Carbon fiber radio trays    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Carbon fiber radio trays
Page: [1] 2   next >   >>
Login
Carbon fiber radio trays - 11/15/2012 3:05 PM
Beavis
Score: 110
Last Login: 5/23/2013
Status: offline
Where do you guys get all these carbon fiber radio trays that I keep seeing so often on these forums? Do you typically cut them yourselves, or is there a place that sells ready-cut / custom-cut trays for different models?
Also, wouldn't a carbon fiber tray have a negative impact on radio reception, depending on where the antennas are placed?
Thanks in advance.
Hide Signatures
       Post #: 1
RE: Carbon fiber radio trays - 11/15/2012 3:12 PM
Greg Wright
Score: 102
Last Login: 5/24/2013
Status: offline
Beavis,
I think most of those that you are seeing are actually wood trays covered with the carbon fibre looking monokote. Because real carbon does cause the 2.4Ghz radios to have issues.
_____________________________
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
(in reply to Beavis)
       Post #: 2
RE: Carbon fiber radio trays - 11/15/2012 3:13 PM
quist
Score: 116
Status: online
Most are plastic trays that look like carbon cloth. Dreamworksrc sells the material. It looks gray on the webstie but it is a black carbon pattern.
http://dreamworksrc.com/catalog/carbon-fiber-simulated-p-172.html
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
       Post #: 3
RE: Carbon fiber radio trays - 11/15/2012 3:35 PM
trioval00
Score: 110
Status: offline
on some of the tray's I have built were wood and covered with Monokote that looked like carbon fiber.
Mark
JPO District III rep - Turbine CD,
www.jpnepa.org
Hide Signatures
(in reply to quist)
       Post #: 4
RE: Carbon fiber radio trays - 11/15/2012 3:39 PM
k12rc
Score: 101
Status: offline
Xrea
dreamworks. Sells plastic look alike
don''''''''''''''cry'''''''' till''''''''it hits
Hide Signatures
(in reply to trioval00)
       Post #: 5
RE: Carbon fiber radio trays - 11/15/2012 3:40 PM
Gonzalo38
Score: 100
Status: offline
Take a look in here http://www.espritmodel.com/transmitter-trays.aspx I have a couple of the carbon ones and they are great.
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
       Post #: 6
RE: Carbon fiber radio trays - 11/15/2012 4:38 PM
DrScoles
Score: 105
Status: offline
there is monokote that looks like carbon? Awesome! I have the plastic sheets from dream works. Still need to put plywood underneath, don't think they're strong enough on there own. The monokote idea is sweet.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Gonzalo38)
       Post #: 7
RE: Carbon fiber radio trays - 11/15/2012 4:47 PM
Jame
Score: 100
Last Login: 4/19/2013
Status: offline
Very Neat Install Mike Cant beat plastic lookalike sheets, just score down the back with a scalpel and twist two or three times and they break leaving a clean edge, dont even need sanding if the cut is straight......Im always sanding mine to a nice finish
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to DrScoles)
       Post #: 8
RE: Carbon fiber radio trays - 11/15/2012 6:34 PM
ianober
Score: 100
Status: offline
I cut mine out of G-10 to custom fit on my CNC machine. Have been thinking about offering it as a service if some people wanted a custom tray
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Jame)
       Post #: 9
RE: Carbon fiber radio trays - 11/15/2012 7:16 PM
DrScoles
Score: 105
Status: offline
Getting it cut out on CNC would be cool. My problem is I sit there and kind of plan arrangement as I go. Can you cut the plastic sheets or do they just melt? Your G-10 is much lighter than the way I'm doing it.
Love the little wheel cover!
Hide Signatures
(in reply to ianober)
       Post #: 10
RE: Carbon fiber radio trays - 11/15/2012 7:52 PM
ianober
Score: 100
Status: offline
Yeah, I know what you mean Mike. The other problem is getting all the measurements for the parts and things that will go into the tray. I think ultimately its doable one way or another. I can cut the plastic no problem most likely with a single flute bit. They also make special plastic cutting bits.
Hide Signatures
       Post #: 11
RE: Carbon fiber radio trays - 11/15/2012 8:54 PM
cmjets
Score: 105
Status: offline
Hi friends:
I made it in wood and Oracover, it is a easy way for get a pretty job.
BR from Spain.
