seaplane / weedeater help...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> seaplane / weedeater help...
Page: [1] 2 3   next >   >>
Login
seaplane / weedeater help... - 11/13/2012 3:39 AM
joshrc110
Score: 100
Last Login: 11/14/2012
Status: offline
ok guys iv just got a nice neptune seaplane 60" nice fuse build and i love the plane all but where and how the motor is mounted... i also want to mount a 26cc weedeater engine iv been working on.
so my questions are
www.valuehobby.com/60in-neptune-seaplane-arf-almost-ready-to-fly.html
is 60"" enough to use the 26cc engine? it did use the K&B .40 nitro engine
also i want to mount the engine on the front and ad landing gear so it will no longer see water.
ill include pics not the greatest but pics none the less...
any help is always appreciated
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: seaplane / weedeater help... - 11/13/2012 4:00 AM
foodstick
Score: 177
Last Login: 5/24/2013
Status: offline
I don't think it will work ... I have put 25cc on some planes before, but thats not much wing to be flying off water, with that big motor on board. Also you will probably run a 16-8 two blade prop, or a 15 inch three blade? Clearance will be an issue.
I'd love to see you make it work, but its dicey at best...
Hide Signatures
(in reply to joshrc110)
       Post #: 2
RE: seaplane / weedeater help... - 11/13/2012 4:06 AM
joshrc110
Score: 100
Status: offline
it will no longer be a seaplane im putting landing gear on it.... still think it wont work?
Hide Signatures
(in reply to foodstick)
       Post #: 3
RE: seaplane / weedeater help... - 11/13/2012 4:07 AM
longdan
Score: 103
Last Login: 5/20/2013
Status: offline
Given that a 40 engine is 6.5 cc, I think the weedeater engine is a massive overkill. I wouldn't put more than a 61 (10cc) on something like that, but that's just me.
I know that glow engines are less powerful than gas engines of the same displacement, but not by a factor of 4, which is about how much you are increasing the engine size by.
I'd look for a bigger plane to mount that bad boy in.
Hide Signatures
       Post #: 4
RE: seaplane / weedeater help... - 11/13/2012 4:16 AM
joshrc110
Score: 100
Status: offline
well with the 40 it is slow and moves slow i want the weedater engine on there to turn the plane into more of a 3d plane
Hide Signatures
(in reply to longdan)
       Post #: 5
RE: seaplane / weedeater help... - 11/13/2012 4:35 AM
haikt
Score: 110
Last Login: 4/6/2013
Status: offline
You don't have enough wing area for an engine that size. That engine should go with a wing span of 73+.
Nitro engines are more powerfull then gas engines and are lot lighter.
You can try it but very likely will end with disaster.
Hide Signatures
       Post #: 6
RE: seaplane / weedeater help... - 11/13/2012 4:37 AM
joshrc110
Score: 100
Status: offline
well iv been looking online and 60" seems to be good for 26cc
Hide Signatures
(in reply to haikt)
       Post #: 7
RE: seaplane / weedeater help... - 11/13/2012 4:44 AM
foodstick
Score: 177
Status: offline
I think the smallest airplanes I have flown successfully with a 25 cc conversion was an ugly stick, I can't recall the numbers I sort of used to use as a rule of thumb.. but I think you need a minimum of 900 square inches...
I think the ugly stick was about that many square inches, and weighed around 8 pounds, I had to chop the nose of the plane 4 inches and mount the radio and battery under the stabilizer to balance without using lead.
Hide Signatures
       Post #: 8
RE: seaplane / weedeater help... - 11/13/2012 4:46 AM
joshrc110
Score: 100
Status: offline
www.dragtimes.com/video-viewer.php
the plane in this video i believe in 1400mm witch is not to much bigger then my seaplane and the thing flys great?
Hide Signatures
       Post #: 9
RE: seaplane / weedeater help... - 11/13/2012 4:48 AM
joshrc110
Score: 100
Status: offline
i was thinking of making small attachable lead plates on the back so it will alow me to balance for what conditions im in?
Hide Signatures
       Post #: 10
RE: seaplane / weedeater help... - 11/13/2012 4:54 AM
joshrc110
Score: 100
Status: offline
and if you look on this site it says 63in = 26cc to 30cc engine http://www.tradekey.com/product-free/R-c-3d-Model-Airplane-katana-26cc3408912.html
Hide Signatures
       Post #: 11
RE: seaplane / weedeater help... - 11/13/2012 5:22 AM
joshrc110
Score: 100
Status: offline
i also think i need to make my ailerons bigger? how much nose would i need to chop off to mount this engine
Hide Signatures
       Post #: 12
RE: seaplane / weedeater help... - 11/13/2012 5:40 AM
joshrc110
Score: 100
Status: offline
what if i make my wings a bit bigger would i need to modify the fuse?
Hide Signatures
       Post #: 13
RE: seaplane / weedeater help... - 11/13/2012 11:26 AM
joshrc110
Score: 100
Status: offline
any ideas ? i want to make this work!
Hide Signatures
       Post #: 14
RE: seaplane / weedeater help... - 11/13/2012 1:38 PM
smithcreek
Score: 159
Status: offline
sarcastic remark removed. Please, continue, and don't forget to video.
