Gyrobot 3-axis gyro    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Gyrobot 3-axis gyro
Page: [1]
Login
Gyrobot 3-axis gyro - 11/12/2012 2:49 PM
SpiderJets
Score: 105
Last Login: 4/30/2013
Status: offline
Just curious.
Does somebody here have real hands-on experience with the Gyrobot ? Good ?
_____________________________
Memory Cards and Nano Turbines. The only two objects men like to brag about theirs is smaller.
Hide Signatures
       Post #: 1
RE: Gyrobot 3-axis gyro - 11/12/2012 4:19 PM
gerhard
Score: 100
Last Login: 5/14/2013
Status: offline
perfect- more than 120 flights, 70 flights with turbine jet, 50 flights with carf extra 2,12. go for it
gerhard
Hide Signatures
(in reply to SpiderJets)
       Post #: 2
RE: Gyrobot 3-axis gyro - 11/12/2012 4:33 PM
lookilook
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Nicolas, a friend of mine is using it in Cyprus on his sebart Katana for a year now and he is very happy, he has also purchased one for his jet and  i also bought it for my TD viper....not finished yet.
Rgds Nicos
OWNER OF
F16 1/8 K80E
Hide Signatures
       Post #: 3
RE: Gyrobot 3-axis gyro - 11/12/2012 5:33 PM
cairoman
Score: 100
Status: offline
quote:
ORIGINAL: lookilook
Rgds Nicos
He knows him! It's Mario, the Astronaut!
Chris
IJMC-Cyprus,
JEt-Tronics, Kingtech Turbines, Jets-Munt, FADEC, Grumania Jets
Hide Signatures
(in reply to lookilook)
       Post #: 4
RE: Gyrobot 3-axis gyro - 11/12/2012 6:01 PM
lookilook
Score: 100
Status: offline
hehe you'll never change Chris.!!!
OWNER OF
F16 1/8 K80E
Hide Signatures
(in reply to cairoman)
       Post #: 5
RE: Gyrobot 3-axis gyro - 11/12/2012 6:35 PM
POWER JET
Score: 100
Last Login: 5/16/2013
Status: offline
I was wondering,why ,you guys do you need a gyro?
You don't know how to fly the planes?
No excuses...!
Hide Signatures
       Post #: 6
RE: Gyrobot 3-axis gyro - 11/12/2012 8:28 PM
cairoman
Score: 100
Status: offline
quote:
ORIGINAL: POWER JET
Άλα....τα δυνατά σχόλια!!!!!
The reason for using three axis gyros, is to stabilise your toy, when you perform manoeuvres, your toy is not capable of and Mother Earth keeps calling it back!
Αντε νανάκια τώρα!
IJMC-Cyprus,
Hide Signatures
(in reply to POWER JET)
       Post #: 7
RE: Gyrobot 3-axis gyro - 11/12/2012 11:08 PM
rcand
Score: 105
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: POWER JET
Knowing how to fly may mean you can take off and land without doing repairs or it could mean you look like an expert. For the majority of us how are in-between the 2, the gyro makes it look like we are experts, or at least better than those who can fly but are not smooth in their manuevers or look like experts.
Hide Signatures
       Post #: 8
RE: Gyrobot 3-axis gyro - 11/13/2012 5:23 AM
POWER JET
Score: 100
Status: offline
Γιατι παρεξηγηθηκες φιλε Κυπριε?Οποιος εχει την μυγα μυγιαζεται λεει μια παροιμια και την επιβεβαιωνεις πληρως απο οτι φαινεται!!
I know what a gyro do my friend!!  But it seems you don't know how to fly so you need the help from electronics!!
I never use a gyro even if  the plane was 3D or a jet.
If you afraid the gravity then you better go to the moon and fly free!!
< Message edited by POWER JET -- 11/13/2012 6:05 AM >
No excuses...!
Hide Signatures
       Post #: 9
RE: Gyrobot 3-axis gyro - 11/13/2012 5:59 AM
POWER JET
Score: 100
Status: offline
No excuses...!
