NGH 38CC 4 stroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> NGH 38CC 4 stroke
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
NGH 38CC 4 stroke - 11/15/2012 6:50 PM
SJN
Score: 105
Last Login: 5/24/2013
Status: online
This looks nice.
Anyone got one yet ?
http://www.himodel.com/engines/NGH_GF38_38CC_4-Stroke_Petrol_Engine.html
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Sonnich Johannesen
Hide Signatures
       Post #: 1
RE: NGH 38CC 4 stroke - 11/15/2012 7:18 PM
earlwb
Score: 584
Status: online
I can't get one for a while, but I plan on it.
I find it odd they bent the fuel inlet tube over and pointed it up. That would tend to make the fuel line make a large loop to the carb on the engine.
Good thing they sold out already, so I don't have to fret about getting one for a while.
I noticed some people had posted videos of it already, so a few people are flying them so far.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to SJN)
       Post #: 2
RE: NGH 38CC 4 stroke - 11/15/2012 7:23 PM
Turk1
Score: 108
Status: offline
http://v.youku.com/v_show/id_XNDI3MzUxODU2.html
http://v.youku.com/v_show/id_XNDI3MzQ1NDQw.html
http://v.youku.com/v_show/id_XNDM0MjMxMjAw.html
http://v.youku.com/v_show/id_XNDM0MjMyMzQ4.html
http://v.youku.com/v_show/id_XNDM4MzcyMzky.html
Hide Signatures
(in reply to earlwb)
       Post #: 3
RE: NGH 38CC 4 stroke - 11/15/2012 8:07 PM
airraptor
Score: 130
Status: online
My thoughts are this is a big magnum engine that was set up for glow. now it will be gas with no increase in cooling fins. will have to run rich and dont think it could be cowled in.
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to Turk1)
       Post #: 4
RE: NGH 38CC 4 stroke - 11/15/2012 11:26 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: airraptor
Saito didn't increase the cooling fin area on their gasser four strokes either. But I don't know if anyone cowls the gasser Saitos  in or not.
AMA # 928076
Hide Signatures
(in reply to airraptor)
       Post #: 5
RE: NGH 38CC 4 stroke - 11/16/2012 12:18 AM
acerc
Score: 221
Status: online
Doesn't gas and nitro run in the same temperature range?  Thefore no change needed in the fin's or cowl application's?
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 6
RE: NGH 38CC 4 stroke - 11/16/2012 1:25 AM
mikes68charger
Score: 106
Last Login: 5/23/2013
Status: offline
 Who is selling this motor in the US?
i got my NGH 35. From AGAPE RACING AND HOBBY, and the customer service has been great
Hide Signatures
(in reply to acerc)
       Post #: 7
RE: NGH 38CC 4 stroke - 11/16/2012 4:25 AM
Ernie Misner
Score: 130
Status: offline
Gas doesn't give the cooling effect that running methanol through it does. The intake manifold on 4-strokes will get frost on them sometimes.
Hide Signatures
(in reply to mikes68charger)
       Post #: 8
RE: NGH 38CC 4 stroke - 11/16/2012 5:49 AM
Turk1
Score: 108
Status: offline
quote:
ORIGINAL: airraptor
 There should be a YouKu video  showing while running on bench they are checking temp continuously.I cant put exact link because that YouKu is a real trouble when I try to open.
Hide Signatures
       Post #: 9
RE: NGH 38CC 4 stroke - 11/17/2012 4:37 AM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: acerc
Gasoline doesn't provide a cooling effect that methanol does inside of the engine. Methanol runs at a much more rich air to fuel ratio and has a wide range for the ratio too. Gasoline on the other hand needs to be used at a much more lean air to fuel ratio and the range of the ratio is much more narrow.  But in any case the gas engines tend to operate at a somewhat more hot temperature than the glow engine does. But if you are using a really good quality oil in the engine the higher operating temperature isn't a problem. But operating the engine inside of a cowl on a airplane may require more careful consideration for air flow and ducts to route the air over the engine good too.
It is somewhat amazing how much cooling methanol can have in a glow engine. When you look a at some of the racing engines, they tend to have little to no cooling fins on them and they tightly cowl the engines in as well. But the engines run OK like that.
Here is the temperatures I was measuring on a NGH 9cc gas engine, at the base of the glow plug, when it was 82 degrees F outside a while back. In the heat of the summer when the ambient temperatures are higher, the engine's temperature goes up accordingly too.
AMA # 928076
Hide Signatures
(in reply to acerc)
       Post #: 10
RE: NGH 38CC 4 stroke - 11/17/2012 5:38 AM
Octopus RC
Score: 100
Last Login: 4/18/2013
Status: offline
It`s a good engine , you guys will love it !
We Offer XYZ / B&D / TGY / TMM Online Support and offer factory price replacement parts .Wherever and whenever you brought your engine from . Please check www.octopusrc.com . Big Save !!!!
