Engine mount repair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Crash & Rebuild >> Engine mount repair
Page: [1]
Login
Engine mount repair - 11/14/2012 1:04 AM
rsdonomoore
Score: 102
Last Login: 4/21/2013
Status: offline
I have a 1/4 scale piper super cub. The motor has to be replaced and they do not make the SV 26cc anymore so I opted to replace with a different 26cc gasser. My problem is that the new motor is almost identical except for the motor mount size. The new location of mounting holes is just slightly skinnier than the existing holes. I don't think I will be able to drill new holes through the firewall because it will be so close to the existing holes. What do I do in this scenario? Do I have to cut out the firewall and glue in a new piece of wood? Any help would be greatly appreaciated. I've attached a picture of the existing setup. Thanks!
Click to see fullsize image.
Click for fullsize
_____________________________
rsdonomoore
Hide Signatures
       Post #: 1
RE: Engine mount repair - 11/14/2012 1:21 AM
KitBuilder
Score: 131
Last Login: 6/16/2013
Status: offline
Fill in the existing holes with the correct size "hardwood" dowel epoxied in place... smooth and redrill the new locations.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
(in reply to rsdonomoore)
       Post #: 2
RE: Engine mount repair - 11/14/2012 3:08 AM
rsdonomoore
Score: 102
Status: offline
What minute epoxy should I use, 30 minute? Also, how can I tell if the dowel is "hard wood"? Sorry, I'm new at this. Thanks!
rsdonomoore
Hide Signatures
(in reply to KitBuilder)
       Post #: 3
RE: Engine mount repair - 11/14/2012 4:59 AM
countilaw
Score: 229
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: rsdonomoore
 Balsa is a    soft     wood !        So    a hard wood would be      Maple,  Oak,  Ash,  Spruce, Pine,  Mahogany,  Pecan,  Bass  and etc.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 4
RE: Engine mount repair - 11/14/2012 6:27 PM
N1EDM
Score: 125
Last Login: 6/20/2013
Status: offline
I agree with the hardwood dowel method, but also remember to make the dowels flush with the BACK SIDE of the firewall. That has to be a level surface for any fastening hardware (Tee nuts, washers & nuts, etc) to mount to in a flush manner. I have done this many times ahd have no problems, except of course to the 'first time', when I didn't make things flush with the back of the firewall.
After the new holes have been drilled where you want them, remember to fuelproof the new fresh wood on both sides of the firewall with CA or epoxy.
Just my $.02
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to countilaw)
       Post #: 5
RE: Engine mount repair - 11/14/2012 8:23 PM
opjose
Score: 284
Status: offline
quote:
ORIGINAL: N1EDM
Very good point. I was going to say the same thing as I also learned this the "hard way".
It is extremely difficult in some cases, to flush cut or sand down dowels from behind the firewall if you do not have A LOT of access.
Better to glue the down so the back is flush with the inside of the firewall.
I usually either flush cut or sand down the protruding part at the firewall front. Japanese flush cut saws are GREAT for this.
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to N1EDM)
       Post #: 6
RE: Engine mount repair - 11/14/2012 8:39 PM
Live Wire
Score: 6334
Status: offline
With the mounts that close to the edge you are asking to get the engine in your face with out replacing the firewall and doing it right
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to opjose)
       Post #: 7
RE: Engine mount repair - 11/15/2012 12:11 AM
rsdonomoore
Score: 102
Status: offline
I guess I'm going to try the dowel idea. They should have the hard wood dowels at the local hobby shop right?
rsdonomoore
Hide Signatures
(in reply to Live Wire)
       Post #: 8
RE: Engine mount repair - 12/28/2012 11:23 PM
f16man
Score: 106
Last Login: 6/13/2013
Status: offline
Yup or any hardware store should have poplar dowels for wood working projects [ home depot, lowes.ace, or any home improvement store.]
Hide Signatures
       Post #: 9
RE: Engine mount repair - 12/29/2012 2:39 PM
kenh3497
Score: 115
Last Login: 6/11/2013
Status: online
This is a VERY easy thing to do. Use a flat tool of some king to make sure the dowel is flush on the back side of the firewall and sand the front flush after the epoxy cures. It is OK to drill out the hole on the firewall for a slightly larger dowel if needed. When I was doing some tool and die work we did this on occasion to "repair" a mistake
Ken
Sent from my Dry-Erase-Board
Hide Signatures
       Post #: 10
RE: Engine mount repair - 12/30/2012 6:33 AM
nitro wing
Score: 125
Status: online
quote:
ORIGINAL: Live Wire
It does look a bit sketchy
seems the upper portion is likely not attached to much except sheeting.
I would drill and put some small screws in the sides of the firewall or better drill and put small wooden dowels around 1 inch long to add more security.
You do not want a 18 inch prop and engine becoming dislodged while standing in front of it.
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
