Jet Boat with a Jettec Drive    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Jet Boat with a Jettec Drive
Page: [1]
Login
Jet Boat with a Jettec Drive - 11/13/2012 5:22 AM
The Ghost
Score: 110
Last Login: 5/21/2013
Status: offline
Hi All,
I started on my secone jet boat with the Jettec jet drive. First you nead to find the center of the reansom, then using the seal plate mark and cut out the transom. This needs to be as neat as possiable. Then check jet alignment and mark the hull. I use plastic tape and a release agent on the jet drive, then mix up body filler(Bondo) to make a bed for the jet unit to sit in, this helps hold and locates the jet drive.
Cheers
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Remember, Always look after the ORGANIC part of the model
Hide Signatures
       Post #: 1
RE: Jet Boat with a Jettec Drive - 11/13/2012 5:28 AM
The Ghost
Score: 110
Status: offline
Mark up the bottom of the hull and cut out for the jet intake. I drill the 6 mount holes while the jet unit is held in place after the body filler has gone off. Refit jet unit and mark and clean up intake hole, sand back excess filler and recheck drive fitment.
Cheers
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to The Ghost)
       Post #: 2
RE: Jet Boat with a Jettec Drive - 11/13/2012 5:33 AM
The Ghost
Score: 110
Status: offline
Make up and fit transom seal plate and seal, made from an inner tube from car/truck. Moulding line on jet drive will have to be sanded off for a good seal. Then I refitted the drive with a 1mm bead of Sikaflex-227 to seal the drive to hull and bolted the drive in(excess sealer will be removed after it setups up). Then fitted the end of the jet drive.
Cheers
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3
RE: Jet Boat with a Jettec Drive - 11/13/2012 5:43 AM
The Ghost
Score: 110
Status: offline
Fitted the drive dogs to the drive and engine and using an alignment tool(machined from scrap alloy bar stock 2mm longer than the drive bone) positioned and alinged the engine, then drilled mount holes and mounted the engine with the bone fitted. Fitted the radio box, fitted the steering and trim adj linkages, fitted the steering rod joiner and supports.
Cheers
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: Jet Boat with a Jettec Drive - 11/13/2012 5:47 AM
The Ghost
Score: 110
Status: offline
Radio box finished. Fitted carry, launch, recover, roll cage. Second one almost ready. Fitted exhaust header and pipe, fitted rear mount. Fitted fuel tank(waiting on filler port) Ready to GO.
I still have to make up the start, carry cradle.
Cheers
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Jet Boat with a Jettec Drive - 11/14/2012 1:44 AM
jvdd
Score: 100
Last Login: 5/20/2013
Status: offline
very nice work...can't wait for the video.
mmmmm maybe I'll get one for my fleet.....I wonder if Santa is listening.
jim
Hide Signatures
       Post #: 6
RE: Jet Boat with a Jettec Drive - 11/15/2012 3:19 AM
The Ghost
Score: 110
Status: offline
quote:
ORIGINAL: jvdd
jim
Vid will have to wait a while, Have my daughters year 12 grad this weekend and my sisters wedding next weekend, also looking for another site as all the rain here last month destroyed the area I used to use these boats at.
Cheers
Hide Signatures
(in reply to jvdd)
       Post #: 7
RE: Jet Boat with a Jettec Drive - 11/15/2012 8:22 PM
mickieb49
Score: 100
Status: offline
Hey Andrew, think we have found another small area for running the jetsprints, it has a heap of little alcoves that are shallow and there are a few places where you can jump over the bank into the next part. Should be ok when it has a little more water in it, and it is FRESH Water.
 Your builds are looking great mate.
Mick
Hide Signatures
       Post #: 8
RE: Jet Boat with a Jettec Drive - 11/15/2012 8:52 PM
The Ghost
Score: 110
Status: offline
Mick, That sounds great, all the rain last month stuffed the area I used. Its now a sand bar and only about 4"-6" deep at high tide, not deep enough, may change after a while. I will just go back to the ski club, but this time of year it starts to get bissy with skiers.
Cheers
Hide Signatures
(in reply to mickieb49)
       Post #: 9
RE: Jet Boat with a Jettec Drive - 11/17/2012 1:19 AM
F1Rodman
Score: 105
Status: offline
Nice builds Andrew, looks really good, and neat and tidy too.
Look forward to some vid when you get the time to run them.
Keep up the good work, and maybe I'll get my hull down off the shelf soon.
Cheers
Chris
< Message edited by F1Rodman -- 11/20/2012 8:13 AM >
Hide Signatures
       Post #: 10
RE: Jet Boat with a Jettec Drive - 11/29/2012 12:07 AM
The Ghost
Score: 110
Status: offline
Hi All,
Got in a short run this morning, faulty plug stopped the fun. Have to get the trim and tune sorted.
Cheers
Hide Signatures
(in reply to F1Rodman)
       Post #: 11
RE: Jet Boat with a Jettec Drive - 11/30/2012 8:47 PM
mickieb49
Score: 100
Status: offline
Looking good Andrew,  the trim is why i like having the 3rd channel radio's, so you can adjust whilst going, and also using it to trim the boat back down when doing a turn.
