RE: Walbro WT-71 Carb?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Walbro WT-71 Carb?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Walbro WT-71 Carb? - 11/16/2012 12:27 AM
Schizted
Score: 100
Last Login: 12/1/2012
Status: offline
 K, got the gaskets on and fuel flows beautifully thru the intake hose up to the primer bulb and back out the return line.
when i prime it off the engine am i suppose to see fuel going into the throat or does that require the pulse from the engine
Hide Signatures
(in reply to Schizted)
       Post #: 26
RE: Walbro WT-71 Carb? - 11/16/2012 1:02 AM
w8ye
Score: 318
Last Login: 5/22/2013
Status: offline
Vacuum from the engine opens the metering valve and makes fuel available at the venturi and along openings along one side of the throttle plate. Some of these are more airflow sensitive than others
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 27
RE: Walbro WT-71 Carb? - 11/16/2012 1:37 AM
All Day Dan
Score: 151
Last Login: 5/21/2013
Status: offline
Good. those are the right ones for my WT-76 carbs. I hope they are the right ones for yours. Dan
Dan
Hide Signatures
       Post #: 28
RE: Walbro WT-71 Carb? - 11/16/2012 9:09 PM
Schizted
Score: 100
Status: offline
OMG! this dang carb, i hooked it up to the engine, try to prime it and no fuel is getting to the engine.
Ive checked the heat dam for clogs and its clear, ive sprayed the hole from the carb hole into the crank case and its clear
the carb will push fuel threw both intake and return line but no fuel will come out anywhere...
Hide Signatures
(in reply to All Day Dan)
       Post #: 29
RE: Walbro WT-71 Carb? - 11/16/2012 10:14 PM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: MetallicaJunkie
i have a wt-71 on my 3w80....im sure you know this...but you might want to make sure the metering fork is engaged on the pump.... some carbs dont have it, but this particular carb does...
what engine do you have it on?
My bet is your 3W80 uses a WJ-71, not the WT-71. The WT series does not have the fork that engages the pin on the metering diaphram. The WT series just pushes against the arm.
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 30
RE: Walbro WT-71 Carb? - 11/16/2012 10:25 PM
Schizted
Score: 100
Status: offline
...? the Walbro WT-71 was stock on my 25cc Homelite weed wacker engine
the wt-340 carb was from another engine i was testing but the venturi is way to small
my WT-71 is not getting any fuel out the venturi
Hide Signatures
(in reply to Truckracer)
       Post #: 31
RE: Walbro WT-71 Carb? - 11/16/2012 10:31 PM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: Schizted
This whole thread has me confused. First, I assume from the past posts this carb has a primer pumb bulb on it. If this is correct, is it on the pump side (most common) or is it on the regulator side of the carb (rare)? If on the pump side, it can only bring fuel to the carb, it will not inject any fuel into the carb venturi. The carb still depends on having a closed choke and the vacuum from the pumping action of the piston in the engine to displace the regulator diaphram and actually suck fuel into the venturi. In short, if the piston is not going up and down, there should be no fuel flow into the venturi of the carb. If fuel could just flow freely, the engine would just flood with fuel as it would siphon from the tank anytime the carb was lower than the tank.
There are some different primer setups used on some of the Walbro carbs that will actually squirt fuel into the venturi, but these are rarely used for RC applications .... and most of the carbs that use this setup don't have choke plates in place. The primer is their only way to get fuel into the engine for starting.
At this point on your learning curve about Walbro carbs, I'd strongly suggest replacing the carb or take it to someone with a great amount of Walbro experience and have them analyze the problem.
Hide Signatures
       Post #: 32
RE: Walbro WT-71 Carb? - 11/16/2012 10:51 PM
Schizted
Score: 100
Status: offline
Well the primer is on the carb, it sits above the metering digaphram.
I close the choke on the engine and prime it and hand prop with no results at all.
ive also tryed rocking the prop back and forth to get the piston moving to suck in fuel no results i understand that thecarb needs a signal from the crankcase, but no fuel is flowing and the heat dam, gaskets are in working order
Im doing this as a home project and a learning experince. i would love to figure this out myself just trying to get as much information as possible from this community.
Hide Signatures
       Post #: 33
RE: Walbro WT-71 Carb? - 11/16/2012 11:10 PM
Truckracer
Score: 304
Status: offline
Has this carb worked for you in the past? If so, how long ago? Did it sit around unused for a long period of time or was it exposed to the elements for long periods.
Hide Signatures
       Post #: 34
RE: Walbro WT-71 Carb? - 11/16/2012 11:23 PM
Schizted
Score: 100
Status: offline
it was a buddy's it sat in hes garage for a year or so, he said it stopped working on him and just bought a new one.
I took it apart to convert it to rc and trim the excess metal and in the process the piston had a ton of carbon on it, cleaned all that off cleaned the engine up and bought all new gaskets,fuel lines,spark plug. lubed the engine with a bit of oil before putting it back togeahter.
dont have a compression tool but id sucks on my finger hard threw the plug hole.
Hide Signatures
       Post #: 35
RE: Walbro WT-71 Carb? - 11/17/2012 4:56 AM
Rick Sowell
Score: 100
Last Login: 5/19/2013
Status: offline
are you getting a pulse signal from the engine? take the carb off and rotate the engine and see if you can feel the pulse from the hole in the crank case. also one other thing, how many turns out are the needles? some carbs need more than the traditional 1 1/2 turns open.
