RE: New DX18QQ Quique S edition    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: New DX18QQ Quique S edition
Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: New DX18QQ Quique S edition - 11/18/2012 12:54 AM
marquisvns
Score: 115
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: drac1
If the ''exclusive software'' for the QQ was made available to everyone, then the purchasers of the QQ would be pissed.
I doubt that would be the case, since QQ customers have all the other hardware included in the package, not mentioning QQ's signature
I would just hate to see if someone maxed out all the comparatively limited amount of sliders and switches and having to still rely on throttle trim to shut down a turbine and, in a time of need,wasn't able to. In the end, perhaps Horizon/Spektrum would have to be in the picture in terms of liability because it would take the pilot to hold and wait that throttle trim for minimum of 24 (100 clicks on default trim step) clicks before the engine shuts.
I am plenty satisfied with my bland 18 : ) However, I believe all the best and latest software, especially for sake of safety should be made available to all DX18 users, regardless of QQ or not.
Cheers,
Barry
_____________________________
www.kingtechturbines.com
kingtechturbines@gmail.com
Hide Signatures
(in reply to drac1)
       Post #: 51
RE: New DX18QQ Quique S edition - 11/18/2012 2:32 AM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: Frank Ts Stuff
For the mechanical throttle trim I read about a neat trick in another thread. Assign one of your sliders as the throttle trim. It may seem a bit unorthodox but it is a pretty innovative solution....
the standard 18 has slider as trim built in.. I use it now, trim menu.. you can select the digital trim, left or right slider...
Here is an idea to help: Everyone has seen the "I" button on top.. Set it as a throttle cut.. Yes its the trainer and bind button, so.......
1. Bind from the menu
2. IF you buddybox someone, Go to the training menu and set the enable switch to the BACK button on front of the transmitter.. I say the BACK because the CLEAR button clears the clock.. so when you do training, use the back button from now on, set the "I" button to kill, and that would free up your left slider for those that want it back.. or you can use the digital L/R trim like the DX8 for trim too..
For me, the left slider works fine,but I know some guys like smoke or speed brakes on that slider..
I moved my training button to BACK and I like it so far because i use the Cut for glow/gas birds because I dont want to move the trim from a good idle position.. takes a little getting used to because its below the sticks instead of above it, but its pretty natural after a couple mins..
try it..
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Frank Ts Stuff)
       Post #: 52
RE: New DX18QQ Quique S edition - 11/18/2012 2:43 AM
drac1
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: marquisvns
quote:
ORIGINAL: drac1
Cheers,
Barry
Purchasers are paying for a limited edition with extras only available on that particular model, so would not expect them to made available to other models?? Maybe or maybe not. Just my thoughts.
I don't fly turbines, (i have a P80SE but haven't fitted it to a model or bench run yet). Is that how you shut the turbine down, by pulling the throttle trim right back? I was under the impression that a switch was assigned for shutdown.
That's the reason i prefer the mechanical trim on throttle. It only takes a split second to have the trim where you want it to be.
There is no such thing as too much power.
Hide Signatures
(in reply to marquisvns)
       Post #: 53
RE: New DX18QQ Quique S edition - 11/18/2012 4:09 AM
marquisvns
Score: 115
Status: offline
quote:
ORIGINAL: drac1
quote:
ORIGINAL: drac1
Cheers,
Barry
If you assign engine shut off to a switch, then there goes a switch and an additional channel. Mechanical throttle trim is fine but an even wider trim step on throttle trim is essential for ALL DX18s, in my opinion.
Hide Signatures
(in reply to drac1)
       Post #: 54
RE: New DX18QQ Quique S edition - 11/18/2012 6:24 AM
PropsnWings
Score: 110
Last Login: 5/23/2013
Status: offline
It is just a "slap in the face" to not offer the DX18 the software, or even the "non pro" parts of it. Fine, keep the true Pro pilot parts of it for the QQ version, but allow the DX18 to become better than it is, by way of the software available to customize sound, avatars, no power off system menu access, customization flight modes.. etc.
By way of no choice, we who purchased the DX18 that was released only about 5 months ago, as the World Pro Class transmitter, now have the "standard edition".  And are no longer allowed updates via Airware, as now its "well all except".
I bought mine just about 2 months ago.  Too bad I cant return it now, or I would.
Really cruddy way to take care of your customer base, IMO.
Had they named it the QQ18, we really couldnt prove much .... but to add a couple letters to the end of it, and deny the first version updates of software that works on both, is going to leave "bad tastes" in a lot of peoples mouths, and cause them to make different brand choices in the future.
