SURPRISE: Redline oil might not be the best out there    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> SURPRISE: Redline oil might not be the best out there
Page: [1]
Login
SURPRISE: Redline oil might not be the best out there - 11/12/2012 2:58 PM
q8cub
Score: 100
Last Login: 4/21/2013
Status: offline
To my surprise, after doing tests on two engines: dle-55 and dle-111 using redline oil and ACE synthetic oil, here are the results,
DLE 55 (on an extra with fair air ventilation)
Redline: temp range 96-106
ACE: temp range 86-96
DLE-111 (on a yak - no baffles used)
Redline: temp range 122-130!!!
ACE: temp range 98-118
Temps are in Celsius.
Conclusion: In general the ACE oil gave a 10-20 degrees difference!!! in both engines
Note: for the dle-111, I checked the needles and the low was 1 turn while the high was 3/4 turn. This is a difference of minus 1/4 turn for the low and 3/4 for the high!!! I think it was too lean. The reason I got this lean was to raise the RPM to 6000 (it was around 5400) plus the engine was spitting black oil residue so I thought it could have been too rich!
Now I am confused:
1- Is ACE oil better than Redline?
2- Was the dle-111 too lean? I guess 130 is too dangerously high temp!!
3- Are there any factors other than engine temp to gauge the quality of an oil?
Thanks in advance!
Note: I searched for the ACE synthetic oil in the gas engines forum and did not find a single trace of it!!! Anyone heard of it ?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:31 PM
karolh
Score: 310
Last Login: 5/23/2013
Status: offline
For the comparison to really have much merit your the oil tests should be carried out using the same engine and model. I have never heard anyone say that Red Line oil was the best, but rather that is very good. Just my 02 cents.
Karol
_____________________________
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to q8cub)
       Post #: 2
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:32 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
First thing I wonder is, was the RPM the same the same with both oils? maybe the temp was up because because the RPM was up?
David
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to q8cub)
       Post #: 3
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:37 PM
BarracudaHockey
Score: 280
Status: offline
And what did the engines look like inside after being flown for a few gallons and torn down?
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:40 PM
q8cub
Score: 100
Status: offline
quote:
ORIGINAL: daveopam
David
good point!
I will test this next time at the field.
So, your logic is like this. Redline allows the engine to provide higher RPM so this could be why it is giving higher temp!?
So, is the temp the only factor that gauges an oil type?
Hide Signatures
       Post #: 5
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:47 PM
q8cub
Score: 100
Status: offline
quote:
ORIGINAL: BarracudaHockey
for the dle-111, I only flew it 3 flights with a new needle setting which was I think too lean. So, I hope no damage has been done. I bring the needles back to factory setting improve air flow around the cylinders.
Any suggestions on where to go from here regarding the dle-111 ?
Should I continue using redline at 40:1 (with richer setting and better air ventilation)?
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 6
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 3:48 PM
q8cub
Score: 100
Status: offline
quote:
ORIGINAL: q8cub
for the dle-111, I only flew it 3 flights with a new needle setting which was I think too lean. So, I hope no damage has been done. I will bring the needle back to factory setting improve air flow around the cylinders.
Hide Signatures
(in reply to q8cub)
       Post #: 7
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 4:15 PM
All Day Dan
Score: 151
Last Login: 5/21/2013
Status: offline
q8, how did you measure the temperatures? Dan.
Dan
Hide Signatures
(in reply to q8cub)
       Post #: 8
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 4:30 PM
q8cub
Score: 100
Status: offline
quote:
ORIGINAL: All Day Dan
using a temp gun soon after landing between second and third cyl fins away from the plug. I know this is not the most accurate way of measuring accuracy, but the point here is relative measurements. In other words, using the same method the temp difference is between 10-20 degrees.
One more thing, for the dle-111, I was flying it doing mostly a harrier! Does a harrier cause the engine to heat more than a hover? Since the engine is mostly at idle with less air flow!!
Hide Signatures
(in reply to All Day Dan)
       Post #: 9
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 5:34 PM
w8ye
Score: 318
Status: online
The difference in temperature is because the engine was running leaner with the Red Line oil.