Hide Signatures
       Post #: 36
RE: Walbro WT-71 Carb? - 11/17/2012 4:57 AM
Rick Sowell
Score: 100
Status: offline
what kind of engine is this? it might help us get you more help if we all know what you are using.
Hide Signatures
(in reply to Rick Sowell)
       Post #: 37
RE: Walbro WT-71 Carb? - 11/17/2012 9:57 AM
Schizted
Score: 100
Status: offline
its a homelite 25cc, and yes it sucks air in, and pushes it out of the little hole. the low is 1 1/2 turn and the high is 2 turns
Hide Signatures
       Post #: 38
RE: Walbro WT-71 Carb? - 11/17/2012 2:34 PM
EJJK
Score: 100
Last Login: 1/30/2013
Status: offline
I'm not familiar with your particular Walbro model, but I have experienced a similar problem with Walbro carbs and found the diaphram cover to be warped or bowed. Air leakage at this critical area could be your problem. Check this and ensure it mates perfectly with the carb body. If the cover is questionable, you could resurface it on a flat surface using a fine grit sandpaper (220-400 grit). Hope this helps.
Hide Signatures
       Post #: 39
RE: Walbro WT-71 Carb? - 11/18/2012 11:12 PM
Schizted
Score: 100
Status: offline
Ok, Ive tried 3 diffrent carbs on this engine, one that i jsut pulled off my weed wacker it was a zama i know it works. But when i put it on the engine, prime and rock the prop back and for still no fuel in the cylinder.
It must have something to do with the engine....
Im getting a pulse from the hole in the crankcase the gaskets are all brand new and in there right positions, this might be a stupid question but could i have put the piston on backwards? i dont know what else to try
Hide Signatures
(in reply to EJJK)
       Post #: 40
RE: Walbro WT-71 Carb? - 11/18/2012 11:57 PM
All Day Dan
Score: 151
Status: offline
Some of them have an arrow stamped on the top of the piston that points in the direction of the exhaust. Dan.
Dan
Hide Signatures
       Post #: 41
RE: Walbro WT-71 Carb? - 11/19/2012 10:54 PM
Schizted
Score: 100
Status: offline
IDK anymore, i put a zama carb on it that i know works and was able to get a little fuel into the cylinder by hand propping,
took it outside to really try turning her over, for 30 mins i hand propped over and over, was only able to get a tiny pop from the exhaust once, now it looks like there is no fuel in the cylinder
Hide Signatures
       Post #: 42
RE: Walbro WT-71 Carb? - 11/20/2012 12:43 AM
w8ye
Score: 318
Status: offline
You will be lucky to ever start a magneto ignition Homelite 25 by flipping the prop.  You need an electric starter.
Original AMA #31261
Hide Signatures
       Post #: 43
RE: Walbro WT-71 Carb? - 11/20/2012 1:12 AM
Schizted
Score: 100
Status: offline
any suggestions? and on a bit of a budget
Hide Signatures
(in reply to w8ye)
       Post #: 44
RE: Walbro WT-71 Carb? - 11/20/2012 1:32 AM
w8ye
Score: 318
Status: offline
I have a couple Homelite 30's that look identical to Homelite 25's and they both run nice. One has CH ignition and the other has the original ignition.
The one with the original mageto ignition, you have to use a starter. A friend said that he thought that he could start it by hand flipping because he always started his Zenoah G-38 by hand flipping.
But he couldn't get it started.
For a while I just had a regular Tower starter and it would not turn it over. But if someone would hold the plane for me, I could hold the starter in one hand and flip the prop once with the other hand. This would give it enough speed to start turning the engine over and start it with the starter.
Click to see fullsize image.
Click for fullsize
Original AMA #31261
Hide Signatures
       Post #: 45
RE: Walbro WT-71 Carb? - 11/20/2012 1:45 AM
Schizted
Score: 100
Status: offline
what power source are you hooking the tower starter too?
Hide Signatures
(in reply to w8ye)
       Post #: 46
RE: Walbro WT-71 Carb? - 11/20/2012 2:02 AM
w8ye
Score: 318
Status: offline
At the time I was using a 12v - 7 amp gell cell from Tower.
Original AMA #31261
Hide Signatures
       Post #: 47
RE: Walbro WT-71 Carb? - 11/20/2012 2:09 AM
w8ye
Score: 318
Status: offline
I would stick my thumb over the carb venturi to choke the engine during starting.
The carb is a Walbro WA-167A from a Zenoah G26. It has a 11.2mm venturi and a number 28 cast into the venturi entrance.
The other Homelite has a Walbro WT-499 carb with a "27" cast into the venturi. The carb is from a Zenoah G-23 glow engine but I use gasoline.
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 48
RE: Walbro WT-71 Carb? - 11/20/2012 2:26 AM
Schizted
Score: 100
Status: offline
what nose cone should i be looking for... im using a 18x6 master airscrew classic
Hide Signatures
(in reply to w8ye)
       Post #: 49
RE: Walbro WT-71 Carb? - 11/20/2012 3:21 AM
w8ye
Score: 318
Status: offline
In the picture is a Harry Higley 1" prop nut that has 5/16" X  24 threads
Original AMA #31261
Hide Signatures
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Walbro WT-71 Carb?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