_____________________________
For a kit you are, and to a kit you shall return.
Hide Signatures
       Post #: 15
RE: seaplane / weedeater help... - 11/13/2012 2:35 PM
GerKonig
Score: 191
Status: offline
quote:
ORIGINAL: joshrc110
well iv been looking online and 60'' seems to be good for 26cc
Everybody advised against it. You have your mind made up. Why ask? You would be adding a lot more weight that is needed to that model. You do not have 3D control surfaces on it, but, do not listen to us.
You will have to redesign entirely the fuse, chopping off all the nose area, because of the weight of the gas power plant, then you will have to reinforce all the fuse because of the vibrations of the gas power plant. You will end up with a really, really heavy 60" model...
Idea: you could get a model designed for you power plant, like a giant Sweet Stick... and be at the field in one week, having fun...
If you do this, do not forget to video the event, and share.
Good luck!
Gerry
Hide Signatures
       Post #: 16
RE: seaplane / weedeater help... - 11/13/2012 2:44 PM
pmerritt
Score: 167
Last Login: 5/23/2013
Status: offline
Put it all together Josh, fly the hell out of it.  Make sure you have someone at the field with a video camera.  We love exciting RC Crashes!
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
(in reply to GerKonig)
       Post #: 17
RE: seaplane / weedeater help... - 11/13/2012 3:15 PM
bogbeagle
Score: 148
Status: offline
IMO, it'll fly like a plank.
Hide Signatures
(in reply to pmerritt)
       Post #: 18
RE: seaplane / weedeater help... - 11/13/2012 3:26 PM
GerKonig
Score: 191
Status: offline
quote:
ORIGINAL: bogbeagle
And glide like a brick:-) But, hey, the Space Shuttle also glided like a brick, and always landed successfully...
Gerry
Hide Signatures
(in reply to bogbeagle)
       Post #: 19
RE: seaplane / weedeater help... - 11/13/2012 3:27 PM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
Where to start to explain why this is not a good idea?
The plane does not have the overall size or structure to mouint a massive, heavy, magneto ignition 26cc weed whacker enigne.
A website suggesting that a 60" wingspan plane is OK for a 26cc weed whacker engine is of no value. Take a look at something like a 110" span motor glider. You'd never get a 26cc weed whacker on that pencil thin fuselage. You'd have trouble with your .40. There are may more factors to consider for appropriate engine size than simply wingspan.
Look here to see what I mean:
http://www.aerospaceweb.org/question/design/q0214.shtml
The Bumble Bee II plane has a wingspan of 5 ft 6 inches - that's only 66 inches my friend, a measly 6 inches more than your dream machine. It's powered with a Continental C-85, 85hp engine, which makes your weed whacker look like a flea! And there's no way that it would fly with your .40.
Consider this: things work the way they do because that's the way they work.
Nothing in your plane was designed to accomodate that engine. So once you change the wing, change the fuse, add the stilt landing gear, add the ton of lead to balance, overload the wing and rear fuselage structure to accomodate the lead and on and on, what you've got is a mess. And it's no longer the plane with which you started. And neither will its flight characteristics be the same.
If you want a plane for a 26cc weed whacker engine, why not just start with one which is intended to use that size engine?
There are many more issues with your great plan. However, this and everyone else's comments should give you the idea.
Click for fullsize
< Message edited by do335a -- 11/13/2012 4:44 PM >
Hide Signatures
       Post #: 20
RE: seaplane / weedeater help... - 11/13/2012 3:48 PM
sensei
Score: 176
Status: offline
There is a thing called wing loading, maybe you have heard of it or maybe not, this airplane is supposed to come in around 6.5 lbs. that seems heavy in my opinion but whatever, with this pig of an engine you want to place on this tiny platform just what do you think the weight and wing loading will be then? Power is not an antidote for wing loading and never will be so this is a really lame idea with absolutely no valuable point to be made...
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to do335a)
       Post #: 21
RE: seaplane / weedeater help... - 11/13/2012 4:05 PM
raptureboy
Score: 178
Status: offline
TROLL ALERT! don't feed the TROLL really guys, 40 size seaplane he wants to turn into a 26 cc 3d plane
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to sensei)
       Post #: 22
RE: seaplane / weedeater help... - 11/13/2012 4:41 PM
superfli
Score: 100
Status: offline
There are 40-60 size gas engines. They are beam mounted and electronic ignition and very light. A weedwacker conversion is like mounting a boat anchor to the front. Save that for a quarter scale cub.
Good luck,
Superfli
Hide Signatures
(in reply to raptureboy)
       Post #: 23
RE: seaplane / weedeater help... - 11/13/2012 4:46 PM
Daniel Spurlock
Score: 100
Status: offline
I say install it and when it returns to kit form you can build it bigger.There is no way that aircraft is anywhere big enough for that engine and it will never 3D not enough wing,tail or rudder how ever it will be an awsome crash.
Hide Signatures
       Post #: 24
RE: seaplane / weedeater help... - 11/13/2012 4:49 PM
do335a
Score: 105
Status: offline
quote:
ORIGINAL: joshrc110
Flys great? I didn't see anything fly in that video.
The plane just sits there with the engine running.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
