EAC Mach1 prebuild questions    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> EAC Mach1 prebuild questions
Page: [1]
Login
EAC Mach1 prebuild questions - 11/13/2012 11:38 PM
pilotx
Score: 101
Last Login: 5/23/2013
Status: offline
Ok guys, just a couple of questions before I get started on this build. I have a Eureka Aircraft Mach1 and MAN plans
Any info will be appreciated, THANKS in advance
Spars: are they needed in the construction of the foam wings? I was planning on laminating some Carbon thread its like 3/8 inch wide from DaveBrown Products is this enough? or do i need more.
I'm using Mechanical Retracts in this one just to keep with the Old School era of this build and i am having a hard time wraping my head around how with a single retract servo in the wing, how is the front/nose gear actuating wire hooked up and removed when transporting with the wing not attached to the plane? seems like a pain in the butt to unhook this each time. I'm thinking of using a small servo in the nose wheel bay to simplify this.
also i have two choices of glue for sheeting the wing, both are on hand in house one is 3M 77 spray and the other is Elmers Ultimate is either one better that the other
this is my first pattern build and i am planning on doing a build thread if their is any interest?
_____________________________
-Tracey aka Pilotx
CORSAIR Brotherhood # 62
Hide Signatures
       Post #: 1
RE: EAC Mach1 prebuild questions - 11/14/2012 1:11 AM
doxilia
Score: 136
Last Login: 5/26/2013
Status: offline
Spars: forget about small balsa spars in the foam wing unless used to support the landing gear block back to the root. CF is definitely the way to go. Use two under the wing, one near the 30% chord line where it doesn't interfere with anything else and another along the TE. You can optionally use another on the core top.
Retracts: use two servos for less headaches. You might wind up with a third small servo for steering in the nose bay.
American 3M 77 will dissolve foam. Canadian 3M 77 is a different formulation and doesn't. Regardless, I would recommend polyU (Elmer's) or laminating epoxy.
David
Hide Signatures
(in reply to pilotx)
       Post #: 2
RE: EAC Mach1 prebuild questions - 11/14/2012 1:55 AM
PatternPilot
Score: 125
Last Login: 5/25/2013
Status: offline
+1 on what David said....
We do a .007 x 1/2 wide carbon strip top always , bottom sometimes.
That is why I like Taildraggers...
That's right, on the spray glue... David I have lost my Canadian vendor info for the Spray 77 do you have info for a source ?
Elmer's polyglue the only way to do wings !! I have a set drying now.
Scott
CPA#2
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to doxilia)
       Post #: 3
RE: EAC Mach1 prebuild questions - 11/14/2012 2:01 AM
J Strong
Score: 100
Last Login: 5/11/2013
Status: offline
This is the inside look of one of my two Mach Ones.
Click to see fullsize image.
Click for fullsize
Jamie
In Bama
Hide Signatures
(in reply to PatternPilot)
       Post #: 4
RE: EAC Mach1 prebuild questions - 11/14/2012 2:06 AM
J Strong
Score: 100
Status: offline
This is my two Mach Ones, pictured with their builder, Art Azlin from Huntsville.
Click for fullsize
Click for fullsize
Jamie
In Bama
Hide Signatures
(in reply to J Strong)
       Post #: 5
RE: EAC Mach1 prebuild questions - 11/14/2012 3:53 AM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: PatternPilot
Scott
CPA#2
Scott,
Just about every hardware, paint supply and art shop here carries it. But probably the easiest place to order from online is Canadian Tire.
David
Hide Signatures
       Post #: 6
RE: EAC Mach1 prebuild questions - 11/19/2012 6:34 PM
Alan W
Score: 100
Last Login: 5/9/2013
Status: offline
Damn ... thats Sexxxy
(the Mach's ... not the builder but props to him on his skilz)
Hide Signatures
       Post #: 7
RE: EAC Mach1 prebuild questions - 11/19/2012 8:13 PM
hrrcflyer
Score: 121
Status: offline
Pilot,
Go ahead and do a build thread, I for one will follow along..............
Jamie,
I have a dumb question for you. In the first picture you sent, what is the short rod with the ball links connected to the middle of the rudder servo for?
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
       Post #: 8
RE: EAC Mach1 prebuild questions - 11/19/2012 9:17 PM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: hrrcflyer
Jamie,
David
David,
that's a good one. I was wondering the same thing at first and then I realized that it probably is a "servo stabilizer". The rudder servo wants to be very firm in place and one way to "cement" it is to lock the output shaft in place by using a firm short pushrod anchored to the plate. The ball links allow the servo arm to rotate but the lock rod keeps it from moving fore-aft or side-to-side.
Jamie, please correct me if I'm wrong.
David
Hide Signatures
(in reply to hrrcflyer)
       Post #: 9
RE: EAC Mach1 prebuild questions - 11/19/2012 9:25 PM
J Strong
Score: 100
Status: offline
That's exactly right. It's a stabilizing shaft support sold by Horizon. I've heard cases where a few servo gears snap off at the point of the shaft with no support, but never seen it personally. JR' s 821 servo is the one I have heard of, on more than one occasion.
Jamie
In Bama
Hide Signatures
       Post #: 10
RE: EAC Mach1 prebuild questions - 11/19/2012 11:29 PM
pilotx
Score: 101
Status: offline
still getting things sorted out for the Mach1, while finishing a 1/5 scale mustang. I hope to start in honest after the Thanksgiving hoilday...
-Tracey aka Pilotx
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