Hide Signatures
       Post #: 11
RE: NGH 38CC 4 stroke - 11/17/2012 4:43 PM
airraptor
Score: 130
Status: online
quote:
ORIGINAL: Octopus RC
Coming from the saleman lol
What prop and rpm? how much is it in US. The roto motor 35 will spin a 20x10 xoar at 6,000
AMA # 186123
Hide Signatures
(in reply to Octopus RC)
       Post #: 12
RE: NGH 38CC 4 stroke - 11/17/2012 8:04 PM
SkyPilot101
Score: 125
Status: offline
It look's like the rod is equiped with needle bearings, that said, I would gladly snatch one up at $380, much better than 1000+ for a simular size Saito! Hell, run it on gas/glow mix if you want some extra cooling
Hide Signatures
       Post #: 13
RE: NGH 38CC 4 stroke - 11/18/2012 2:01 AM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: airraptor
One of the videos of them testing the engine had it turning a 20x10 wood unknown brand prop at 5,500 rpms.
I would assume the cost would be about $20 to $30 more in the USA than from HiModel in China.
AMA # 928076
Hide Signatures
       Post #: 14
RE: NGH 38CC 4 stroke - 11/18/2012 6:46 PM
jeffEE
Score: 120
Status: offline
I would pick one up if I could find one that was not "OUT OF STOCK".
If its not a warbird, Its just a target.
Hide Signatures
       Post #: 15
RE: NGH 38CC 4 stroke - 11/18/2012 9:23 PM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: airraptor
you ca only fit X amount of cooling fin area on a given mass of engine.
Hide Signatures
       Post #: 16
RE: NGH 38CC 4 stroke - 11/18/2012 10:09 PM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
First test on a production unit today:
GREAT ENGINE !!!!!
Include the engine mounting plate, RCEXL ignition, allen wrench, RCEXL standard CM6 spark plug,
My only guess is to include a 120 degrees spark plug cap. Better fit than 90 degrees supplied.
I've dismantled all parts to take pictures and check quality : awesome..
Needle bearings on both sides of con-rod, a custom WT1022 carb, very well made the intake mainfold , with two nipples, one for the oil from cranckcase and one for carb pressure pulses. Many interesting mechanical solutions, and NONE of the parts are from Magnum or a glow existing engine. All parts are designed from scratch. Like many others products of differents manufacturers ,they looks the same ....
Best regards
Hide Signatures
(in reply to TimBle)
       Post #: 17
RE: NGH 38CC 4 stroke - 11/18/2012 10:21 PM
WindGap
Score: 105
Status: offline
when will this get stateside?
Hide Signatures
(in reply to mpascual)
       Post #: 18
RE: NGH 38CC 4 stroke - 11/18/2012 10:36 PM
mpascual
Score: 115
Status: offline
quote:
ORIGINAL: WindGap
Sorry
I don't know.
Hide Signatures
(in reply to WindGap)
       Post #: 19
RE: NGH 38CC 4 stroke - 11/19/2012 12:28 AM
SkyPilot101
Score: 125
Status: offline
quote:
ORIGINAL: mpascual
GREAT ENGINE !!!!!
Best regards
Have you looked at the rocker box, do the valves run in guides? If so, do they look like bronze, I'm currious as to how well the exaust valve will hold up.
Hide Signatures
       Post #: 20
RE: NGH 38CC 4 stroke - 11/19/2012 12:41 AM
WindGap
Score: 105
Status: offline
definitely one of the more interesting offerings from China in a while
I'd play with this one and see how it turns out.
Hide Signatures
(in reply to SkyPilot101)
       Post #: 21
RE: NGH 38CC 4 stroke - 11/19/2012 7:24 AM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: mpascual
GREAT ENGINE !!!!!
Best regards
Hi Pascual,
Wll you be flying this soon? I'm interested to know  if it develops enough thrust for a 2x2 pattern application.
Hide Signatures
       Post #: 22
RE: NGH 38CC 4 stroke - 11/19/2012 5:08 PM
airraptor
Score: 130
Status: online
quote:
ORIGINAL: TimBle
quote:
ORIGINAL: airraptor
Yes that is true but you can make them wider ie: more aluminum to heat up and more area cool with.
AMA # 186123
Hide Signatures
       Post #: 23
RE: NGH 38CC 4 stroke - 11/19/2012 6:21 PM
TimBle
Score: 162
Status: offline
But the amount of heat needed to be absorbed by the air is in proportion to the power produced and the efficiency of the engine. If the mechanical efficiency is similar and power produced is similar then heat rejection is similar....
Hide Signatures
       Post #: 24
RE: NGH 38CC 4 stroke - 11/19/2012 8:15 PM
airraptor
Score: 130
Status: online
So this engine isnt very storng then???? lol
Glow ones ran warm. Then the gas one will run hotter is all I am saying.
AMA # 186123
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> NGH 38CC 4 stroke
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
