Lets see your original designs    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Lets see your original designs
Page: [1] 2   next >   >>
Login
Lets see your original designs - 11/14/2012 11:26 AM
AA5BY
Score: 153
Last Login: 5/23/2013
Status: offline
If you have built and flown (any length of flight qualifies) your original design, lets see it. It can be any type of model plane including scale if you drew the plans.
It would be interesting to see how much and what variety of craft are created.
Provide the basic details of the plane as well of course pics and other notes that might be of interest about the build such as when, why, length of build and current status.
It doesn't have to be current... any creation in your modeling history is more than welcome.
Hide Signatures
       Post #: 1
RE: Lets see your original designs - 11/14/2012 11:53 AM
AA5BY
Score: 153
Status: offline
My only design is a 96" sport/aerobatic RC powered by a 35cc gas engine. Weight is 16.5 lbs constructed with a foam cored wing and balsa stick airframe with forward lite ply box construction covered with UltraCote.
The design goals were for a '30s era sport/racer look having good flight qualities for traditional and somewhat scale aerobatics.
The design was conceived during the spring of 2011, plans drawn during the summer and finalized in late December. Construction began in January of 2012 taking four months. It currently gets flown several times a month.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 2
RE: Lets see your original designs - 11/14/2012 12:14 PM
bogbeagle
Score: 148
Status: online
This model was first flown in May of this year. Has, so far, accumulated 6.1 flying hours.
Span is about 80". No plans ... I just made it up as I went along.
Undercarriage is bungee sprung, rather like the early Fokker monoplane fighter. Works very well.
The wing is secured by a single steel pin at the TE, which makes assembly very easy. There is, of course, a tongue at the LE of the centre-section.
Power is my modified YS 1.20, which is a delight to use. Since the fuel tank is under the wing, there is a fuel pump.
The fuselage is braced internally with rattan strips ... just an experiment. Successful, though.
Twin flight packs are carried.
Quite a few bracing wires around the tail end; mostly there to add character.
Rudder, skid and elevators are operated by exposed closed loop.
Cockpit and area immediately forward of pilot are made from Cornflakes packet.
Wheels are homemade. Ply, ali sheet and O-ring material. They weigh the same as Flair vintage wheels. A slight cost-saving, but, "Hey, they're my babies."
General covering courtesy of Solartex, painted with acrylics.
Marking is Italian ... just made it up... simple, but tasteful, I think.
Powerful flaps demand respect.
Very pleasant to fly. No bad habits. (just like me!)
In essence, it's a pattern-ship and it goes pretty much where you point it.
My design philosophy was to create something with a bit of character, but which was sporty. It's a good aerobat (well it's better'n me) but will stooge around at low speed at very modest power settings. Ground handling is very good, despite the tail-skid.
I like it.
< Message edited by bogbeagle -- 11/14/2012 1:04 PM >
Hide Signatures
(in reply to AA5BY)
       Post #: 3
RE: Lets see your original designs - 11/14/2012 12:15 PM
wildwillie3
Score: 100
Status: offline
Very Nice!
Both of them
Bill
Hide Signatures
(in reply to AA5BY)
       Post #: 4
RE: Lets see your original designs - 11/14/2012 12:52 PM
curtrc
Score: 100
Last Login: 1/30/2013
Status: offline
As a matter of fact I just finished one! A 30cc 1/4-scale Pitts S-12 designed for 3D, I call her the "Pitts Dash".
Designed the entire aircraft in 3D CAD, then had the intricate parts laser-cut and filled in the rest. Spent long hours with a calculator and books on aerodynamics and it paid off, she flies solid.
Here is the build thread:  http://www.rcuniverse.com/forum/m_11096359/mpage_1/key_/tm.htm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 5
RE: Lets see your original designs - 11/14/2012 4:25 PM
142088
Score: 100
Last Login: 12/3/2012
Status: offline
Click for fullsize
Hide Signatures
(in reply to curtrc)
       Post #: 6
RE: Lets see your original designs - 11/14/2012 4:46 PM
bogbeagle
Score: 148
Status: online
Well, aren't you going to tell us something about this glider?