Hide Signatures
       Post #: 10
RE: Gyrobot 3-axis gyro - 11/13/2012 6:01 AM
POWER JET
Score: 100
Status: offline
Double post... please delete...
No excuses...!
Hide Signatures
       Post #: 11
RE: Gyrobot 3-axis gyro - 11/13/2012 6:21 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: rcand
quote:
ORIGINAL: POWER JET
You don't know how to fly the planes?    www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" src="" />
I fly rc airplane models for 20 years now!I never used a gyro!Never needed!The secret is practice...practice...practise.!!!
You don't need the electronics!!Learn how you to stabilized your aircraft by your hands and not with a gyro!!
The gyro will make you a worst pilot and never a better one!!
No excuses...!
Hide Signatures
(in reply to rcand)
       Post #: 12
RE: Gyrobot 3-axis gyro - 11/13/2012 7:29 AM
cairoman
Score: 100
Status: offline
Μήν με τσιγκελίζεις....θα πάρω αεροπλάνο και θα έρθω εκεί πάνω, να μου δείξεις πώς πετάς εσύ, μεγάλε Μοντελλιστή! Αντε και είδαμε τα κατορθώματά σου στο YouTube!
Υ.Γ. Ελα κάτω, στην Κύπρο να σου δείξουμε πώς να προσγειώνεις HK-L59 !!
Chris
IJMC-Cyprus,
Hide Signatures
       Post #: 13
RE: Gyrobot 3-axis gyro - 11/13/2012 8:06 AM
rctech2k7
Score: 115
Last Login: 4/16/2013
Status: offline
Look like a curious question but now it's different when somebody wants to answer your question... I believe you found an answer to your question however the second one if you apply your analogy based on logic analysis it will prove your limitation including that your answer is wrong.
To advice that practice makes it perfect is a helpful one. Regardless of the skills a more properly setup aircraft is an advantage. We used natural stability and mechanical way on setting up our aircraft that's why we don't see the need for gyro so far but we can't deny the fact that technology is advancing and electronics is replacing some of its function. The good thing we got more options for our aircraft's stability as long as it complies safety and reliability against mechanical and human factor... Check on heli before they don't use gyro but now expert heli pilots are using them and found it more advantage, better skills and capability. Feel free to use either option depending on your preference and rules, gyro technology is not new to full scale and those expert pilots are using them...
< Message edited by rctech2k7 -- 11/13/2012 8:36 AM >
More than just sports, hobby and recreation, it’s technology…
Hide Signatures
       Post #: 14
RE: Gyrobot 3-axis gyro - 11/13/2012 8:46 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: cairoman
Chris
δεν μπορω να καταλαβω γιατι παρεξηγησες αυτο που ειπα?Ηταν μια απλη ερωτηση απο μερους μου και εσυ το εκανες ολοκληρο θεμα!!
Και οσον αφορα το L59 βαλε και εσυ μια P20 πανω,και μεχρι να βρεις που θα το κεντροβαρισεις,που πρεπει να εξισοροπησεις την διαφορα της 6cells μπαταριας και μετα ελα πες μου!!Θα σου στειλω βιντεο να μαθεις εσυ να προσγειωνεις το L59!!Μεγαλε Δασκαλε!!
Εισαι πολυ νευρικος παντως και θα σου κανει κακο στην υγεια σου!!
No excuses...!
Hide Signatures
       Post #: 15
RE: Gyrobot 3-axis gyro - 11/13/2012 8:52 AM
marc s
Score: 110
Status: offline
I am not a regular flyer and don't own a gyro but having built a few jets in my time there are some kits out there which have 'tendancies' which are not easy to mix out or manually control with sticks so the addition of a gyro, I read, adds the stability inputs needed to get the jet (or plane) to fly normally whilst the pilot does his flying thing - in these cases I suspect a gryo is invaluable.
