RE: seaplane / weedeater help...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: seaplane / weedeater help...
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: seaplane / weedeater help... - 11/13/2012 5:08 PM
philakapd
Score: 100
Last Login: 5/3/2013
Status: offline
Hi,
What is the all up weight (wet)?
What will your wing loading be?
What is your ground clearance to centerline after the gear and wheels are installed?
Hide Signatures
(in reply to do335a)
       Post #: 26
RE: seaplane / weedeater help... - 11/13/2012 5:11 PM
GerKonig
Score: 191
Last Login: 5/20/2013
Status: online
quote:
ORIGINAL: do335a
quote:
ORIGINAL: joshrc110
www.dragtimes.com/video-viewer.php
the plane in this video i believe in 1400mm witch is not to much bigger then my seaplane and the thing flys great?
Flys great? I didn't see anything fly in that video.
The plane just sits there with the engine running.
Well, his might "fly" as well as the one in the video. As long as it does not take off...:-)
Gerry
Hide Signatures
       Post #: 27
RE: seaplane / weedeater help... - 11/13/2012 5:18 PM
jrf
Score: 105
Status: online
Here is a link to the plane in the video. It has an 86.5" span and about double the wing area of his neptune.
http://www.abellhobby.com/86-Aerial-Video-Aircraft-ARF-p/26ccav.htm
On the other hand, the photo of the (supposedly) converted Neptune land plane in the first post looks kind of interesting. I may build one.
(For 7.5cc power, of course.)
Jim
Hide Signatures
(in reply to GerKonig)
       Post #: 28
RE: seaplane / weedeater help... - 11/13/2012 5:25 PM
sensei
Score: 176
Status: offline
The wing loading and more importantly cubed loading is going to be way outside the bounds of a prudent sport flying airplane. Just saying...
Bob
< Message edited by sensei -- 11/13/2012 5:46 PM >
_____________________________
Fly It Like You Stole It!!!
Hide Signatures
       Post #: 29
RE: seaplane / weedeater help... - 11/13/2012 6:10 PM
foodstick
Score: 177
Status: offline
This plane WILL work with your motor if you modify the airframe, and balance it right.. It does however have 1000 square inch of wing. I have also flown the great Planes GeeBee r2, and the CMP Hellcat with converted 25ccs.. One time I flew a giant stinger with one, but it was the most terrifying underpowered overloaded flight I have ever survived :P
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMM8&P=ML
At least I have flown mine with no real problems, even lands decent, warm but no bad habits...
I need a new carb diaphragm in it ..
Hide Signatures
(in reply to sensei)
       Post #: 30
RE: seaplane / weedeater help... - 11/13/2012 6:21 PM
foodstick
Score: 177
Status: offline
Here you go p.s. my new Carb parts just showed up in the mail !
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to foodstick)
       Post #: 31
RE: seaplane / weedeater help... - 11/13/2012 6:26 PM
foodstick
Score: 177
Status: offline
just found this thread http://www.rcuniverse.com/forum/m_11295904/anchors_11295904/mpage_1/key_/anchor/tm.htm#11295904
talking about small !, I bet the pilot is no slouch!
Hide Signatures
       Post #: 32
RE: seaplane / weedeater help... - 11/13/2012 7:30 PM
champjocky
Score: 100
Last Login: 5/13/2013
Status: offline
do it!
Hide Signatures
       Post #: 33
RE: seaplane / weedeater help... - 11/13/2012 7:53 PM
pmerritt
Score: 167
Last Login: 5/19/2013
Status: offline
This might go to prove that "witches" DO FLY?
quote:
ORIGINAL: joshrc110
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
(in reply to joshrc110)
       Post #: 34
RE: seaplane / weedeater help... - 11/13/2012 10:17 PM
joebahl
Score: 132
Status: offline
I have the same heavy arf seaplane i got in a trade ,the motor mast was loose when installed ,no front hatch for a flight battery and the hardware looks like junk. It is a heavy plane to begin with and adding a gas motor would make it fly like a yard dart . I dont want to argue cause it your plane but if your heart is set on waisting time mounting the BIG motor and trying to fly it knock your socks off. My china junk seaplane is sitting in a corner till i can cut it open and fix it so i dont waist my time even mounting a 40 or 50 nitro on it. As far as more weight for landing gear mounted on it all i can say is, LMAO . Good luck . joe
Hide Signatures
(in reply to pmerritt)
       Post #: 35
RE: seaplane / weedeater help... - 11/14/2012 2:52 AM
wallace.tharp
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: raptureboy
TROLL ALERT! don't feed the TROLL really guys, 40 size seaplane he wants to turn into a 26 cc 3d plane
No more calls, Raptureboy is the winner..... I think. Hey, if I'm wrong I apologise, but..... can you see two guys or more sitting around, stoped building in the shop, may be drank a couple & one guy says, "Hey, I got a great idea of how we can get everybody goin on a RCU forum!!!!" just sayn wallace.tharp
Hide Signatures
(in reply to raptureboy)
       Post #: 36
RE: seaplane / weedeater help... - 11/14/2012 3:33 AM
2walla
Score: 100
Status: offline
If you want to do something with it go electric. If you must go gas look at some of the small 60- 90 size gas motors that r coming out. Smilar to the bme supertiger conversion. About a pound and a half lighter than your weedie right off the bat.
