Cargo Trailer Ceiling Material    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Cargo Trailer Ceiling Material
Page: [1]
Login
Cargo Trailer Ceiling Material - 11/15/2012 11:43 PM
dasintex
Score: 126
Last Login: 5/26/2013
Status: online
I'm renovating my Cargo Trailer to a decent Plane Hauler, the Ceiling/Roof is slightly curved and I want to insulate it with some styro which will not be a problem, the trick is what do I use to cover the ceiling afterwards, the ceiling has metal ribs that I can easily screw the covering onto, I'm thinking some thin gauge aluminum or galvanized tin from a tin working shop that makes ducts, etc; I figure it can bend to match the curve, light weight, can be secured to the ribs with self tapping sheet metal screws, etc; any suggestions, or am I on the right track?
Thanks.
_____________________________
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
       Post #: 1
RE: Cargo Trailer Ceiling Material - 11/16/2012 1:20 PM
jbdismukes
Score: 110
Last Login: 5/25/2013
Status: offline
Would thin insulating panels be another option?  Flexible and would supplement the styro insulation.  It also might mitigate "hanger rash".
My Senior Moments have become Senior Momentum
Hide Signatures
(in reply to dasintex)
       Post #: 2
RE: Cargo Trailer Ceiling Material - 11/16/2012 9:44 PM
dasintex
Score: 126
Status: online
What are Insulating Panels? you mean the thin Blue Foam Stuff?
P-40 Brotherhood #3
Hide Signatures
(in reply to jbdismukes)
       Post #: 3
RE: Cargo Trailer Ceiling Material - 11/16/2012 10:18 PM
jbdismukes
Score: 110
Status: offline
That's one type.  Other brands have a paper or thin cardboard surface, similar to the foamboard used for posters.
Hide Signatures
       Post #: 4
RE: Cargo Trailer Ceiling Material - 11/18/2012 11:49 PM
PLANE JIM
Score: 171
Status: offline
I used 3/4 inch foam board on my roof and then lined from the inside plastic panels from Lowes-they are white in color made of plastic in 4X8 sheets-same material as you would use in a not so fancy shower stall-cuts easily and screws with self tappers into the roof ribs-they have a 1 inch divider strip to join two panels at seam.
"IF YOU HAVE TOO MANY AIRPLANES -FLY BOLDLY AND REDUCE YOUR NUMBER"
Hide Signatures
       Post #: 5
RE: Cargo Trailer Ceiling Material - 11/19/2012 12:53 AM
dasintex
Score: 126
Status: online
quote:
ORIGINAL: PLANE JIM
Are those Shower Stall Panels Flexable enough to curve a little bit, to follow the contour of the roof curvature?
P-40 Brotherhood #3
Hide Signatures
(in reply to PLANE JIM)
       Post #: 6
RE: Cargo Trailer Ceiling Material - 11/19/2012 3:33 AM
Mpizpilot
Score: 100
Status: online
Go to go homedepot And ask for FRP (fiberglass reinforced plastic). Very flexible, use a good pair of shears to cut it. 1/4-1/2" foam board for insulation, then screw the FRP to ceiling ribs with self tapping 1" sheet rock screws.
Hide Signatures
       Post #: 7
RE: Cargo Trailer Ceiling Material - 11/20/2012 12:47 AM
PLANE JIM
Score: 171
Status: offline
Yes they are flexible-do your self a favor if your are in a cold environment-warm them up a little bit they become brittle when cold.
They will follow radius of the ceiling-
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