For those who use it for fun then cool, we have choices and pockets
marcs
Hide Signatures
(in reply to rctech2k7)
       Post #: 16
RE: Gyrobot 3-axis gyro - 11/13/2012 10:38 AM
DelGatoGrande
Score: 105
Status: offline
A gyro will outfly the best pilot.
It dramatically reduces workload and cures dutch rolling that its impossible to be corrected by the best pilot.
Any modeller with a 20year experience should have known that by now.
Problem with gyros and jets is the wide speed range this models fly and if the gain is not correct it will destroy/flutter from over-compensating your surfaces.
The best gyro IMHO is the new 3 axis iGyro from PowerBox with the GPS sensor that takes constant speed reading and adopts to the needs of the jet.
http://powerbox-systems.com/e/powerbox_systeme/powerbox_igyro/start.php
Im considering geting one, for one of my big toys since i have a problem during landing ,from fuel moving in big tanks and changing my CG.
I dont know if its because my experience is less than 20years but
bear in mind that this been sed by someone with rudder skills to hover and harrier roll a 50% aerobatic all day long.
p.s. FAI F4G world championship allowed the use of 3axis gyros this year
Here is the master flying the new PowerBox iGyro
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to marc s)
       Post #: 17
RE: Gyrobot 3-axis gyro - 11/13/2012 1:17 PM
cairoman
Score: 100
Status: offline
quote:
ORIGINAL: POWER JET
quote:
ORIGINAL: cairoman
Chris
Τίποτα από όλα αυτά, δεν ισχύει!! Απλά σπάω πλάκα μαζί σου!
IJMC-Cyprus,
Hide Signatures
       Post #: 18
RE: Gyrobot 3-axis gyro - 11/13/2012 1:35 PM
Dr Honda
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: POWER JET
quote:
ORIGINAL: cairoman
Chris
TRANSLATION.....
"I can not understand why they misunderstand what I said; It was a simple question of me and You did ENTIRE issue!
And regarding the L59 came a Jack, and P20 over, until you find that the (CG?) that the ballast must be of different 6cells battery and Then come tell me!'ll Send video to learn thou lands L59!! great teachers!
You're very nervous, however, and I will do harm to your health!"
I'm not trying to be harsh... but this is an English speaking board. AND... since it's a "Public" forum... it should remain that way. You guys can email if you want it to be privet.
OK... back to the debate...
There is nothing wrong with using a gyro. The heli guys have been using them for a VERY long time. But... when you use a 3 axis gyro in a large turbine model... it really is a crutch for a lesser skilled pilot.
With that said... for a sport flyer, or a tippy air frame... there is nothing wrong with it. (as long as they aren't being used in competition) I personally have one of the new EagleTree 3D systems coming... and will be playing with it in the spring.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 19
RE: Gyrobot 3-axis gyro - 11/13/2012 2:00 PM
basimpsn
Score: 120
Status: offline
I wonder what kind of 3D advantage I would get using a 3-axis gyro on my 35% yak?.. For example would it fight my Rollng Harrier inputs?, Flat Spins. I know it will help with my strugging hover
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to Dr Honda)
       Post #: 20
RE: Gyrobot 3-axis gyro - 11/13/2012 5:59 PM
Robrow
Score: 100
Status: offline
quote:
ORIGINAL: POWER JET
quote:
ORIGINAL: rcand
quote:
ORIGINAL: POWER JET
You don't know how to fly the planes?    www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' src='''' />
Practice is all well and good but for many of us time is a precious commodity. So why not use the help that a gyro can give?
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 21
RE: Gyrobot 3-axis gyro - 11/13/2012 8:21 PM
invertmast
Score: 193
Status: offline
It must be winter time.... Which means time to order more popcorn
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to Robrow)
       Post #: 22
RE: Gyrobot 3-axis gyro - 11/13/2012 11:31 PM
JoeEagle
Score: 100
Last Login: 5/13/2013
Status: offline
how about a comparison with the gyrobot vs the iGyro
feature for feature-not if you're a wienie if you use a gyro.
i know i need more help (ok maybe alot!)
thanks
Joe
Hide Signatures
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
