OS .60 SR muffler    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> OS .60 SR muffler
Page: [1]
Login
OS .60 SR muffler - 11/14/2012 6:29 PM
countilaw
Last Login: 5/18/2013
Status: offline
 I am in need of the  part number for a    stock muffler for the    O.S. Max   .60   SR.
Frank
_____________________________
It''s a hobby, not a job.
Hide Signatures
       Post #: 1
RE: OS .60 SR muffler - 11/14/2012 6:34 PM
vpresley
Status: offline
Hi
Its a 744 muffler.
Vince
Hide Signatures
(in reply to countilaw)
       Post #: 2
RE: OS .60 SR muffler - 11/15/2012 1:08 AM
countilaw
Status: offline
Sorry Vince,
           but  the  744  only fits the   Max   .61  SF ,   .61 FSR,      and will also fit the  .61  Evolution and  .61 ASP.         But not the   .60 SR.
The  744 is a bolt   through  muffler.    The bolt goes   "through"  the  crank case into the muffler.         The muffler for the   .60 SR is a bolt  "on" as the bolts go through the muffler and bolts the muffler  "on"  to the  crank case.
Some one out there in     OS  land  has a   .60  SR   with a stock muffler,   I just need the number of the muffler.      Come on guys,   go out into the shop and dig around in some of those boxes of old engines and get that number.    I'm counting on you.
Frank
< Message edited by countilaw -- 11/17/2012 11:57 PM >
Hide Signatures
(in reply to vpresley)
       Post #: 3
RE: OS .60 SR muffler - 11/15/2012 8:38 AM
vpresley
Status: offline
Hmmmmmm don't tell that to the 744 muffler currently bolted to my .60 FSR, I just looked again!!!
Vince
Hide Signatures
       Post #: 4
RE: OS .60 SR muffler - 11/15/2012 3:09 PM
turbo.gst
Status: offline
The OS 744 has 2 versions. The original 744 is a bolt to the engine. The second version the 744B was a bolt thru. The 61SF used the 744B, but the first versions had holes for either muffler. The older fsr series need the original 744 (bolt to) muffler.
Hide Signatures
       Post #: 5
RE: OS .60 SR muffler - 11/15/2012 3:46 PM
flyinwalenda
Status: offline
744        #26625009
744B     #26615010
Brian Ray
Hide Signatures
(in reply to turbo.gst)
       Post #: 6
RE: OS .60 SR muffler - 11/15/2012 4:49 PM
countilaw
Status: offline
 Vince you are right.    I've seen several   SR 60  with a  744 muffler on them.      Well guys,   I have   two  (2)   744  mufflers     they both fit the     .61 SF,    but will not  fit the  .60  SR.
Does't   the    774 B   have "744B"   on the header,  or  did they leave the B off?    I have not seen a  " B "  on  any  muffler.     If I find  a 744,  how will I know  which  model of the 744 will fit the   60 SR?         Any other ideas?         I really don't want to buy every  744 I find and  find out  that it won't fit.
Frank
Hide Signatures
       Post #: 7
RE: OS .60 SR muffler - 11/15/2012 5:02 PM
vpresley
Status: offline
Hi
The early version 744 muffler will have a much narrower bolt pattern, approximately 34 mm center to center bolt, like the 61 FSR. The newer version 744 has a longer, narrow exhaust port size.
Vince
Hide Signatures
       Post #: 8
RE: OS .60 SR muffler - 11/15/2012 6:57 PM
landeck
Last Login: 5/17/2013
Status: online
quote:
ORIGINAL: countilaw
Frank
The Fox tilt-up or the tilt-down mufflers for the Fox .61/.74 Eagle IV engines will fit the OS .60 SR. I just test it. You can order either style muffler directly from Fox.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 9
RE: OS .60 SR muffler - 11/15/2012 7:32 PM
earlwb
Status: offline
If the Fox mufflers fit then some of older  the Rossi mufflers would fit too.  The Fox mufflers use a about a 34.8mm screw spacing.
Macs Mufflers makes an adapter plate (bridge adapter)  for the Fox engines that you could use to adapt a Mac's muffler or other muffler with the same screw hole spacing to fit.
You could also fabricate a bridge adapter so that you could adapt most any muffler you want to fit too. I did that myself for my Fox engines and my Rossi engines could use the OS sized Performance Specialties Ultrathrust Mufflers (aka Nelson).
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to landeck)
       Post #: 10
RE: OS .60 SR muffler - 11/15/2012 11:11 PM
Hobbsy
Status: offline
Frank, do you have a picture of the .60SR, I have a .60fp, the E-4010 muffler looks to be much different. My LA .65 and .60FP each wears an E-4010.
Click to see fullsize image.
Click for fullsize
A young man knows the rules and an old man know the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 11
RE: OS .60 SR muffler - 11/15/2012 11:52 PM
turbo.gst
Status: offline
Yes the original 744 fits the 50-61 fsr, Rossi 60, Fox Eagle III & .60-.74 Eagle IV, Enya 60X, HP 61 Gold Cup, and Mvvs 10cc. I even have a couple of Webra Speed 61's that were drilled for this muffler spacing, but some have no muffler holes drilled( some HP's also have no holes). It was a great universal type muffler to bolt on for many engines of that time. I guess mfg's copied the popular OS spacing. There may be some other applications it will fit, but those are the one's I have and have tried the 744 on.
