Walbro WT-71 Carb?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Walbro WT-71 Carb?
Page: [1] 2 3   next >   >>
Login
Walbro WT-71 Carb? - 11/12/2012 6:57 PM
Schizted
Score: 100
Last Login: 12/1/2012
Status: offline
my walbro carb will pull fuel up the lines and back thru the return but it wont pump any fuel into the engine...?
Ive dissaymblyed and cleaned out all the ports with carb cleaner and a little wire and still nothing
why cant i get this thing to flood the eninge?
Hide Signatures
       Post #: 1
RE: Walbro WT-71 Carb? - 11/12/2012 7:32 PM
All Day Dan
Score: 151
Last Login: 5/19/2013
Status: offline
Rebuild the carb. Get the rebuild kit K20-WAT. Check the choke plate for full closure. Blow out the carb with a can of computer dusting air.
http://wem.walbro.com/walbro/group2.asp?FamilyName=WT
Dan.
_____________________________
Dan
Hide Signatures
(in reply to Schizted)
       Post #: 2
RE: Walbro WT-71 Carb? - 11/12/2012 7:41 PM
Schizted
Score: 100
Status: offline
Choke plate closes fully, Blown out the carb with cleaner, all gaskets look good except the diaphragm will be getting a hole kit soon, tried a walbro wt-340 that i knew was working on another trimmer, attached it and the purge with flown gas in and out but non of it is getting to the engine...
Hide Signatures
(in reply to All Day Dan)
       Post #: 3
RE: Walbro WT-71 Carb? - 11/12/2012 7:43 PM
Schizted
Score: 100
Status: offline
ive taken the carb off the engine and primed it and no fuel comes out of the throat of either carb
Hide Signatures
       Post #: 4
RE: Walbro WT-71 Carb? - 11/13/2012 12:02 AM
All Day Dan
Score: 151
Status: offline
There's a mounting block between the engine and the carb. That may have a leak. Also change the gaskets that are on both sides of it. Dan.
Dan
Hide Signatures
       Post #: 5
RE: Walbro WT-71 Carb? - 11/13/2012 12:54 AM
w8ye
Score: 318
Status: offline
Soundsas though the metering valve is stuck and not letting fuel though?
The screen between the pump and metering valve may be stuck?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 6
RE: Walbro WT-71 Carb? - 11/13/2012 3:59 AM
Schizted
Score: 100
Status: offline
 The Gaskets between the carb and the heat dam and engine are brand new, took the carb off and check the gasket holes to see if its all lined up, it was all ok.
Took the carb apart except for the needle seat and all that and is soaking in a carb cleaner bath over night.
Goning to local shop to look for a carb repair kit to replace all of it. and clean out the needle seat and metering valves
On another note, i added a bit of gas straight into the cylinder and hand propped the engine, it didnt want to pop really only got 1 decent put put put
i dont have the tools to do a compression test but holding my finger over the plug hole it sucks pretty hard and pushes my finger away
took the plug out and hand propped and i get a god amount of sparks popping off.
is the carb affecting the engine from not wanting to run for a second even with straight gas to cylinder?
Hide Signatures
(in reply to w8ye)
       Post #: 7
RE: Walbro WT-71 Carb? - 11/13/2012 6:26 AM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
i have a wt-71 on my 3w80....im sure you know this...but you might want to make sure the metering fork is engaged on the pump.... some carbs dont have it, but this particular carb does...
what engine do you have it on?
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
       Post #: 8
RE: Walbro WT-71 Carb? - 11/13/2012 8:48 AM
Schizted
Score: 100
Status: offline
its engaging, but myabe clogged its soaking and it that dosnt work ill replace when i ge the repair kit.
its on a 25cc homelite
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 9
RE: Walbro WT-71 Carb? - 11/13/2012 9:59 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: Schizted
see if yur local shop has one of these...they come in handy http://www.ebay.com/itm/NEW-WALBRO-DIAPHRAGM-CARBURETOR-W-METERING-LEVER-TOOL-/280341093058
Hide Signatures
       Post #: 10
RE: Walbro WT-71 Carb? - 11/14/2012 12:23 AM
Schizted
Score: 100
Status: offline
ive replaced all the gaskets the metering fork, needle, screens everything but the little metal caps. let it soak 24 hrs in carb cleaner, blew out all ports with carb cleaner and reassemble
all it will do now is after a bunch of priming i can get the gas to climb th line to the carb but thats it, it wont fill the bulb if it does its just a tiny bit of gas.
Ive have disassemble and reassemble it 3 times to check everything, what is going on?
Hide Signatures
       Post #: 11
RE: Walbro WT-71 Carb? - 11/14/2012 1:06 AM
w8ye
Score: 318
Status: offline
You need to take your carb to someone who works on Walbros all the time or get yourself a new carburetor?
