115FZ Crank re assembly    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> 115FZ Crank re assembly
Page: [1]
Login
115FZ Crank re assembly - 11/14/2012 10:49 PM
smasheruk
Score: 100
Last Login: 3/30/2013
Status: offline
 I am having touble getting the crankshaft back in the crankcase, I can not seem to get the crank ring into the housing and have cracked one  trying.
Is ther a special tool required?
Hide Signatures
       Post #: 1
RE: 115FZ Crank re assembly - 11/15/2012 3:13 PM
Bustabloodklaart
Score: 100
Last Login: 5/14/2013
Status: offline
Happy to lend you my universal tool Glen
Click to see fullsize image.
Click for fullsize
_____________________________
The Ground''s the limit
Hide Signatures
(in reply to smasheruk)
       Post #: 2
RE: 115FZ Crank re assembly - 11/15/2012 3:31 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
I had the same problem with a 70. I finally put a nylon wire wrap around ( shuved it down one side until it came out the other - cylinder off ) the ring and compressed it while I pushed it in. One of the official guys said that the camfer is sufficeint just to press the crank in on the 115 ? But there should also be room to put something around the ring to compress it while you push the crank in.
Hide Signatures
(in reply to Bustabloodklaart)
       Post #: 3
RE: 115FZ Crank re assembly - 11/15/2012 9:23 PM
smasheruk
Score: 100
Status: offline
 Thanks Four Stroker for such a simple obvious solution, I have to say there is not much sign of any chamfer in my crankcase
I will let you know how I get on whn I get the new ring
Hide Signatures
(in reply to Four Stroker)
       Post #: 4
RE: 115FZ Crank re assembly - 11/16/2012 7:20 PM
Four Stroker
Score: 104
Status: offline
The (crankshaft )ring only rides on one side. Just turn it around.
Hide Signatures
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> 115FZ Crank re assembly
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.109RCU1