Red Line oil is all synthetic and contributes less to combustion than the Synthetic/mineral oil blends like the ACE Synthetic Blend oil.
Other than the mixture being wrong with one test, the temperature measurements mean nothing.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to q8cub)
       Post #: 10
RE: SURPRISE: Redline oil might not be the best out there - 11/12/2012 6:41 PM
closetguy
Score: 166
Status: offline
i am not buying into this until you do the test on the same engine,tuned the same,prop the same,and use a better way to measure the heat, and at a longer period of run time.also how long did you run the engines in between the switch in oils,COMON!
Hide Signatures
(in reply to w8ye)
       Post #: 11
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 1:55 AM
earlwb
Score: 584
Status: offline
They are correct in that you need to carefully measure out the oil to mix with the gasoline so it is accurate;y the same quantity with both. Then run your tests using the same engine. Now you could try both oils in one engine and then again in the other engine too. Then you can compare the results better.
That ACE oil is a synthetic and mineral oil blend of oil, it is not 100% synthetic oil.
The best oils I know of are Stihl Ultra and Amsoil Saber Pro, both oils are 100% synthetic and designed for two stroke air cooled engines.
I am sure Europe or Asia has something equivalent to it. Both of these oils don't carbon up the engine with residue deposits or sludge over time either.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to closetguy)
       Post #: 12
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 2:55 AM
avidflyguy
Score: 105
Last Login: 5/22/2013
Status: online
pennzoil aircooled 2 cycle oil, use that in my dle 55 and da 100 with no issues, plus over 1,000 hours of flight time behind rotax 2 strokes in ultralights and a 582 powered avid flyer, synthetics are highly over-rated and its not necessary to spend major bucks on that "special" snake oil(amsoil,redline or whatever) i have 3 local flyers that have engine troubles related to synthetics, 1 used klotz, piston and rings were carboned up so bad( rings stuck) within 30 hours he had to rebuild top end, he switched to pennzoil and has no issues with around 300 hours so far, another had crankshaft failure at 90 hours (amsoil) due to rust developing on bearings. the rotax rebuild center told him to never use amsoil or any straight synthetic oil due to poor corrosion protection due to stuff not being used for long periods of time(pennzoil user now) and lastly a fellow flier had the misfortune of seizing his engine up and having to ditch his ultralight in the river. (amsoil 80 to 1 mix that the amsoil rep told him that "other " fliers were using) i tried talking that flier out of using that low of a mix and go 50 to 1 instead because 80 to 1 isnt enough oil
Hide Signatures
(in reply to earlwb)
       Post #: 13
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 3:58 AM
captinjohn
Score: 247
Status: offline
Pennzoil for Air cooled engines works good for me. I am testing Redline in another engine, but I do not see where it is any better at all.   This plug has seen a lot of Penzoil....and a lot of wide open running....flash on camera made the white look brighter !
Click for fullsize
Click for fullsize
I never met a engine I did not like !
Hide Signatures
(in reply to avidflyguy)
       Post #: 14
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 6:31 AM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
i stopped switching brands and ratios of oil a long time ago.... but when i did change, i would make sure to reset the high end needle..... i also do the same thing when i change props, i learned this from my glow air plane days....different prop loads can change how an engine burns fuel
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to captinjohn)
       Post #: 15
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 10:11 AM
RiverLarry
Score: 100
Status: offline
John  you do  still use   30 / 1   or  32 / 1      on mix ?????   for  DLE !!!!
at least  what the motor MFG.  states  to use on  mix ?????   for motor used
30 /1  is  still   30 /1    is it not   !!!      or am I missing something  hear !!!!
just because  the oil bottle  states    40 /1     it does not mean  it will be the same    as   30 / 1    mix ????      R/L
Hide Signatures
       Post #: 16
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 12:31 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: q8cub
Now I am confused:
Thanks in advance!
I ran high end two stroke engines in adverse conditions and have worked with various oils for many years and most of the decent oils do a great job. Most of it is just preference. The only thing that seems odd sometimes is how one person seems to get better use out of an oil and the other not so good. There are many variables to the equation that have to be weighed in. Sometimes it is just a matter of how the user runs the engine.