Hide Signatures
(in reply to wallace.tharp)
       Post #: 37
RE: seaplane / weedeater help... - 11/14/2012 2:12 PM
bruceal
Score: 100
Last Login: 4/28/2013
Status: offline
I had this plane last year with a 55AX. I thought that it flew lousy to say the least. Finally the engine pod snapped off and that was that! This was the only plane that I ever bought off of e-bay and I only paid $75.00 for it. It looked like a nice plane but the hardware was garbage and the covering was a cheap knock off of cheap covering. Hardly worth the effort to try a project like this.
Hide Signatures
(in reply to 2walla)
       Post #: 38
RE: seaplane / weedeater help... - 11/14/2012 2:32 PM
raptureboy
Score: 178
Status: online
No replies from the op(troll) since starting this thing, yet here we are on almost 3 pages of responses.????? No wonder people have no time to build kits. Me, it's just a slow day at work today so I have nothing else to do, but when I get home it's straight to the man cave got to finish my p-47 and start my pt-19
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to bruceal)
       Post #: 39
RE: seaplane / weedeater help... - 11/14/2012 4:46 PM
wallace.tharp
Score: 100
Status: offline
rap: You got it man! He's too bussy laughing at us! And I admit it's a good one. Anyone in the hobby for any amount of time knows that there is no way you can convert a weed-eater to be anywhere near what an average inexpensive R/C engine can do on an R/C airplane. They are great boat anchors!! wallace.tharp
Hide Signatures
       Post #: 40
RE: seaplane / weedeater help... - 11/14/2012 10:24 PM
foodstick
Score: 177
Status: offline
Well, troll or not. this has been an interesting thread, I am always glad to see a thread with discussion. heaven knows so many are pretty dry with content, or worse "angry"... :P
Hide Signatures
       Post #: 41
RE: seaplane / weedeater help... - 11/15/2012 2:11 AM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
And what's even more interesting is that all the subsequent posters have offered correct advice.
Maybe that's why we haven't heard from the OP. He hasn't heard what he was wanting to hear.
Hide Signatures
       Post #: 42
RE: seaplane / weedeater help... - 11/15/2012 7:51 AM
bogbeagle
Score: 148
Status: online
quote:
ORIGINAL: do335a
Could be. It's a truism that, when we claim to seek advice, what we are really seeking is confirmation. It's a "human" thing.
Hide Signatures
       Post #: 43
RE: seaplane / weedeater help... - 11/15/2012 4:58 PM
wallace.tharp
Score: 100
Status: offline
quote:
ORIGINAL: bogbeagle
quote:
ORIGINAL: do335a
Could be. It's a truism that, when we claim to seek advice, what we are really seeking is confirmation. It's a ''human'' thing.
Most any woman knows if you really want to impress a man, ask him a lot of questions and act like you are really interested in the answers, especially if it's a subject he loves.. again...just sayin. wallace.tharp
Hide Signatures
(in reply to bogbeagle)
       Post #: 44
RE: seaplane / weedeater help... - 11/15/2012 9:17 PM
joebahl
Score: 132
Status: offline
I scratch built this electrict short solent seaplane from plans ,its 100 inch wing span with a 6ft long fuse .I wonder if i should get rid of its slow scale gracefull flight and the way it takes off so easy from the water by putting 4 gas motors on it so it flys like a brick lmao Naaaaaaa ,joe
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 45
RE: seaplane / weedeater help... - 11/15/2012 9:39 PM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: joebahl
Sweet airplane!
Bob
Hide Signatures
(in reply to joebahl)
       Post #: 46
RE: seaplane / weedeater help... - 11/15/2012 10:08 PM
joebahl
Score: 132
Status: offline
Thanks Bob ,i cant figure out why most of us are trying our best to make our planes lighter and you get a couple of these guys trying to screw up their own plane. I think he is watching this and is most likly laughing but it is him that looks foolish . I weighed most every thing i could to keep it at 8 pounds or under and straping BIG gas motors on it is not the answer to flying a nice plane. You fly on the wing not the motor. Check out the weight and wingloadings of Ivans planes ,thats why they fly so nice. joe http://www.ivansplans.com/
Hide Signatures
       Post #: 47
RE: seaplane / weedeater help... - 11/15/2012 10:35 PM
do335a
Score: 105
Status: offline
quote:
ORIGINAL: joebahl
Don't forget to include the necessary mods to make it do 3D.
Hide Signatures
       Post #: 48
RE: seaplane / weedeater help... - 11/15/2012 10:57 PM
joebahl
Score: 132
Status: offline
quote:
ORIGINAL: do335a
quote:
ORIGINAL: joebahl
Thats why i built this ,its a 100mph seaplane .I had a tuned pipe on it but things were flexing to much. Iam old fart but just try keepimg up with my old ars . lmao Iam the second guy flying my red and white seacruiser in this video ,it will fly 3-d and do a nife edge circle . joe http://www.youtube.com/watch?v=tExcCotOxfo
Click for fullsize
Hide Signatures
       Post #: 49
RE: seaplane / weedeater help... - 11/26/2012 10:09 PM
wallace.tharp
Score: 100
Status: offline
quote:
ORIGINAL: joebahl
quote:
ORIGINAL: do335a
quote:
ORIGINAL: joebahl
Doooooooood! I saw you fly this at Lk. Havasu a few weeks back. You call it the "suitcae," right? Flys very well for a homebrew flying boat! Congrats. wallace.tharp
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