Yes, I am ticked off by this move.  I and many others feel cheated, and got cheated.   There needs to be an incentive program offered soon to the DX18 owners, to foster loyalty and retain the current customer base.
Hide Signatures
       Post #: 55
RE: New DX18QQ Quique S edition - 11/18/2012 6:30 AM
smitty1001
Score: 103
Status: offline
Pro. Class. Almost.
Jet Central Tejas
Hide Signatures
(in reply to PropsnWings)
       Post #: 56
RE: New DX18QQ Quique S edition - 11/18/2012 6:31 AM
spd101
Score: 100
Last Login: 5/21/2013
Status: offline
Im sticking with my 9303, never any issues
Hide Signatures
       Post #: 57
RE: New DX18QQ Quique S edition - 11/18/2012 12:58 PM
pmerritt
Score: 167
Status: offline
I don't own nor validate that much money for a DX 18.  I think most pilots bought hastily bought a DX18 for the ego sake anyway.   Those other than a few that have the ego planes with 24 servos that might "possibly" need the extra channel because God forbid we "Y" anything!
Anyway, I have one question to ask those of you DX18 owners.....Did it say anywhere in the Ads that there were free endless upgrades?
Are you DX18 owners still using Windows 3.0 because Microsoft charged for upgrades and comes out routinely with new OS?
You KNOW Spektrum has work in progress for a DX 4000 someday.   Do you expect that you should have your radio upgraded to that system ust because you bought a very expensive OLDER radio?
DUH.  You ran out an dumped a chunk of change on a hot new radio because you just had to have it yesterday so now you live with it.
How many times have you heard, "I'm going to wait and let them work the bugs out" on electronics?   Had you had a little patience, you might have the QQ now.
That being said, watch all the QQ owners go WAH WAH when the DX20 or DX4000 comes out the first of the year.  LOL.
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
(in reply to spd101)
       Post #: 58
RE: New DX18QQ Quique S edition - 11/18/2012 1:19 PM
smitty1001
Score: 103
Status: offline
Nevermind, now I get it! Everything is fine!
Jet Central Tejas
Hide Signatures
(in reply to pmerritt)
       Post #: 59
RE: New DX18QQ Quique S edition - 11/18/2012 1:22 PM
GerKonig
Score: 191
Status: offline
quote:
ORIGINAL: luv2flyrc
quote:
ORIGINAL: FenderBean
FUTABA is your friend
REALLY? They're not the friend of anyone who bought a 14mz two weeks ago at $2399 and now it's $1599. Or the guy who bought 12z @ $1599 and now it's $1099.
Mike
So now we complain because prices go down? Next what, will we complain because we are alive? Your comment makes no sense...
Gerry
Hide Signatures
(in reply to luv2flyrc)
       Post #: 60
RE: New DX18QQ Quique S edition - 11/18/2012 1:31 PM
gooseF22
Score: 103
Status: offline
Both are a great value, and the best link available in my opinion.. So those that adopted early, we all have a great transmitter.. I bought it for the link alone.. programming can be learned or adapted.. dont forget we flew jets with Super 8's, Fut 9, 9303's, and 10X's.. This radio is a big improvement over those generations...
Airware is still fully supported.. dont know where that statement came from..
Yes, I hope HH maintains inter-compatability between QQ and Std models.. Im sure they have considered that.. Anyone from HH know?
If you use a throttle cut, you do not lose a channel. it works just like any other radio's throttle cut.. just lowers the th channel PW by set amount in radio..
I flew a full season with the Std.. its still the best transmitter I have used.. I didnt really find any major limitations..
I do hope they enable the three step throttle trim.. I would think that is easily done in Airware.. HH please consider that one ported down.. Canard programming would be cool, but it can easily be done in the Std radio.. 6 servo wings can also be done.. using the dual input capability and channel assignment.. I dont know what else is exclusive.. I just like the looks of the new one, but I still would have bought the std instead of holding out... it has been perfect and my links have been solid.. I simply bought it over the 12x because of the dual antenna.. dont underestimate that important point.. THat alone is a huge improvement...
the QQ is a good value even if it had the standard programming because of the extras..so I do hope HH does port down most or all the doo dads to the Std.. I would think maintaining two separate SW loads is more difficult than commonizing them..assuming the hardware is the same.. my2C...
Goose
Hide Signatures
       Post #: 61
RE: New DX18QQ Quique S edition - 11/18/2012 1:49 PM
erbroens
Score: 105
Last Login: 5/22/2013
Status: offline
Exponential technological progress + marketing ideas = technological anxiety to the masses. LOL Welcome to the brave new world!