Carlos Márquez
______________________________________
http://cmjets.blogspot.com.es/
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Carbon fiber radio trays - 11/15/2012 11:03 PM
BaldEagel
Score: 118
Status: offline
Als hobbies sell plastic look alike in 34 x 66 sheets if I remember correctly : http://alshobbies.com/shop/lookupstock.php?pc=35093 I usually gorilla glue it to a 3mm piece of ply to give it a bit of strength if its going to hold any weight.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to cmjets)
       Post #: 13
RE: Carbon fiber radio trays - 11/15/2012 11:42 PM
highhorse
Score: 116
Status: offline
I believe the Monokote being discussed is actually Oracover and/or Ultracote. Works great, looks great, just build a wood tray and cover it up.
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to BaldEagel)
       Post #: 14
RE: Carbon fiber radio trays - 11/16/2012 12:02 AM
dbsonic
Score: 100
Status: online
Nice, These all look good.
Hide Signatures
(in reply to highhorse)
       Post #: 15
RE: Carbon fiber radio trays - 11/16/2012 12:16 AM
rcand
Score: 105
Status: offline
quote:
ORIGINAL: Beavis
Thanks in advance.
Don't use a carbon fiber tray, unles you don't mind crashing and buying a new plane.
Hide Signatures
       Post #: 16
RE: Carbon fiber radio trays - 11/16/2012 12:43 AM
Gary Arthur
Score: 105
Status: offline
Wood with covering works well.
Click for fullsize
Hide Signatures
(in reply to rcand)
       Post #: 17
RE: Carbon fiber radio trays - 11/16/2012 2:48 AM
LGM Graphix
Score: 166
Status: offline
quote:
ORIGINAL: rcand
quote:
ORIGINAL: Beavis
Thanks in advance.
I disagree with that, my Firebird (and all firebirds) have carbon fiber trays and none that I'm aware of have been lost to radio issues. Do a clean install and locate receivers and antenna's in spots that make sense and there is no issue.
remember when people actually BUILT their airplanes?
Hide Signatures
(in reply to rcand)
       Post #: 18
RE: Carbon fiber radio trays - 11/16/2012 3:02 AM
roger.alli
Score: 104
Status: offline
Some very nice installs here..
I just use plain old plywood..... And paint it.
Roger
Click for fullsize
Hide Signatures
(in reply to LGM Graphix)
       Post #: 19
RE: Carbon fiber radio trays - 11/16/2012 5:08 AM
rcjetsaok
Score: 135
Status: offline
Top Flite makes Carbon Fiber and Kevlar Monokote and Hanger 9 makes Carbon Fiber Ultracote. I prefer the Ultracote myself. Easier to work...
Danno
The Hobby Express - Jet Central Tejas
Hide Signatures
(in reply to roger.alli)
       Post #: 20
RE: Carbon fiber radio trays - 11/16/2012 6:45 AM
mavrick
Score: 100
Status: offline
Been using carbon fibre trays for years and never had an issue. I make my own I have a sheet of glass with 3mm sides and lay it up you can't tell the difference from the stuff you pay through the nose for.Make all my own horns as well.
Cheers
Mav
< Message edited by mavrick -- 11/16/2012 10:19 AM >
Hide Signatures
(in reply to rcjetsaok)
       Post #: 21
RE: Carbon fiber radio trays - 11/16/2012 12:59 PM
Dr Honda
Score: 100
Status: offline
The real carbon mounts act like a shadow just like metal. That's why Spektrum makes carbon specific Rx units. BUT... on an Rx like the 1221... you have 3 satellites. So... as long as they are mounted somewhere else... it's not a big deal.
I don't do the cleanest installs... but I also use wood, and covering.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to mavrick)
       Post #: 22
RE: Carbon fiber radio trays - 11/18/2012 3:32 AM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: ianober
G-10 builds up a surface charge... watch out... but if you spray a light coat of hair spray or clear on it, its ok..
We had issues in an EMI chamber with G10 discharges on a sensitive piece of calibrating electronics awhile back at work
Goose
Wren Turbines USA, Fromeco
Hide Signatures
       Post #: 23
RE: Carbon fiber radio trays - 11/18/2012 3:34 AM
gooseF22
Score: 103
Status: offline
my bandit.. and my elan.. painted
Click for fullsize
Click for fullsize
Goose
Hide Signatures
(in reply to gooseF22)
       Post #: 24
RE: Carbon fiber radio trays - 11/18/2012 5:55 AM
ianober
Score: 100
Status: offline
I am painting my boards so that wont be a problem. But the G10 I use from mcmaster states it has good electrical insulating properties so I dont see how it would conduct enough electricity to cause issues with the equipment.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.000RCU1