The OS 60FP will fit an OS 61SF as I traded for one of those without a muffler and the FP muffler fit. I am not sure about the volume as I have no 744B to compare it to.
Hide Signatures
(in reply to Hobbsy)
       Post #: 12
RE: OS .60 SR muffler - 11/16/2012 12:11 AM
ronwc
Status: offline
I put htis together for my own reference -
OS #761 - .10FSR .10FSR-S .10FSR-C .10FSR-M .10FSR-B CZ-1
OS Max #871 Muffler for 10 & 15FP, 15LA, 12-15 CZ and CV series engines. May fit other .10-.15 size engines
OS Max E-2030 muffler for the 20 & 25FP and the 25LA series engines. This muffler replaces the #842 OS Max muffler.
892 = O.S. replacement muffler for the OS MAX 25SF and 25FX engine.
3030 - O.S. muffler included now with the OS 35FP, 40FP and 32F engines. It is quieter than the #843 that used to come with the engine.
O.S. Max #873 - .40SF ABC .40SF-S ABC
.46SF-H .46SF ABC .46SF-S ABC
.46SF .46SF-HS .46FX Non-Ringed
O.S #873S super Silencer muffler used for the Max 40FX and 46FX engines.
4010 - O.S. replacement muffler for the OS MAX 60FP, 65LA, and 61FX Engines. 65LA
O.S. #855 muffler for the OS Max .91 & 108 FSR engines. Adapter plate takes the round/oblong exhaust port and makes it possible to mount the #855 muffler.
842 - FP 20 - 25
744 - 50 - 90 FSR - bolt to engine
744 (B) - 61 SF - bolt thru
703 - S 30 -35 -40
762 - 25 - 28 FSR
702 - 15 - 25
743 - 40 - 45 FSR
843 - OS 32-46 FP & LA
873 - 40 - 46 SF
4010 - OS 61 FX FP
761 - 10 FSR
E-4010 - OS MAX 60FP, 65LA, and 61FX Engines
E-4020 = OS Max 91 FX
Ron - AMA 1025 - Largo, FL
Hide Signatures
       Post #: 13
RE: OS .60 SR muffler - 11/16/2012 12:59 AM
countilaw
Status: offline
quote:
ORIGINAL: Hobbsy
Here are pictures of the  two engines,    the    .61 SF is on the left    and the     .60 SR is on the right.         Forgive the  balsa dust on the  SF,  I am in the process of fitting it to a new plane.    I would like to put the  SR in the new plane, but I don't have a muffler for it yet. So I am having to go with the  SF.
This is a real problem with the  Max Muffler.  It  Max didn't put   the     " B "  on the  744B  muffler it's going to be hard getting the right muffler for the SR.     Bummer !!
Frank
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by countilaw -- 11/17/2012 11:55 PM >
Hide Signatures
       Post #: 14
RE: OS .60 SR muffler - 11/16/2012 1:32 AM
Quikturn
Status: offline
You can go to macspro.com and get the one piece muffler or the Scotsman (silver) for a little less and an adapter plate. Maybe it's not ideal but at least it will get you going.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
       Post #: 15
RE: OS .60 SR muffler - 11/16/2012 1:34 AM
ronwc
Status: offline
quote:
ORIGINAL: countilaw
quote:
ORIGINAL: Hobbsy
Here are pictures of the  two engines,    the    .61 FS is on the left    and the     .60 SR is on the right.         Forgive the  balsa dust on the  FS,  I am in the process of fitting it to a new plane.    I would like to put the  SR in the new plane, but I don't have a muffler for it yet. So I am having to go with the  SF.
This is a real problem with the  Max Muffler.  It  Max didn't put   the     '' B ''  on the  744B  muffler it's going to be hard getting the right muffler for the SR.     Bummer !!
Frank
Not that hard to find, they turn up on ebay all the time, I have sold a few on there myself, I'll look to see if i have anymore laying around -
Hide Signatures
       Post #: 16
RE: OS .60 SR muffler - 11/16/2012 2:30 AM
fiery
Status: offline
A muffler from a series 1 ASP .61 will bolt right up as well.
Hide Signatures
(in reply to ronwc)
       Post #: 17
RE: OS .60 SR muffler - 11/16/2012 5:32 AM
jeffie8696
Last Login: 5/15/2013
Status: offline
Bruce at Brucercengines.com has a boxOmufflers and might have one that fits.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to fiery)
       Post #: 18
RE: OS .60 SR muffler - 11/17/2012 4:36 AM
countilaw
Status: offline
Thanks guys
Frank
Hide Signatures
(in reply to jeffie8696)
       Post #: 19
RE: OS .60 SR muffler - 11/17/2012 3:30 PM
TFF
Status: online
You have a small nomenclature problem you need a muffler for a FSR/SR. Your calling your SF an FS; people might be thinking FSR with your FS, causing confusion.
Hide Signatures
       Post #: 20
RE: OS .60 SR muffler - 11/18/2012 12:00 AM
countilaw
Status: offline
quote:
ORIGINAL: TFF
TFF,   Thank you  for bringing that to my attention.   I try to proof read everything, but  missed that.           Corrections made.
Frank
Hide Signatures
(in reply to TFF)
       Post #: 21
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> OS .60 SR muffler
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