Enrique
Hide Signatures
(in reply to GerKonig)
       Post #: 62
RE: New DX18QQ Quique S edition - 11/18/2012 2:21 PM
saddler
Score: 100
Status: offline
Yes, you can transfer models from the original dx18 to the QQ version, I know first hand
Team Horizon Hobby
Wren Turbines USA
Hide Signatures
(in reply to erbroens)
       Post #: 63
RE: New DX18QQ Quique S edition - 11/18/2012 2:38 PM
bcovish
Score: 1018
Status: offline
Man, talk about a bunch of "whinners", this takes the cake. Grow up guys, load up the plane, the DX18 and go to the field, fly and have fun. Some of you think the sky is falling because your transmitter doesn't have "QQ" stamped on it.
I have a DX18 and I don't feel "cheated" or "violated". I paid my money, got a TX at a good value and does everything that it was advertised to do although I haven't tapped into all of it's capabilities yet and probably never will.
I'd go flying today with my DX18 but going to the F1 race in Austin.
Bob-O
Austin TX
Hide Signatures
       Post #: 64
pmerritt
Score: 167
Status: offline
Hey Erbroens you just invented the next PHD field.  Treatment for that disorder!   We can be the first to initiate a school to teach up and coming professionals how to handle that.  We'll call it    "PETAD"
POST EXPONENTIAL TECHNOLOGICAL ANXIETY DISORDER
Think of all the money we can scam from these bimbos!
Hide Signatures
       Post #: 65
RE: New DX18QQ Quique S edition - 11/18/2012 2:57 PM
luv2flyrc
Score: 102
Status: online
quote:
ORIGINAL: GerKonig
quote:
ORIGINAL: luv2flyrc
Mike
Gerry
Nobody's complaining Gerry,
The premise of this thread is that people are upset that Horizon has come out with a better "package" on the DX18, when many people had already purchased the radio. Some people feel they have been "shafted" after trusting Horizon.  Fender suggested Futaba wouldn't do this. I pointed out that they are in fact no different as people who trusted Futaba are likely to feel shafted that the company has dropped it's prices right after they purchased. Why does that not make any sense to you?
I persoanlly don't care what the price is, I'm not interested in either of these two brands. It was a simple comparison to show brand F's regard for the customer is no different /better/ worse then Brand S.  I don't plan to berate the point as Fender pointed out his comment was in jest anyway.
Mike
Hide Signatures
       Post #: 66
RE: New DX18QQ Quique S edition - 11/18/2012 3:07 PM
murdock0700
Score: 100
Last Login: 4/18/2013
Status: offline
How limited is it really ??? Are you guy's jumping all over this thinking you are gonna be 1 of only 2,000... I don't think so.!!  Read the wording of the Radio info on the H/H site.... ( I'll save you the research )   "   This stunning DX18QQ Limited Edition transmitter, of which only 2,000 have been made, " .. Does not say " Will be made " There might be another 10,000 on the assembly line as you all gripe.. It is what it is.. I can't help but think the guy's across the street are getting some good entertainment out of all this. I can't help but think that a lot of you guy's used to get the crap beat out of you on the playground at recess.!
Live long and prosper,
HM
Hide Signatures
       Post #: 67
RE: New DX18QQ Quique S edition - 11/18/2012 3:58 PM
Frank Ts Stuff
Score: 100
Status: offline
quote:
ORIGINAL: pmerritt
I don't own nor validate that much money for a DX 18.  I think most pilots bought hastily bought a DX18 for the ego sake anyway.   Those other than a few that have the ego planes with 24 servos that might ''possibly'' need the extra channel because God forbid we ''Y'' anything!
How many times have you heard, ''I'm going to wait and let them work the bugs out'' on electronics?   Had you had a little patience, you might have the QQ now.
In response to your question about updates from Spektrum...uh, yeah they kinda did...DUH
"And you'll always be up to date with the latest version of Spektrum AirWare thanks to the Spektrum Community and the Spektrum Data Interface (SDI). Just register your DX18 at community.spektrumrc.com and you'll receive alerts whenever a new version of Spektrum AirWare is available"
I love my DX18, it performs awesomely but I think we should be able to update our software to the latest version as promised....
Sean Curry
FTE Inc.
Hide Signatures
       Post #: 68
RE: New DX18QQ Quique S edition - 11/18/2012 4:04 PM
THERCAV8R
Score: 105
Status: offline
Yea, Software and $500 more dollars just for a name. Not me.