 But none the less you have done a great job with it.
Hide Signatures
       Post #: 12
RE: Jet Boat with a Jettec Drive - 12/15/2012 7:06 AM
The Ghost
Score: 110
Status: offline
Hi All,
Hope to get some better video soon, got an early chrisy gift. Made up a mount for it.
Cheers
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Jet Boat with a Jettec Drive - 12/15/2012 7:29 AM
F1Rodman
Score: 105
Status: offline
Gotta love the Go Pro camera's, they are so popular. Nice mount you have made, look fowrad to seeing some vid of it.
Cheers
Chris
Hide Signatures
       Post #: 14
RE: Jet Boat with a Jettec Drive - 12/15/2012 8:29 AM
The Ghost
Score: 110
Status: offline
quote:
ORIGINAL: F1Rodman
Cheers
Chris
Thanks, Just hope that the weather improves, been too windy or wet, been raining on and off for the last couple of days.
Cheers
Hide Signatures
       Post #: 15
RE: Jet Boat with a Jettec Drive - 12/15/2012 11:53 AM
wan6176
Score: 105
Last Login: 3/17/2013
Status: offline
slow
Everyday is learning day,no one can say he has learn enough.
Hide Signatures
       Post #: 16
RE: Jet Boat with a Jettec Drive - 12/18/2012 5:39 AM
The Ghost
Score: 110
Status: offline
Got out for a quick run, still having ign problems.
Cheers
Hide Signatures
(in reply to wan6176)
       Post #: 17
RE: Jet Boat with a Jettec Drive - 1/25/2013 1:45 AM
Body Guard
Score: 100
Status: offline
Hi Andrew,
I'm interested in the jet drive for my rc Jetski Project. Can't get on the Jettec site. Any advise where I can get one of those jet drive ? What is the price on this jetdrive ?
Appreciate your help.
Latiff
Hide Signatures
       Post #: 18
RE: Jet Boat with a Jettec Drive - 1/25/2013 5:08 AM
The Ghost
Score: 110
Status: offline
quote:
ORIGINAL: Body Guard
Hi Andrew,
Latiff
Latiff
You can find the jetdrives at http://www.jettec.co.nz/# or you can contact Adam at adam@jettec.co.nz cost NZD$849 plus NZD$65international postage, hopes this helps
Cheers
Hide Signatures
(in reply to Body Guard)
       Post #: 19
RE: Jet Boat with a Jettec Drive - 1/26/2013 1:57 PM
Body Guard
Score: 100
Status: offline
Thanks for the info mate. Like to have a closer look at the unit before starting on the project.
Cheers .
Hide Signatures
       Post #: 20
RE: Jet Boat with a Jettec Drive - 3/20/2013 1:21 AM
swashdrive
Score: 100
Last Login: 4/4/2013
Status: offline
heah ghost
Do you mind telling me where you purchased these hulls from ?
Builder of 1/4 scale Jetboats, Swashdrive Developments Pty Ltd, Australia
Hide Signatures
       Post #: 21
RE: Jet Boat with a Jettec Drive - 3/21/2013 1:41 AM
The Ghost
Score: 110
Status: offline
quote:
ORIGINAL: swashdrive
heah ghost
He used to live at Nowra but he has moved and I have not been able to contact him lately, I will keep trying.
Cheers
Hide Signatures
(in reply to swashdrive)
       Post #: 22
RE: Jet Boat with a Jettec Drive - 3/23/2013 2:03 AM
mistycreekboats
Score: 105
Status: offline
What kind of COG are you looking for when you build a jet boat ?? WHere do those "dogbone drive shafts" come from and can you get longer ones??
< Message edited by mistycreekboats -- 3/23/2013 7:54 AM >
Randy Danchuk
Misty Creek Boats Canada
Hide Signatures
       Post #: 23
RE: Jet Boat with a Jettec Drive - 3/24/2013 1:51 AM
infinityteg
Score: 100
Status: offline
Hi Randy,
We tend to set the jetboats up around 27% (well mine anyway)
Looks like the dog bones that Ghost is using are the swashdrive ones. jettec also make dog bone drives now.
For my hulls i am now using double ended square flex shafts and have held up very well now
cheers
steve
Infinity RC
1/4 scale jet boats
Hide Signatures
(in reply to mistycreekboats)
       Post #: 24
RE: Jet Boat with a Jettec Drive - 3/24/2013 8:47 AM
mistycreekboats
Score: 105
Status: offline
Thanks Steve these puppies are new toy to me - was hoping I could use square / square as thats what I run on couple others
I'm looking at something little longer than most so was hoping I could move my engine forward some with out alot of special drive parts
What do you think of the MHZ new 52 Jet
http://www.mhz-powerboats.com/Antriebe/Jet/Jet-Power-924.html
Thanks again
Randy Danchuk
Hide Signatures
(in reply to infinityteg)
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
