RE: NGH 38CC 4 stroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: NGH 38CC 4 stroke
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: NGH 38CC 4 stroke - 12/13/2012 5:38 AM
MKnutson
Score: 100
Last Login: 5/18/2013
Status: offline
Michaelchow,
Do you have plans at all to offer a muffler for this engine, and where can we get parts if needed?
Thanks in advance, Mark.
Hide Signatures
(in reply to MKnutson)
       Post #: 76
RE: NGH 38CC 4 stroke - 12/13/2012 6:52 AM
michaelchow
Score: 105
Status: offline
Mr. Mark, do you mean there is no muffler in GF38 box? each GF38 has a muffler inside engine box. please check.
Hide Signatures
       Post #: 77
RE: NGH 38CC 4 stroke - 12/13/2012 7:03 AM
SJN
Score: 105
Status: online
Hi Michael, there is no muffler in my box either, only the 55 degree exhaust header pipe.
_____________________________
Sonnich Johannesen
Hide Signatures
(in reply to michaelchow)
       Post #: 78
RE: NGH 38CC 4 stroke - 12/13/2012 7:08 AM
SJN
Score: 105
Status: online
you need to make something like this for the NGH 38cc
Click to see fullsize image.
Click for fullsize
Sonnich Johannesen
Hide Signatures
(in reply to SJN)
       Post #: 79
RE: NGH 38CC 4 stroke - 12/13/2012 8:30 AM
michaelchow
Score: 105
Status: offline
Mr. Johannesen, thanks for your advice. I will try to make the beauty in picture for GF28cc future. current GF38 is just with  simple exhaust header pipe, but I will make some new, just afraid vibrating will effect long pipe. so need your more  professional suggestions. thank you. michael
Hide Signatures
(in reply to SJN)
       Post #: 80
RE: NGH 38CC 4 stroke - 12/13/2012 4:39 PM
vertical grimmace
Score: 149
Status: offline
How does this engine sound with the straight pipe? Are the DB too high?
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 81
RE: NGH 38CC 4 stroke - 12/13/2012 6:13 PM
SJN
Score: 105
Status: online
Fired it up twice for a few seconds just to make sure it runs before taking it out to the field for break in.
It was quite difficult to prime the carb for the first time, and it did not want to draw fuel.
I had to cap off the vent line that is under the cam shaft, so a pressure pulse could reach the carb, to make it pump.
I also pressurized my tank, to push fuel into the carb.
But after that, it seems to draw fuel just fine, and I could remove the cap on the vent line.
It ran realy rough, but I expeced that since it has no run time on it.
Once, it kicked back, and loosened my prop nut, so it had to b re-tightned.
Running it in my 27% cap232 with out the wings on to dampen the vibration it brutal
It realy kicks hard at the moment, and shakes my airframe. Wings on next time.
Im quite sure I wil lhave to buy a muffler for it, as the sound level seems quite high......will have to see when I get it outside.........in the snow
Click for fullsize
Click for fullsize
Click for fullsize
Sonnich Johannesen
Hide Signatures
(in reply to vertical grimmace)
       Post #: 82
RE: NGH 38CC 4 stroke - 12/13/2012 9:04 PM
SJN
Score: 105
Status: online
Found another youtube video:
http://www.youtube.com/watch?v=6w53WABuoXQ
16x8 8050rpm
18x8 7300rpm
Sonnich Johannesen
Hide Signatures
(in reply to SJN)
       Post #: 83
RE: NGH 38CC 4 stroke - 12/13/2012 9:46 PM
SJN
Score: 105
Status: online
And a flight video from Norway
http://www.youtube.com/watch?v=XvAUaFe3xuQ&feature=player_embedded
Sonnich Johannesen
Hide Signatures
(in reply to SJN)
       Post #: 84
RE: NGH 38CC 4 stroke - 12/14/2012 2:49 AM
MKnutson
Score: 100
Status: offline
Sonnich,
Your engine will get better with more time. Mine is running pretty good now that it has about 1.5 hours on it. This engine is a fuel miser, you can use a real small tank in the plane. Mine now will run about 30-45 min. on 6oz. at very fast idle and full throttle runs. It also runs much smoother on less oil in the fuel...28-1.
I'm thinking about getting a Saito 220/fg36 muffler to put on mine, it's a little too loud for our field with a straight pipe only.
Still haven't got an answer from Michael about parts yet. So far there doesn't seem to be very many of us running/flying these engines yet. There MIGHT be an issue with the aluminum header stress cracking at the flange.....just thinking.
Mark.
Hide Signatures
(in reply to SJN)
       Post #: 85
RE: NGH 38CC 4 stroke - 12/14/2012 3:46 AM
michaelchow
Score: 105
Status: offline
Mr.Mark,sorry for Late response. Parts supply for four stroke is very important, so it is most important for me consider parts supply smoothly.  dealers will soon inventory parts, we ensure original made parts and very easy to get parts. so please contact dealer you bought from and send a request, dealers will service you No matter whether you bought from him. and let me know result please. thank you very much, michael
Hide Signatures
       Post #: 86
RE: NGH 38CC 4 stroke - 12/14/2012 4:02 AM
michaelchow
Score: 105
Status: offline
moreover, please pay attention. different prop and oil will get different output data on same engine. someone prefer smaller size prop to get bigger tension even use 16*8 Three-bladed propeller. we always use 20*8 wood prop, normal output is at about 6000rpm, If your engine speed far lower from 6000rpm, Please consider you use prop and  oil, please use higher grade 100% complete synthesis oil. thanks
Hide Signatures
       Post #: 87
RE: NGH 38CC 4 stroke - 12/14/2012 5:15 AM
Turk1
Score: 108
Status: offline
Hi Michael, when new batch of engine will be on sale again?