Hide Signatures
(in reply to 142088)
       Post #: 7
RE: Lets see your original designs - 11/14/2012 5:40 PM
All Day Dan
Score: 151
Last Login: 5/21/2013
Status: offline
Here are my four canards I designed just to be different. Sorry for including me in the images but they are the only ones I have. They are in chronological order as you can tell by my hair line. All had the CGs are well in front of the wing and about two inches in front of the main wheel axels. I got the location of the CG from various equations I picked up from the magazines and books. They all survived the first flight and I made the final CG adjustments after that. The first three were powered by VECO 61s. I do not have the details for them any more. The last one is powered by a Brison 2.4. The wing area is 1120 square inches and it weighs 23 pounds which includes 42 ounces of lead in the tail. With a wing loading of 47 ounces per square foot landings were always fast. Getting the proper location of the Cg for canards is easy now with the use of this website. I did check it against what I know and it is accurate. The first three plans were hand drawn and the last one was drawn with AutoCAD. Dan.
http://adamone.rchomepage.com/cg_canard.htm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Dan
Hide Signatures
(in reply to AA5BY)
       Post #: 8
RE: Lets see your original designs - 11/14/2012 6:15 PM
142088
Score: 100
Status: offline
Ok.
I am a returnee. About 1983 to 1986 I was messing around changing Craft Air's Drifter II.
I quit all R/C in 1992 and the "evolution" had stopped at 100 inch span poly and spoilers.
Drifter IIs were adaptable or so I and an OFB thought.
V-Tails T-Tails, 2M and Std 100". Flying Stabs, Polyhedral wings, straight wings with and without ailerons and on and on.
We found it a great trainer and good to experiment with.
I now wish I had never quit.
I returned in 2008 and scratch built this plane in 2010 as a mule based on the evolved 1986 version to serve as a trainer for myself as well as others.
Therefore I built it a little sturdier but kept simple and stable.
Rudder Elevator and Spoilers, in this photo the blade and frames for the spoilers were installed but I didn't have the right servos at that time.
I widened the fuselage one standard servo width wider in case I want to use a channel for something else. Chute drop? Candy drop?
It is all balsa and spruce and a dash of ply. I fly hi-start mostly so I didn't use carbon fiber in the spar as I would if I built it now.
I never named the thing in 1983 so why start now? Airplane num 1 I guess.
I am overall pleased with it, it flies like a floater like a big Drifter II pretty much. Not as twitchy as a 2M though.
I bet some folks will recognize the lines of Tom Williams' 2M aircraft.
Yes, there is a new Airplane num 2 based on the 1986 plane more LSF task oriented and less "trainer". It is stuck in the CAD-land right now though.
Good things to all
142088
4677
Hide Signatures
(in reply to bogbeagle)
       Post #: 9
RE: Lets see your original designs - 11/14/2012 7:44 PM
jim19
Score: 100
Last Login: 5/9/2013
Status: offline
This is my Gemini GT40. It is the .40 size version of the Gemini GT25 which I designed a few years ago. It has a 66" wingspan, all wood construction, SpringAir retracts and is powered by two ThunderTiger Pro .40's. A very good handling twin with a top speed in the 130 mph range. Also has good slow speed handling and is very maneuverable, a pleasure to fly. Flaps allow smooth landings with no tendency for the plane to balloon when the flaps are lowered.
Jim
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 10
RE: Lets see your original designs - 11/14/2012 11:12 PM
AA5BY
Score: 153
Status: offline
Wow... came in from work and found some interesting and good looking creations and obvious craftmanship. Dig out the pics and post em.
Hide Signatures
(in reply to jim19)
       Post #: 11
RE: Lets see your original designs - 11/14/2012 11:15 PM
AA5BY
Score: 153
Status: offline
Hide Signatures
(in reply to jim19)
       Post #: 12
RE: Lets see your original designs - 11/15/2012 12:29 AM
jeffp51
Score: 100
Last Login: 5/22/2013
Status: offline
Night bipe. 32" suffered its demise when I got disorientated on landing approach. should have become more accustomed to it before I flew it at night.
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 13
RE: Lets see your original designs - 11/15/2012 2:26 AM
flyingagin
Score: 114
Status: offline
I designed and built this one, called it the "Purple People Eater".
K&B Sportster 65 for power. Only needed about 1/2 throttle. The most enjoyable part of flying it was shooting touch and goes. Darn thing flew like it was on rail road tracks. I could get 30 minuts on a 16 ounce tank.
Construction was foam board, Paper left on. Fuse sides, top and bottom, foam board. I did use some ply as doublers up front to cary the fire wall and all other stressed attach oints. Tail feathers more foam board with spruce spars. The wing ribs were also foam board. Spruce spars, balsa leading edge and trailing edge.
Covering was fabrick and dope.
I think it was about a 6' wingspan.
