grosbeak
    Score: 140
    Status: offline
    Time for one of my favourite tools - the transfer punch.
    Holes marked.
    Started with a pin vise...
    ... finished with a hand drill and 3/32" bit, marked with tape for a 1/2" depth.
    MAAC 83386
    Hide Signatures
           Post #: 12
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 2:53 AM
    grosbeak
    Score: 140
    Status: offline
    For#8 wood screws I'm not sure it's necessary to pre-thread the holes and drizzle in some CA, but I've gotten into the habit with RC so I went ahead.
    After that came the covering, then the main gear.
    I cut some brass tubing to bridge the gap between axle size and wheel bore.
    Then onto its new legs for the first time!
    MAAC 83386
    Hide Signatures
           Post #: 13
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 5:37 AM
    jeffie8696
    Score: 120
    Status: offline
    I run a lot of four strokes and having the improved ground clearance to swing a big prop is important to me. I also fly off tall grass sometimes and it makes a big difference with a tail dragger.
    Hide Signatures
           Post #: 14
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 11:09 AM
    grosbeak
    Score: 140
    Status: offline
    quote:
    ORIGINAL: jeffie8696
    I hear you. This plane is powered by an OS 65 LA 2-stroke running a 12 x 6 prop, but I whacked the grass with it plenty of times while I was learning on it with trike gear. Had to replace the nose gear a couple of times too.
    MAAC 83386
    Hide Signatures
           Post #: 15
    RE: Hobbistar 60 - Tail dragger conversion - 11/15/2012 4:28 PM
    jeffie8696
    Score: 120
    Status: offline
    I just hate it when my plane turns green from mowing the grass with the prop.
    Hide Signatures
           Post #: 16
    RE: Hobbistar 60 - Tail dragger conversion - 11/18/2012 4:38 AM
    grosbeak
    Score: 140
    Status: offline
    Together again for the first time.
    Just a little nose heavy at the rearmost point of the CG range.
    MAAC 83386
    Hide Signatures
           Post #: 17
    RE: Hobbistar 60 - Tail dragger conversion - 11/18/2012 2:54 PM
    jeffie8696
    Score: 120
    Status: offline
    Looks great, hope it flies as well as it looks.
    Hide Signatures
           Post #: 18
    Page:   [1]
    Page: [1]
    Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.797RCU1
