FE no more got a nitro outboard    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> FE no more got a nitro outboard Page: [1]
Login
FE no more got a nitro outboard - 11/12/2012 7:41 AM
Thunder nut
Score: 100
Last Login: 11/30/2012
Status: offline
Hello all,
Well I have taken the plunge after no sucess at all with a FE system on my VS1 I have taken the plunge into the world of nitro outboards. I bought a new Thunder tiger Pro as that was most of the budget gone.
My question is about starters, do I need a 12 volt hand held starter or can I buy from somewhere an adaption for a cordless drill so I dont need to cary a car battery with me, and I already have the cordless drill.
Cheers
Hide Signatures
       Post #: 1
RE: FE no more got a nitro outboard - 11/12/2012 3:26 PM
advanced builder
Score: 105
Last Login: 6/16/2013
Status: offline
guys are using a 18 volt battery pack from your hand drill. Adding that to the starter Some add a older 4 wheeler starter. Or make your own ,and go wireless.
http://www.mcmaster.com/#catalog/118/903/=k4rssv
DC Voltage High-Amp Relays part #7995K42
Look down at the bottom of the page for a layout.
http://www.rcuniverse.com/forum/m_9801940/mpage_71/key_/tm.htm
_____________________________
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
(in reply to Thunder nut)
       Post #: 2
RE: FE no more got a nitro outboard - 11/12/2012 3:28 PM
LostParts
Score: 100
Last Login: 12/1/2012
Status: offline
I bought a replacement cone for a starter ( I believe a dubro) and use a drill on most of my nitro boats.  I don't believe it has the torque of a good aircraft starter but it will  fire up a 3.5 outboard no trouble.
Double Gun Pro
Hide Signatures
       Post #: 3
RE: FE no more got a nitro outboard - 11/13/2012 12:46 AM
Blackout
Score: 100
Last Login: 6/18/2013
Status: offline
Some new engines can be hard to turn over with the starter because of a tight piston/liner fit. If this is the case with your Thunder Tiger, you can heat the head with a heat gun. This expands the sleeve and makes it easier to start the engine. I had to do this with my O.S. when I replaced the piston/sleeve with new ones.
Once the engine is broken in, the starter needs very little amps to get the engine going.
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
(in reply to LostParts)
       Post #: 4
RE: FE no more got a nitro outboard - 11/18/2012 5:45 AM
Ron Olson
Score: 1175
Last Login: 6/17/2013
Status: offline
A new or hard-to-start engine can be cranked over easier if you loosen the glow plug.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to Blackout)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