Hide Signatures
(in reply to littleguy901)
       Post #: 69
RE: New DX18QQ Quique S edition - 11/18/2012 4:21 PM
dubd
Score: 135
Status: online
quote:
ORIGINAL: pmerritt
Your Windows logic doesn't make sense. We're not talking about a software product, which in the case of any version of Windows, gets significant software iterations through each product lifecycle. If you want to use a non RC-example, compare what HH did to other consumer HARDWARE products.  Apple, which charges premiums for everything. Even Apple provides the same software upgrades to ALL of their iPhones. Same with Android... same with the Playstation, Xbox, TVs, and most modern consumer electronics. I don't care about the new physical changes to the QQ version of the DX18, but to omit the software changes is lame. There is no cost savings from HH to holdback the software other than to push sales of the QQ version for people who can spend more money.
To think people are buying a DX18 for "ego" is nonsense. I still prefer my 12X over my ego inflating DX18.
Hide Signatures
       Post #: 70
RE: New DX18QQ Quique S edition - 11/18/2012 4:29 PM
Tom Antlfinger
Score: 101
Status: offline
Thanks Sean for the model transfer info.....I suspected you could but nice to confirm as I couldn't definitely find an answer in the HH On-Line manual........
Tom
Hide Signatures
(in reply to saddler)
       Post #: 71
RE: New DX18QQ Quique S edition - 11/18/2012 4:32 PM
Tom Antlfinger
Score: 101
Status: offline
Now tell the truth Bob-O......you spent bags of money on your Ellen Degeneris Naughty Holiday Collection, and now you can't afford a QQ...
Hide Signatures
(in reply to bcovish)
       Post #: 72
RE: New DX18QQ Quique S edition - 11/18/2012 4:41 PM
bcovish
Score: 1018
Status: offline
quote:
ORIGINAL: Tom Antlfinger
Busted
Between that and Victoria’s Secret, I'm broke
Bob-O
Austin TX
Hide Signatures
(in reply to Tom Antlfinger)
       Post #: 73
RE: New DX18QQ Quique S edition - 11/18/2012 4:42 PM
PropsnWings
Score: 110
Status: offline
Has nothing to do with "affording" it.  I cant think of one time anyone felt a software UPDATE was ever worth $400, when told your current product would be updated for free when updates are available.
Anyways, I have said my piece, and I agree HH has painted themselves into a corner on this one.  Not just the DX18 is affected by this choice of exclusivity.  Any future products cannot have those software features either. So this is, IMO, gonna come back to bite them.
I can only hope and "dream" that HH will figure out that they need to make a change on this software stance, in order to attain and retain the level at which they had attained with the Spektrum name for now and in the future.  But that needs to be done now, and not after they have sold all 2000 units.  They need to admit there was a mistake made in making software exclusive to one version of the DX18, when they are features that would sell either version, and features that any purchaser of the DX18 should have.
Do I still like and use my DX18?  sure, but will I promote and look to Spektrum in the future? I am not so sure I will so quick to defend them now, with this, IMHO, a poor choice to hold the software from the current DX18 community.
Truly if anyone buying the DX18QQ bought it strictly based on the software, then I feel sorry for you, as those features should be a part of every DX18 and surely are not worth $400 extra.   And if you did make the choice based on the software, you missed the point of the QQ version.
Hide Signatures
       Post #: 74
RE: New DX18QQ Quique S edition - 11/18/2012 5:03 PM
smitty1001
Score: 103
Status: offline
quote:
ORIGINAL: gooseF22
This is what I've been saying all along, couldn't agree more with Goose. (except on the looks of the new one, just can't do that many Q's all over it and signature splash screens)
A couple of clarifying points:
1) The sky is indeed NOT FALLING, I can verify that as I was just outside. I did fly this morning, and I did have fun. And I used my new/standard edition DX18. It was great.
2) I still would have bought the standard DX-18 even if I knew about the Q one - it would have been nice to be offered the option though especially a week before it comes out. That's just sort of a customer service thing. What I do care about though is:
3) The software should be available to non-Q's even if there is a price for it. As Goose has said, we EXPECT several of the features like new turbine throttle trim, etc.
4) I don't think many, if any people purchased the DX18 for ego?!?! (maybe those that bought the standard and have now sold it for the Q-DX18?) For most of us flying JR, switching to an exclusive Spektrum radio was a little dicey - I guarantee the guys that put their 12x's down for the 18 weren't feeling like big swingin' richards to do so - but probably instead saw where the technology and support/marketing was going and were willing to follow Horizon and our friends that work there.
5) I am happy that we can type the word "pissed" now and it not get deleted, and, I'm happy that we have so many rational-intellectual types in this forum! It really balances out the whiners!
6) Discussing Bob-o's undergarments IS being violated!
Jet Central Tejas
Hide Signatures
(in reply to gooseF22)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