Ken
Click for fullsize
Click for fullsize
"As for Me and My House, We Will Serve the Lord"
Club Saito Member 775
Hide Signatures
(in reply to jeffp51)
       Post #: 14
RE: Lets see your original designs - 11/15/2012 2:32 AM
flyingagin
Score: 114
Status: offline
And here is another plane I designed and built. This one control line. Grossly overpowered with a piped .60. It about pulled my arm off.
Again fabrick and dope finnish. Normal balsa construction this time
Ken
Click for fullsize
Hide Signatures
(in reply to flyingagin)
       Post #: 15
RE: Lets see your original designs - 11/15/2012 2:34 AM
flyingagin
Score: 114
Status: offline
There have been others I designed and built but no photos.
I have even used cardboard.
Ken
Hide Signatures
       Post #: 16
RE: Lets see your original designs - 11/15/2012 3:52 AM
Instructor
Score: 105
Status: offline
This is a stand off scale version of a U-2 that I scratch built. I made my own mold and the fiberglass fuselage. The wing is built up balsa and covered in Ultrakote. The fuselage is 35" long and the wingspan is 67". It weights 3 pounds ready to fly with a 4 cell li-po battery. I got tired of only getting four minutes from my EDF RC Lander F9F Panther. This plane now has about 30 flights on it and it flies for 8 minuets.
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 17
RE: Lets see your original designs - 11/15/2012 5:05 AM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: bogbeagle
I love it Bob! The design, construction, and finish are all excellent.
Hide Signatures
       Post #: 18
RE: Lets see your original designs - 11/15/2012 5:13 AM
Chad Veich
Score: 265
Status: offline
I've done a few sport types in the distant past but did not take many pictures and what few I did take are 35mm. No scanner so can't share them I'm afraid. These days all my designs are scale, typically WW2 subjects but not exclusively. Here are a couple recently completed and a couple still under construction.
Hide Signatures
(in reply to Chad Veich)
       Post #: 19
RE: Lets see your original designs - 11/15/2012 5:56 AM
countilaw
Score: 219
Status: offline
I  engineered,  disigned,  this plane.  It's for fun flying.   58" wingspan,  59" long, powered by a   O.S.  .61 FS,   J R  7202  radio.   It even flies the pattern pretty well.   Unfortunately,  it can't be classified as SPA or CPA.    One of  the other members of my club flew it and his only comment was,  " Sweet" !
From looking at all these   originals,  and they say that there are no more builders !
Frank
Click for fullsize
Click for fullsize
Click for fullsize
It''s a hobby, not a job.
Hide Signatures
       Post #: 20
RE: Lets see your original designs - 11/15/2012 11:07 AM
Lifer
Score: 148
Status: offline
I have a long running love of the old NotForSale design, and my control-line roots are evident in a facination with profiles. Lots of fun!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to countilaw)
       Post #: 21
RE: Lets see your original designs - 11/15/2012 1:32 PM
ARUP
Score: 134
Status: offline
Hot off the assembly line! Just finished instrument panel and skid. Currently fabricating venturi tube, backrest and carving pilot. Still needs some graphics. 1/6 scale BS2 'Balestruccio' sailplane 118" span. Hand drawn plans from 3-view in book.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Lifer)
       Post #: 22
RE: Lets see your original designs - 11/15/2012 9:35 PM
sensei
Score: 176
Status: offline
Here is a couple of my mine, 52% Extra 300 SP, 55% Extra 260, 70 Staudacher, and my 35% Extra 300S. I scratch built them and all have been flown.
http://images.rcuniverse.com/gallery/photos/33455/lg-235421.jpg http://images.rcuniverse.com/gallery/photos/33455/lg-235422.jpg http://images.rcuniverse.com/gallery/photos/33455/lg-235423.jpg http://images.rcuniverse.com/gallery/photos/33455/lg-88503.jpg
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to ARUP)
       Post #: 23
RE: Lets see your original designs - 11/15/2012 10:53 PM
AA5BY
Score: 153
Status: offline
And... the creations keep coming. Some really kool birds have been posted. At work today, I was thinking... what will be added today?
Hide Signatures
(in reply to sensei)
       Post #: 24
RE: Lets see your original designs - 11/16/2012 2:00 AM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: ARUP
Hot off the assembly line! Just finished instrument panel and skid. Currently fabricating venturi tube, backrest and carving pilot. Still needs some graphics. 1/6 scale BS2 'Balestruccio' sailplane 118'' span. Hand drawn plans from 3-view in book.
Really magnificent ARUP. Love to see some more, and larger, pictures.
Hide Signatures
(in reply to ARUP)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