Hide Signatures
       Post #: 88
RE: NGH 38CC 4 stroke - 12/14/2012 5:35 AM
michaelchow
Score: 105
Status: offline
Mr.Turk1 , Do GF38 really a little difficult, And the number of each batch is not much, We'll have a lot of work to do. A batch of goods will be sold in the next week, but has set out. This lot of goods to the main supply to Europe Just engines/modelpascher and himodel,taiwan, and Christian Traders Australia. thank you.
Christmas is coming, best wishes for you all!
MERRY CHRISTMAS!
Hide Signatures
(in reply to Turk1)
       Post #: 89
RE: NGH 38CC 4 stroke - 12/14/2012 9:22 AM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
I like your 4 stroke very much !!
Do you have plans to make twin four stroke !
Very interested !!
Merry Christmas
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
       Post #: 90
RE: NGH 38CC 4 stroke - 12/14/2012 3:16 PM
Flyer88
Score: 100
Status: offline
Can anybody tell me if AMR stocks the latest version of this for stroke 38 gasser
Hide Signatures
(in reply to Ernie Misner)
       Post #: 91
RE: NGH 38CC 4 stroke - 12/14/2012 3:24 PM
SJN
Score: 105
Status: online
Since this engine only has been around for a few weeks now, it will be the same as the ones in this thread
Sonnich Johannesen
Hide Signatures
(in reply to Flyer88)
       Post #: 92
RE: NGH 38CC 4 stroke - 12/15/2012 1:27 PM
earlwb
Score: 584
Status: online
I was thinking that the ASP 1.80 four stroke engine's exhaust and or muffler would fit this engine. Both engines are, more or less, look a lot alike. At least the muffler itself might be useable.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to SJN)
       Post #: 93
RE: NGH 38CC 4 stroke - 12/15/2012 5:17 PM
jeffEE
Score: 120
Status: offline
AMR, thats where I ordered my motor from last week. I still have not got it in the mail yet, but that is not AMR's fault. It has been sitting in New York for the last 5 days. Must be the Xmas rush in the mail room. But according to the mail tracking site, it is on its way to a local mail center.
I was thinking about the muffler set up also. I have a saito 2.20 four stroke, and I will see if the muffler can be fitted. And if it can fit, will it help the noise level. I will let you know.
If its not a warbird, Its just a target.
Hide Signatures
(in reply to earlwb)
       Post #: 94
RE: NGH 38CC 4 stroke - 12/15/2012 5:24 PM
SJN
Score: 105
Status: online
Looking forward to hearing your results with mufflers.
The ASP/Magnum 180 muffler looks a bit restrictiv to me, as the outlet is fairly small.
One would have to weld a threaded pipe to a flange to bolt onto the side of the engine.
Installing a piece of silicone on the exhaust header, takes the sharp pitched noise a bit......but it is still loud.
< Message edited by SJN -- 12/16/2012 2:35 PM >
Sonnich Johannesen
Hide Signatures
(in reply to jeffEE)
       Post #: 95
RE: NGH 38CC 4 stroke - 12/16/2012 2:26 PM
jeffEE
Score: 120
Status: offline
how well does the silicone hold up to the heat? I would like to route mine to a more scale location, but was affraid the silicone would not stand the abuse.
Hide Signatures
(in reply to SJN)
       Post #: 96
RE: NGH 38CC 4 stroke - 12/16/2012 9:38 PM
rcguy59
Score: 129
Status: offline
Silicone Should NOT be used with petroleum-based fuel. The fuel and it's residules will destroy the silicone pretty quickly. Use Teflon (PTFE) instead. It holds up much longer.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
       Post #: 97
RE: NGH 38CC 4 stroke - 12/17/2012 1:56 AM
Ernie Misner
Score: 130
Last Login: 5/17/2013
Status: offline
Where are you getting the Teflon tubing Mike?
Hide Signatures
(in reply to rcguy59)
       Post #: 98
RE: NGH 38CC 4 stroke - 12/17/2012 2:07 AM
Flyer88
Score: 100
Status: offline
http://www.youtube.com/watch?feature=player_detailpage&v=PBFwA0OSP1M
Troy Built Models silencer
Hide Signatures
       Post #: 99
RE: NGH 38CC 4 stroke - 12/17/2012 2:24 AM
rcguy59
Score: 129
Status: offline
It can be found online, Ernie. It's seldom cheap, but it's gas-proof and resists VERY high temps. Perfect for exhaust use.
Hide Signatures
       Post #: 100
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: NGH 38CC 4 stroke
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
