ca hinge strenthening    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> ca hinge strenthening
Page: [1]
Login
ca hinge strenthening - 11/14/2012 8:42 PM
tazzzz
Score: 100
Last Login: 5/18/2013
Status: offline
I just purchased a Sig Kadet Sr. the control surfaces are already CA hinged,,do you think I should add a couple of drops of thin to make sure they are secure enough? Or will that not work,seeing how they are already hinged,,,,every thing is tight,,they wont pull out . I just worry they skimped on the glue ,,,you know how some of these factories short-chang us sometimes. Any way to reinforce the to make sure they are secure? Or should I worry at all.
thxTAZZZZ
Hide Signatures
       Post #: 1
RE: ca hinge strenthening - 11/14/2012 8:59 PM
JohnBuckner
Score: 342
Last Login: 5/19/2013
Status: offline
Never try to redrop thin CA on Ca type hinges Once they have been dropped. You cannot redo them because the capillary action of the fibrous material is now compromised.
Just gently pull along the trailing edges of the surface near where each hinges is and if there is no give then everything is fine go enjoy your airplane.
There is even some thought that if you drop more CA at a later date that this could actually accerlerate a hinges failure (cracking or tearing at the hinge line itself).
John
_____________________________
"Keep your controllines tight"
Hide Signatures
(in reply to tazzzz)
       Post #: 2
RE: ca hinge strenthening - 11/14/2012 9:08 PM
tazzzz
Score: 100
Status: offline
OOOOhh WEEEEE,,,thanks ,,I guess Ill just put that thought in the hangar-Thank you sir.
Hide Signatures
(in reply to JohnBuckner)
       Post #: 3
RE: ca hinge strenthening - 11/14/2012 9:13 PM
wickedpissa
Score: 110
Status: online
You can toothpick them, dill the trailing and leading edge glue in a toothpick sand flat.
If you purchased it from SIG you should have a quality plane they are a great company. With that said I never use CA hinges I hate them I use pin hinges.
Hide Signatures
       Post #: 4
RE: ca hinge strenthening - 11/14/2012 9:41 PM
tazzzz
Score: 100
Status: offline
Yea,,so do I,, this is the first time Ive had a Sig pre-hinge anything,,,,,,,they staed that they changed manufacturers cause they had some sort of issues with the previous makers,,I definetly trust Sig ,,,theire good people.
Thanks for the comeback
Hide Signatures
(in reply to wickedpissa)
       Post #: 5
RE: ca hinge strenthening - 11/15/2012 1:43 AM
KitBuilder
Score: 131
Status: offline
What I do to be sure on my builds (not arfs) is near the end poke a pin hole though the wood through the hinge and out the other side. With the skinny syringe type tip I drop in top of bottom... let it harden and lightly sand. This way CA has gotten to the far end as well.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