The only oils that I would not use are the el-cheapo mock off brands. Those will definitely give you some grief. You have be careful because the oil wars can get started. It is all about the pretty packaging. I stay away from the my oil is better than your oil garbage Back in the day I tested some of the not so good el-cheapo oils and yes, they were not so good. I would pull down my engines and could not hardly get the rings off!
Hide Signatures
(in reply to q8cub)
       Post #: 17
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 12:44 PM
earlwb
Score: 584
Status: offline
Yes I forgot to mention and I do agree that one does not go under 32:1 oil to fuel ratio even though the manufacturer might state the oil would work at 100:1 or 80:1 or even 40:1 for that matter. The extra low oil ratio works if the engine is being used as a weed trimmer or leaf blower, but not as a airplane engine. The airplane engine is being run at its highest power RPMs with its strongest load for a entire flight, time and again, and it really needs the extra oil to keep it lubricated.  I have seen people post pics of failed engines and their connecting rods and needle bearings, showing needle bearings turning blue from the heat, where they were running lower oil ratios.
AMA # 928076
Hide Signatures
(in reply to Luchnia)
       Post #: 18
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 2:16 PM
Lifer
Score: 148
Status: offline
I use 32-1 quality synthetic. An $8 for a quart of oil, at that it rate adds about $1 to the cost of a gallon of mixed fuel. Not much at all. Still beats the heck out of a price of 2-stroke glow fuel. Power differences may or may not come into play, but all my gas engines are still running, and some are 8 years old now.
Hide Signatures
       Post #: 19
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 3:52 PM
pilotpete2
Score: 120
Status: offline
+1,
I buy my gas, Stilh HP Ultra and cholesterol/caffeine fix all within 5 minutes of the field
Wish I could totally dump the glow juice.
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to Lifer)
       Post #: 20
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 4:11 PM
dreamwever
Score: 100
Status: offline
Hello you might look at aeroshell oil sport plus 2 it's made for two stroke airplane engines  rotax airplane right on the lable well worth looking into good flying
Hide Signatures
(in reply to pilotpete2)
       Post #: 21
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 4:29 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: RiverLarry
I use 30-1 always on the DLE30 using Pennzoil. I feel DLE need that much oil!  The plug photo was not a DLE or Mintor and the ratio was 32-1 most of the time.
Hide Signatures
(in reply to RiverLarry)
       Post #: 22
RE: SURPRISE: Redline oil might not be the best out there - 11/13/2012 5:48 PM
RealFly
Score: 105
Last Login: 5/6/2013
Status: offline
Also the use of Redline as recommended by some manufacturers is because it burns cleaner as evidenced by tearing down the engine after some hours as compared to other oils.  That as I understand it was solely the basis for the recommendation.  I do not recall any manufacturer producing data that says one lubes better than the other or produces a higher RPM.
However, generally sythetic oils perform better than most natural oils....
Hide Signatures
       Post #: 23
RE: SURPRISE: Redline oil might not be the best out there - 11/14/2012 1:25 PM  1 votes
closetguy
Score: 166
Status: offline
i use to run pennzoil at 32-1 for years.after three years of runnig it in a dle55 i had to replace the crank and rod,lower rod bearings were bad. not the blame of pennzoil just what happens on the budget engines.
what i did notice is the carbon build up on the top of piston,not much but still there. then when they change the name to Outdoor oil and couldn't find Air Cooled, i just switch to Redline at 32-1,and what i found after running it in another dle55 i had no carbon at all on the top of piston.and it doesn't completely burn off, there is a thick film of it on the cylinder wall.
Hide Signatures
(in reply to RealFly)
       Post #: 24
RE: SURPRISE: Redline oil might not be the best out there - 11/14/2012 2:32 PM  1 votes
acerc
Score: 221
Status: offline
Closetguy, I just broke my DLE down to install a Bowman ring. I have what you describe. No buildup any where of carbon. And a nice layer of oil on everything. I have used from day one Poulan synthetic, aircooled 40-1. So I would have to agree for the most part that most oils are descent enough. I think the ratio, the tune, the prop, and the pilot make just as much difference as the effect of the oil on the engine.
< Message edited by acerc -- 11/14/2012 3:52 PM >
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 25
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> SURPRISE: Redline oil might not be the best out there
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