Original AMA #31261
Hide Signatures
       Post #: 12
RE: Walbro WT-71 Carb? - 11/14/2012 3:09 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: Schizted
is it possible you might have swapped the low and high end needles
Hide Signatures
       Post #: 13
RE: Walbro WT-71 Carb? - 11/14/2012 3:26 AM
Schizted
Score: 100
Status: offline
 I had just thought of that so tried to switch em but they are diffrent size and thread so they cant be swapped.
the fuel is not even getting to the primer bulb so im guesing that its not making it past the pump
Hide Signatures
       Post #: 14
RE: Walbro WT-71 Carb? - 11/14/2012 4:23 PM
LanceLKs
Score: 100
Last Login: 4/27/2013
Status: offline
Butterfly couldnt have gotten rotated 180 degrees? Do you see screw heads or threads when looking in carb?
Hide Signatures
       Post #: 15
RE: Walbro WT-71 Carb? - 11/14/2012 5:21 PM
Schizted
Score: 100
Status: offline
see screw heads on both throttle and choke
Hide Signatures
(in reply to LanceLKs)
       Post #: 16
RE: Walbro WT-71 Carb? - 11/14/2012 5:24 PM
MetallicaJunkie
Score: 243
Status: offline
one time after replacing the membranes on both sides of the carb i put the wrong membrane one ,opposite the diaphragm... it was missing the reeds/petals....the guy at the lawmower shop said it was for gravity fed setups....you might have put the wrong one on as well?
Hide Signatures
       Post #: 17
RE: Walbro WT-71 Carb? - 11/14/2012 7:38 PM
Schizted
Score: 100
Status: offline
the fuel pump with the one way valves? the orginal was a clearish color, replaced it with the exact same.
got a black fuel pump gasket that is the extact same cut out but feels liek a rubbery material was thinking about trying that one
i feel like the valves wont open or somin...
Hide Signatures
       Post #: 18
RE: Walbro WT-71 Carb? - 11/14/2012 9:26 PM
All Day Dan
Score: 151
Status: offline
Here's what's in my WT-76. Dan.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Dan
Hide Signatures
       Post #: 19
RE: Walbro WT-71 Carb? - 11/15/2012 5:26 AM
Rick Sowell
Score: 100
Status: offline
quote:
ORIGINAL: Schizted
there looks like your problem, I checked several carbs that I have here and all of them the throttle butterfly screw head will face the engine and the choke screw head will face the outside or incoming airflow.
I had a zenoah that got turned 180 degrees and it would prime but not start, had to use a starter to get a pop from it. have you taken the throttle spring loose? if so it will allow the butterfly to rotate 180 degrees.
Hide Signatures
       Post #: 20
RE: Walbro WT-71 Carb? - 11/15/2012 6:28 AM
All Day Dan
Score: 151
Status: offline
Rick, you're a genius. I took a look at my WT-76 and you are right. The screw head on the choke is visible when the choke is closed and the threads of the screw are visible when the throttle is closed. Brilliant. Never would have thought about it. Dan.
Dan
Hide Signatures
(in reply to Rick Sowell)
       Post #: 21
RE: Walbro WT-71 Carb? - 11/15/2012 6:39 AM
Schizted
Score: 100
Status: offline
I think i might have figured it out, its always the simple things...
Screw heads are in correct postion, i put the rubber fuel pump on and still nothing, so then i deciede to try my old diaphragm again and wala!  it pumped gas threw both lines but not out the throat!
my old diaphragm had a little piece attached to it, the new diaphragm did not and that little piece was sealing it down
now my question is which gasket goes first  on the body of the carb
Carb>  Gasket B->  Gasket A-> Lid
Carb>  Gasket A> Gasket B-> Lid
And am i suppose to see fuel come out the throat of the carb to flood the engine?
Click for fullsize
Hide Signatures
       Post #: 22
RE: Walbro WT-71 Carb? - 11/15/2012 12:18 PM
w8ye
Score: 318
Status: offline
On the metering valve side of the carb it is Carb>  Gasket B->  Gasket A-> Lid
Original AMA #31261
Hide Signatures
       Post #: 23
RE: Walbro WT-71 Carb? - 11/15/2012 3:48 PM
All Day Dan
Score: 151
Status: offline
schizted, do not tighten those four screws too much. If you do, the gasket will get crushed and the cover distorted. What do the right diaphragm and gasket look like on the pump side? Dan.
Dan
Hide Signatures
       Post #: 24
RE: Walbro WT-71 Carb? - 11/15/2012 5:34 PM
Schizted
Score: 100
Status: offline
 good to know i wasnt sure how tight to get those screws.
i dont know what you mean, the fuel pump and gasket look like the pic you posted of the rubber one and gasket
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Walbro WT-71 Carb?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
