AFPD problem with mountain lion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AFPD problem with mountain lion Page: [1]
Login
AFPD problem with mountain lion - 11/15/2012 8:11 PM
ekeesee
Score: 100
Last Login: 3/4/2013
Status: offline
Hi mike,
I have been running AFPD on my iMac without any problems for about a year. Recently I upgraded from snow leopard to mountain lion and my AFPD is crashing when I start the program. Do you know of any compatibility problems with mountain lion?
thank you,
Ed
Hide Signatures
       Post #: 1
RE: AFPD problem with mountain lion - 11/15/2012 8:45 PM
ekeesee
Score: 100
Status: offline
here is the problem report generated when it crashes thanks again
Process: AeroFly [13342]
Path: /Applications/AeroFly Professional Deluxe/AeroFly.app/Contents/MacOS/AeroFly
Identifier: aerofly.com. AeroFly Professional Deluxe
Version: AeroFly Professional Deluxe Version 1.11.07.29 (1.0)
Code Type: X86 (Native)
Parent Process: launchd [160]
User ID: 501
Date/Time: 2012-11-15 10:38:03.756 -0600
OS Version: Mac OS X 10.8.2 (12C60)
Report Version: 10
< Message edited by rajul -- 11/15/2012 11:29 PM >
Hide Signatures
(in reply to ekeesee)
       Post #: 2
RE: AFPD problem with mountain lion - 11/15/2012 11:27 PM
rajul
Score: 105
Last Login: 5/25/2013
Status: offline
Hi ekeesee, AFPD is compatible with mountain lion, and there should not be any problem. Try this: Completely DELETE AFPD from your mac, then install it again. Then download and apply patch 1.11.7.31 which you can find here http://www.aerofly.com/afpd/downloads.html
(Note: I removed most of your system report above because it shows your AFPD key, which should be confidential to you)
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
       Post #: 3
RE: AFPD problem with mountain lion - 11/16/2012 4:05 AM
ekeesee
Score: 100
Status: offline
Thanks for the quick reply mike,
I re-installed AFPD and the patch and have found it works normally as long as I start the program from the AFPD directory in the applications menu. If I try to start from "launchpad", AFPD crashes. I dont know why this occurs but it makes for an easy solution to just start from finder.
Thanks again,
Ed
Hide Signatures
       Post #: 4
RE: AFPD problem with mountain lion - 11/16/2012 11:34 AM
rajul
Score: 105
Status: offline
Hi Ed, I recommend to install the afpd folder in the users folder and not in Applications.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 5
RE: AFPD problem with mountain lion - 11/16/2012 1:38 PM
ekeesee
Score: 100
Status: offline
Thanks mike, I'll do that. Would you place the AFPD folder and all of its contents including the aerofly app in the users folder, or would you leave the aerofly app in applications?
Hide Signatures
(in reply to rajul)
       Post #: 6
RE: AFPD problem with mountain lion - 11/16/2012 1:43 PM
rajul
Score: 105
Status: offline
Hi Ed, completely in the users folder. AFPD needs write permissions in the chosen folder and under mountain lion I think this is not allowed for the app folder. This might cause some issues later.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 7
RE: AFPD problem with mountain lion - 11/16/2012 5:55 PM
ekeesee
Score: 100
Status: offline
Thanks Mike, I really appreciate your help. It's working great now.
Hide Signatures
       Post #: 8
RE: AFPD problem with mountain lion - 12/28/2012 6:03 AM
TBouch
Score: 100
Last Login: 2/19/2013
Status: offline
Hi Mike,
I just purchased the areofly pro deluxe and am trying to use on this same operating system. Mac OSX 10.8.2 mountain lion. It seems to have the same problem here. I tried downloading the patch with no success. Also I am unaware of how to install it on my computer. When I open the disc I open afpd-v1110725.dmg and it mounts the disc after verifying. Once that is done I can open the folder AreoFly Professional Deluxe which has the AreoFly app in it. When I click the app I get the same error code as above. Am I doing something wrong and is there a separate way to install the app?
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
